79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Thu May 30, 2013 11:50 am Post subject: Spindle Differences before 1965 |
Someone is selling a set of stock spindles and king pins and are advertising them as "1953 - 1960". But spindles available from Wolfsburg West are advertised as fitting anything pre-1965. Is there a difference in spindles between 1953-1960 and 1962? _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
flat Samba Member
Joined: April 02, 2004 Posts: 160 Location: Alberta, Canada
Posted: Thu May 30, 2013 1:05 pm Post subject: |
The only difference I've noted is that pre 61s have 10mm grease fittings, where as lates have 8mm _________________ www.vdubengineering.com
IG: VdubengineeringCanada |
Posted: Fri May 31, 2013 11:16 am Post subject: |
So does the commonly available grease gun come with 8mm fittings? Just wondering if I would have to get another grease gun if I got these spindles, if they have 10mm fittings. _________________ Central Jersey VW Society
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri May 31, 2013 12:43 pm Post subject: |
The nipple is the same size just a different size hole they screw into
IIRC the 60 and earlier used 10 shims per link pin and the 61 and later used 8 per with an o ring and dust shield with a nub that fit into a notch either in the carrier or the arms (to long since I seen one to remember ) |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri May 31, 2013 1:17 pm Post subject: |
Dont confuse Spindle/Knuckle and Link Pin Carrier (Torsion Arm Link)..
The spindles are the same but the shim stack and trailing arms changed in 1960. Thats when the shim count change occured.
The grease fitting in the Torsion Arm Link changed thread size as well in I beleive 1960.
(For USA Link Pins)
53-59 =10 shims
60-65 = 8 shims, oring and shield.
60-65 trailing arms also have a groove and slot for the oring to be captured.
The Carriers/Links are interchangeable and from what I've found. Use simply the shim stack based on the trailing arm design its being used on.
So its again a question of how original or how not... _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sun Jun 02, 2013 9:55 am Post subject: |
Thank you all for your replies. _________________ Central Jersey VW Society
