Californio Samba Member
Posted: Thu May 23, 2013 10:53 am Post subject: Any test for I4 low end failure? |
Here's what's going on. I have to take a long trip in a couple of months, 5K miles +, with my Tiico powered Vanagon. Last year I lost an engine--it was making a kind of clicking noise, got worse, finally threw a rod on the freeway. I replaced the block with a used and have been driving it since. But now it is making a similar noise. Ominous.
I talked to the Tiico gurus at FAS and am convinced that s new ECU and related parts will help this engine out (by reducing heat, running richer, etc.) and am ready to buy their parts.
The question I have is: how can I determine before the fact whether the internal parts of the engine are showing so much wear that it's still going to grenade on me?
I was told that installing an oil pressure gauge would tell me the state of the connecting rod/crank bushings, etc., but is there any other diagnostic I can do to figure out what shape the engine internals are in?
Compression is pretty good at 150-160 per cylinder. |
danfromsyr Samba Member
Posted: Thu May 23, 2013 12:19 pm Post subject: |
was your clinking noise pre-detonation?
as for throwing a rod, a oil pressure gauge is a good way to monitor the normal health of your motor. it'll show when the oil thins from breaking down even before the ~3000mi change interval.
for the most part the VW I4s have a very robust bottom end. and failure is usually from preventable maintenence or owner interaction.
my last I4 had excessive blow by and would puff out a huge black cloud on downshifts when struggling up major hills.
still I took it across the Berkshires before I swapped it for another randomly used I4
I run 1.8l digifant engines fwiw _________________
Abscate wrote: |
Posted: Thu May 23, 2013 12:33 pm Post subject: |
That's the thing, it's hard to tell what it is. Could be loose tin someplace (that's what Peter at Van Cafe thought it was when he drove it) or it could be internal. These engines have knock sensors that retard the ignition timing on pre-detonation, so I don't think it's that.
Anyway, other than oil pressure and compression test, anything that could help determine if the internals are good? I can't think of anything but maybe there is some trick? |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu May 23, 2013 12:46 pm Post subject: |
Californio wrote: |
There are no tricks in auto mechanics - this isn't a video game with 'cheat codes'!
Worn wrist pin bushings will rattle when you take the cylinder pressure off them but if Peter drove it and didn't hear anything ominous, that's a pretty good sign.
If the oil pressure checks out both cold and hot, its up to the driving style to keep it going. Be sure that you don't lug the engine - high revs are better than low.
If you want a guarantee, you'll need to have a good shop rebuild the engine for you - its the only way to *know* what you've got.
Good luck! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
r39o Samba Polizei
Posted: Thu May 23, 2013 1:12 pm Post subject: |
Pull the pan and look?
Leak down will tell about upper end.
Oil pressure dips under acceleration indicate worn bearings.
Yes, no tricks.
The lower end of the I4 is quite robust.
I read about the Tiico ECU issues and you NEED the later stuff that FAS has.
Or the early 90s Digifant A2 setup, but you have a Tiico, so it is easiest to stay with what FAS has and recommends. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Robw_z Samba Member
Posted: Thu May 23, 2013 1:48 pm Post subject: |
If you really wanna know just pull the pan and look. Not as involved as you may think, though to be honest I've only pulled pans from VW I4's when they were in their native vehicles. You can remove and inspect the rod bearings, even throw new ones on. You would have to re-torque and possibly replace the rod bolts as well.
-Rob |
Vango Conversions Samba Member
Joined: October 04, 2010 Posts: 1054 Location: Seattle, WA
Posted: Thu May 23, 2013 1:50 pm Post subject: |
Since you've had a failure before, install an oil pressure gauge for sure.
It wouldn't be a TON of work to drop the pan and inspect the bearings, but it would take some time. Synthetic oil might help a little too. |
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Thu May 23, 2013 3:10 pm Post subject: |
I went through two engines in my rabbit before finally changing the intermediate shaft bearings. Rod #1 bearing failure each time _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Thu May 23, 2013 10:37 pm Post subject: |
To me, one of the most cost effective and accurate ways of getting a handle on the bearing condition (what you're essentially asking about) is to send an oil sample in to Blackstone Labs. I have no doubt your engine is really well represented in their huge data base. Just clarify the year and vehicle it came from (or just pick a vehicle/year you know this exact engine is used in) in the explanation section so they'll know that and be able to accurately compare for you.
If your main bearings are loose/worn then their analysis will know because slack bearings produce more wear from the metals (loose means micro banging and continued metal removing) in these areas that will show up in the oil. This service is about $25 and I have used them for decades to keep track of my engines. Warning, it's addictive. They know what metals in your engine are where and are very reputable.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
