What battery to buy?
Page: 1, 2, 3  Next
Bret Young
Bret Young is offline
PostPosted: Sat May 25, 2013 8:09 am    Post subject: What battery to buy? Reply with quote
So I've got my bus pretty much rewired and its time to buy a battery (bus didnt come with one), and im trying to determine what battery I should buy. I searched, but didnt find any model numbers specifically. I have dealt with WalMart batteries in the past, but haven't had great luck with them, and was thinking about splurging for a Optima due to the warranty and them being a little heavier duty. I don't know if bus batteries sizes changed over the years, but my bus is a 64 and is 12V.
If anyone has any incite to which Optimas fit properly in busses, I would be greatly appreciative. I don't know if red tops or yellow tops are better, but I would take part numbers for either one.
Thanks in advance!
campingbox Premium Member
campingbox is offline
PostPosted: Sat May 25, 2013 8:25 am    Post subject: Reply with quote
I've bought a few of these from Amazon and they fit and work fine.
8002-002-FFP
You can't use a stock battery cap but you can get the strap to work if you shim it with a small block of wood.
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Sat May 25, 2013 8:50 am    Post subject: Reply with quote
The dry cell and gel cell batteries have very different charging needs as do the new gen of lithium ion batteries. Not a battery for the home DIY guy. Some will not even stand to be boosted by jumpers.
Just buy a traditional battery with the biggest cold cranking rating you can fit in the space provided. I would stick with name brand batteries that have a 7 year pro-rated warranty, as most batteries only last 5 years, one that they build expecting 7 should be better quality. A little bit more money spent on a good battery now, is less spent on a tow truck later.
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
Bruce Amacker
Bruce Amacker is offline
PostPosted: Sat May 25, 2013 8:59 am    Post subject: Reply with quote
Gordo.
I agree on avoiding an Optima as they are expensive overkill for most VW applications.
The highest CCA you can fit is also overkill and will actually work against you. To get CCA means thinner plates and thinner plates many times will not last as long as thicker plates in a lower CCA battery. I think more than 600-700CCA in an ACVW is overkill.
Look for a sale with a good (3 yr replacement) warranty. Costco is cheap and made by Interstate, they're about $70 here for 650ish CCA.
Good Luck!
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
PostPosted: Mon May 27, 2013 11:20 am    Post subject: Reply with quote
If you have the particular model or Costco inventory # for the battery you bought at Costco, please post it here.
ttullo1
ttullo1 is offline
PostPosted: Mon May 27, 2013 11:27 am    Post subject: Reply with quote
If you look at Consumer Reports they have named the Walmart ones the best. I have been running one in my SC for a while with no issues
Bret Young
PostPosted: Mon May 27, 2013 11:37 am    Post subject: Reply with quote
Did not know this. That's interesting. I believe that Walmart and Costco would be up there with the best warranties since they sell so many of them.
But I am with Everett. Parts/model numbers are always appreciated.
Culito
11010101
Culito is offline
PostPosted: Mon May 27, 2013 12:06 pm    Post subject: Reply with quote
I also have a walmart battery in my SC. No problems here, even when it sits for months at a time. I'll see if I can find a number on it...I just picked it off the shelf.
I ruined the first walmart battery I had due to a bad voltage regulator. They exchanged it, no questions asked.
Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
ttullo1
ttullo1 is offline
PostPosted: Mon May 27, 2013 12:07 pm    Post subject: Reply with quote
I will go down to my shop later today and get numbers
BulliBill
BulliBill is offline
PostPosted: Mon May 27, 2013 12:22 pm    Post subject: Reply with quote
Can anyone post the same info for 6 volt batteries??? I know the local strip mall Interstate battery store has 'em for $125 (ouch!). Any other sources? I'm willng to order and wait for one too if size and price are right...
Bill
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
zozo
zozo is offline
PostPosted: Mon May 27, 2013 12:45 pm    Post subject: Reply with quote
Bill
I ordered a 6-volt optima through Amazon for around $90. The price has gone up, but still comparable to the "norm".
http://www.amazon.com/Optima-Batteries-8010-044-St...lt+battery
C.Moore
C.Moore is offline
PostPosted: Mon May 27, 2013 1:00 pm    Post subject: Reply with quote
I've been running 6V optimas for years in my 6V VWs and have had no problems. They are costly.
Stocknazi
Stocknazi is offline
PostPosted: Mon May 27, 2013 5:46 pm    Post subject: Reply with quote
Bill
i just bought a 6 volt battery at advance; higher cca than the autozone 6volt. i believe it has 800 cranking amps and 650 cca
price was 95.00 plus tax
WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson
obus Premium Member
obus is offline
PostPosted: Mon May 27, 2013 5:56 pm    Post subject: Reply with quote
running a 6v optima in my mangObus also with no issues. starts in the cold of winter too.
66 21 window bus built 8/31/65 https://www.thesamba.com/vw/forum/viewtopic.php?t=777273
flemcadiddlehopper
PostPosted: Mon May 27, 2013 6:44 pm    Post subject: Reply with quote
CCA probably not as important in California, as it would be in the colder climate areas. But for me, the biggest battery you can fit in regardless of cold cranking.
Gordo.
andk5591
andk5591 is offline
PostPosted: Tue May 28, 2013 3:42 am    Post subject: Reply with quote
I use Optimas red tops in several of my bugs. Oldest one has been in for 5 years and 20,000 miles.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
ToolBox
ToolBox is offline
PostPosted: Tue May 28, 2013 9:56 am    Post subject: Reply with quote
Bill
Tractor Supply
Farm and Fleet
Bret Young
PostPosted: Tue May 28, 2013 12:22 pm    Post subject: Reply with quote
Any more info on the 12V Walmart / Costco battery part numbers guys and gals?
TinCanFab
TinCanFab is offline
PostPosted: Wed May 29, 2013 12:35 pm    Post subject: Reply with quote
A part #7244 is a NAPA group 1 6 volt, made by Johnson Controls. Same company that makes Interstate.
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
don.ville Premium Member
Samba YardMan
don.ville is offline
PostPosted: Wed May 29, 2013 5:24 pm    Post subject: Reply with quote
See this thread.....
http://www.thesamba.com/vw/forum/viewtopic.php?t=553578
04 Jetta TDI Page (SOLD)
29 Ford Model A Rat Rod (SOLD)
2015 Audi A8L TDI Quattro
Page: 1, 2, 3  Next
