tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Fri May 24, 2013 7:04 pm Post subject: Curious brake problem |
I've searched and I'm certain it's the servo, but I thought I would post this just to get confirmation and share this problem if others have it. My brakes work perfectly all the time except above an ambient temperature of 90 degrees. I have replaced every single component on the system except the proportioning valve and the servo. I have cleaned and greased the brake pedal pivot and put a new return spring in. When it gets above the said temperature the brake pedal will not return and I have to pull it up with my toe. Cool or freezing weather everything is great, but above 90 the problem is persistent and quite annoying. Thoughts? _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12688 Location: on a bike ride somewhere
Posted: Fri May 24, 2013 7:16 pm Post subject: |
Do your brakes drag along with the pedal not returning? _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51057 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri May 24, 2013 7:23 pm Post subject: |
Try disconnecting the servo hose from the plenum (cap the nipple on the engine) and see if it still does it, beware!, the brakes will require more effort to stop but if it cures the problem a booster rebuild is in your future.
How much freeplay is in the pedal pushrod? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri May 24, 2013 7:27 pm Post subject: |
asiab3 wrote: |
Do your brakes drag along with the pedal not returning? |
Nope
busdaddy wrote: |
Try disconnecting the servo hose from the plenum (cap the nipple on the engine) and see if it still does it, beware!, the brakes will require more effort to stop but if it cures the problem a booster rebuild is in your future. |
I suppose that is the ultimate test. This has been a persistent problem as the PO had a crappy hose clamp/hardware store spring solution set up on it. I will try that tomorrow and report in. Edit: The temperature tomorrow is not forecast to be high enough so I'll have to wait until it gets hot. In Saint Louis that can happen in one day though. _________________ air-cooled or nothing for me
Hoody Samba Member
Posted: Sat May 25, 2013 12:28 am Post subject: |
Well there ya go. You have air in a sytem that you shouldn't. |
