climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Sun May 26, 2013 2:35 pm Post subject: Imagine what I just found in my engine bay . . . |
It's been a few days since I drove the van. I went out a few minutes ago to check something in the engine bay.
Imagine my shock and surprise when I lifted the lid and found this sitting front and center on top of my Subaru 2.5 engine:
It was about a softball sized mound of fluffy and, as they say, "tinder dry" plant husks, seed pods, etc. No rodents were home. The dryness of this is a little mysterious, as it's been dumping rain here in Portland last few days.
I tossed it out, and blew out with an air compressor all the remaining fluff that I could find.
Gee, you think THIS might start a fire!?!?
I was pretty freaked out when I saw it, and still am. It was just blind luck that I happened to go lift the lid. Any other time, I would've gone off for a drive, and the engine and exhaust manifold would heat up, and then . . . I can imagine that fluff ball catching fire and causing all sorts of mayhem.
I heard a sad story recently about a beautiful van catching fire after being stored for the winter and driven for the first time. A mouse nest in the engine bay seems a totally plausible way for this to happen.
Anyway, this post is for me to vent a little bit, and perhaps caution people to be sure and check this if there vans are in storage for a while. (Of course, mine was not even in storage, just sitting in my driveway for a few days.)
-CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often.
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Sun May 26, 2013 2:41 pm Post subject: |
Isn't that a mouse butt in the picture in the lower left side? Either way, that is both scary and lucky!
tam _________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
Posted: Sun May 26, 2013 2:53 pm Post subject: |
No, those two dark things in the middle of the fluff ball are actually some shreds of black foam. The little bugger chewed them off the insulation on the bottom side of the deck lid! _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
juanb Samba Member
Joined: December 03, 2009 Posts: 535 Location: San Francisco, CA
Posted: Sun May 26, 2013 3:02 pm Post subject: |
Yet another reason to run an unreliable waterboxer that requires you to open the lid every couple of days, instead of those Japanese things that never break down.
(I'm kidding) _________________ 1989 Westy AT, 2.2 GoWesty.
We drove it to Argentina: http://www.vanenvan.com |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
danfromsyr Samba Member
Posted: Sun May 26, 2013 3:17 pm Post subject: |
while I cetainly find it disturbing the rapid resourcefulness of the home maker
I don't believe it would have caught fire there, stank sure maybe. but the intake manifold doesn't get hot enough to light 'tinder' again just my not always humble opinion..
does do good conscience to check under there though. _________________
Abscate wrote: |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9808 Location: Mt Lemmon, AZ
Posted: Sun May 26, 2013 3:18 pm Post subject: |
Mine came with a 'friend'.
I was pulling the stuff out of the area where she had made her home -- even though I thought I was ready for it, when my hand came out with this I screamed like a little girl.
Zeitgeist 13 Samba Member
Posted: Sun May 26, 2013 3:23 pm Post subject: |
My cats keep such rodent flare-ups at bay...well that and the generally greasy unpleasantness that is my engine environment _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
tencentlife Samba Member
Posted: Sun May 26, 2013 6:48 pm Post subject: |
Welcome to our world! _________________ Shop for unique Vanagon accessories at the Vanistan shop:
debbiej Samba Member
Joined: December 14, 2008 Posts: 1556 Location: las cruces, nm
Posted: Sun May 26, 2013 9:10 pm Post subject: |
Pack rat, or nicer name, kangaroo rat, ate many,many wires on a parked BMW. The whole engine bay was full to the top, of seeds, wire, twigs, etc, etc. my husband parked it for a couple of weeks, and so much of the wiring was destroyed, it is still parked a couple of years later. We check all our cars almost daily. They are SO destructive!
Have to try the mint. |
Vango Conversions Samba Member
Joined: October 04, 2010 Posts: 1054 Location: Seattle, WA
Posted: Sun May 26, 2013 10:22 pm Post subject: |
I see stuff like this all the time. They do seem to like clean engines that aren't all greasy but they don't care too much about the make. Clean flat and V engines seem to be the worst though as they have the most area to make their nests, but most engines I work on (especially Subaru) have at least a few nuts and seeds scattered about.
