Front Transmission Mount
Chris_914
Chris_914 is offline
PostPosted: Sun May 26, 2013 10:03 am    Post subject: Front Transmission Mount Reply with quote
When I pulled the engine I noticed the front trans mount had significant vertical play. I decided to make my own polyurethane mount.
'75 Westfalia Camper FI 1.8L
'75 914 2.0L
Chris_914
PostPosted: Sun May 26, 2013 12:08 pm    Post subject: Reply with quote
Front trans mount is now checked off the list of things to do\buy before the engine can go back in. It will be fully cured in a week.
'75 914 2.0L
SGKent Premium Member
SGKent is offline
PostPosted: Sun May 26, 2013 1:40 pm    Post subject: Reply with quote
Hi Chris - you might want to keep your eyes open for a good used original to throw in your goody box. Sometimes urethane mounts are so stiff that the sound gets transmitted thru them.
American Standard Snorkeling Terrier
Bring the American Hostages home alive.
Thanks to all who served:
germansupplyscott
germansupplyscott is offline
PostPosted: Sun May 26, 2013 2:58 pm    Post subject: Reply with quote
beauty job!
Applause
SL
Chris_914
PostPosted: Sun May 26, 2013 5:01 pm    Post subject: Reply with quote
The 60A formula was designated as softer for daily driver. The play was putting stress on the shift shaft causing it to leak from the nose cone seal and an occasional noise transfer that vibrated the whole shaft.
In case anyone is looking I pick up the polyurethane from an independent Energy Suspension dealer.
http://www.energysuspensionparts.com
Part number: DIYMMI
Or you might see if Forsch sells directly to the public.
Looks like there was enough in the 1Lb kit to do 2 or 3 more.
'75 914 2.0L
busdaddy
busdaddy is offline
PostPosted: Sun May 26, 2013 5:36 pm    Post subject: Reply with quote
That's impressive, nice work and thanks for sharing it!
Please give us a report on how it holds up and if it sounds or feels any different afterwards.
Chris_914
PostPosted: Sun May 26, 2013 5:50 pm    Post subject: Reply with quote
Forgot to include this photo. It's how I set the shaft to be centered in the rig before I cut out the rubber center. The all thread clamps the top shut in addition to setting the height of the mount carrier. The height of the U-shaft ends are set by resting on the slides of the drill press vise. Markings on the aluminum sides and top plates from the mockup with the original rubber square it all up. The punched L-channel is just to give the left side all thread something to rest on.
'75 914 2.0L
1967250s
1967250s is offline
PostPosted: Mon May 27, 2013 8:36 am    Post subject: Reply with quote
Nice tutorial. I bet you can make all sorts of stuff with that poly. I know I'm fed up with breaking rear engine mounts on my '72! Now, how does it perform when installed? How flexible and how strong is it compared to rubber and the regular polyurethane VW aftermarket bushings?
Dare I say, wouldn't it have been easier to just fill the space with poly?
Chris_914
PostPosted: Mon May 27, 2013 12:57 pm    Post subject: Reply with quote
I thought about just filling in the gaps with the poly but I couldn't be sure it got where I needed it. The stuff is thick and without vacuum or pressure casting techniques I couldn't be sure of not trapping air pockets.
This formula, by the option I bought, is softer that what I am used to for poly mounts and bushings. It has complete set now and is still flexible, it is a little bit stiffer than the OE rubber but not by much. I can squeeze the left over between my fingers and distort it, not something I can do with the poly performance bushing I have purchased for various other projects.
I am feeling pretty good about this being a real front mount option.
'75 914 2.0L
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Mon May 27, 2013 11:59 pm    Post subject: Reply with quote
i have heard some dollar store bouncy balls can make some good shift coupler bushings too...Wink
Stuart Zickefoose
206-841-7324
[email protected]
Chris_914
PostPosted: Fri Sep 20, 2013 10:04 pm    Post subject: Reply with quote
Just wanted to confirm that this is a solution.
Finally got the engine in and have put about 40 miles on.
Shifting is noticeably better and there is no extra noise being transferred through the mount. Because of the engine rebuild it is actually quiet inside the bus now.
'75 914 2.0L
archemitis
archemitis is offline
PostPosted: Sat Sep 21, 2013 6:24 pm    Post subject: Reply with quote
I have done the same thing, and it transmits alot more vibration into the cab. Urethane is almost solid. Not at all like rubber. If you do one mount, you might as well do them all, because a few rubbers and one urethane does not mix well.
Having said that. Theres nothing better than some stiff ass urethane mounts for holding your engine where its supposed to be.
Chris_914
PostPosted: Sun Sep 22, 2013 7:01 pm    Post subject: Reply with quote
This stuff is pretty close to the rubber.
'75 914 2.0L