The cars and trucks with the softer under hood insulation really suffer, as the critters like to use that stuff for nesting material. For some reason on the Subarus, it seems like every one I've worked on, has at least a few chew marks on the little red boot that covers the alternator post. Must be something that they like in the rubber. Like mentioned before, plenty of cars have had a $hit load of $$ dammage done by critters chewing on wires. I wonder if some makes are more vulnerable than others. Maybe some have more of whatever is tasty like in the Subaru alternator post.
Shouldn't be much of a fire hazard though unless the nest is on the exhaust or they chew through the wiring insulation. |
Posted: Sun May 26, 2013 10:55 pm Post subject: |
Mice are one of the main vectors for Lyme Disease. It pays to keep the number of those critters low for multiple reasons. |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Sun May 26, 2013 11:28 pm Post subject: |
danfromsyr wrote: |
I don't believe it would have caught fire there, stank sure maybe. but the intake manifold doesn't get hot enough to light 'tinder' again just my not always humble opinion.. |
This.
Good to get rid of the mouse nest before it got too established though.
I'll have to try the mint trick! _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Mon May 27, 2013 5:19 am Post subject: |
djkeev wrote: |
You will think me cray but........ Mint extract is your friend!
Make a mixture, put it in a Spray bottle and periodically spray your vulnerable areas..... No more mice...... EVER!
Dave |
Dave, at Vanagon meets, we always refer to you as Cray. However, peppermint oil worked to keep mice out of my van last winter. I find I have to mail order it to get the real stuff. Never thought of just spraying it around - great idea!
That reminds me, behind the right taillight is another hiding spot they like. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Mon May 27, 2013 5:59 am Post subject: |
debbiej wrote: |
Pack rat, or nicer name, kangaroo rat, ate many,many wires... |
At the risk of sounding pedantic, the common Packrat is the White Throated Woodrat. The Kangaroo Rat is different altogether and an unlikely automotive problem.
In our van the a packrat took up residence in that open saddle in the middle of the gas tank -- very hard to get at. I had to move the car from one side of the driveway to the other so I backed up and then promptly pulled forward again. Sadly my rodent friend cho,se that moment to hop down (didn't want to go for a ride) and got run over as I pulled forward to park.
Sad... but also satisfying. |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Mon May 27, 2013 7:05 am Post subject: |
Vango Conversions wrote: |
For some reason on the Subarus, it seems like every one I've worked on, has at least a few chew marks on the little red boot that covers the alternator post. |
It's funny you mention this. This is what got chewed up when we over-nighted at one of our favorite spots in Moab. They don't waste any time. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin |
Royb Samba Member
Joined: May 24, 2008 Posts: 228 Location: Sierra Foothills
Posted: Mon May 27, 2013 8:23 am Post subject: |
To be really pedantic, any woodrat is a packrat, but I agree- kangaroo rats probably aren't interested in vanagons. In the Sierra we typically have deer mice building nests in engines, especially in air cleaner boxes, but what's worse are ground squirrels, which have done hundreds of dollars worth of damage to many our work trucks by nibbling on wiring. They also leave acorns behind. _________________ 1991 Westy |
svenakela Samba Member
Posted: Mon May 27, 2013 8:47 am Post subject: |
This is what I found after a trip from Portugal to Sweden. I don't know it's native language but I suspect it talked with a Spanish accent.
More than a pound for sure.
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon May 27, 2013 10:59 am Post subject: |
In my younger years I was carrying a dead pack rat that we trapped to bury. The skin on the tail pulled off in my hand and I could feel each tail bone slide past my fingers before I could let go. Like a zipper feeling Very nasty. I only move them with a shovel or reaching wand now, not with my bare hands. |
NC Dude Samba Member
Posted: Mon May 27, 2013 11:40 am Post subject: |
Are you SURE that ain't a dead mouse under your black junction box in the upper left hand of the pic? I see what looks like a tail and rear legs |
