SCM Samba Member
Joined: January 26, 2011 Posts: 3118 Location: Bozeman MT
Posted: Sat Jun 01, 2013 1:01 pm Post subject: Lost low speed on radiator fan |
I just finished my coolant system R&R and noticed my radiator fan was occasionally a bit noisy during the bleeding process. I tightend a few things up (plastic wind deflectors and the tabs that hold the AC condensor to the rad) and the noise appears to have ceased.
BUT, now I only have the highest speed of my fan. When I jumper the 3 fan switch wires I don't get the low speed. Low speed doesn't come on with the AC either. This all worked fine prior to the coolant system work that I just completed.
The rad fan fuse is good. According to GoWesty's article, my fan is a one speed unit with relays and a resistor used to operate at the lower 2 speeds. Does it seem likely that one of these things just happened to go bad and how do I test each of them?
Thanks _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Sun Jun 02, 2013 6:29 am Post subject: |
This will bump your post. I believe the 91 had an external resistor by the l/f head light behind the grill that controlled the speeds. On factory air models the radiator was actually a 3 speed fan. The resistors do go bad. I used one from a eurovan on ours. Long story. I'd want to check further with a test light or volt meter and the Bentley before I condemed a part or worse ordered the wrong one. _________________ ☮️ |
SCM Samba Member
Posted: Sun Jun 02, 2013 6:01 pm Post subject: |
F-it. I'm punting this one on over to the mechanic. Between the loss of low speed fan, still noisy (only when hot) fan, and what I suspect is a stubborn air bubble around the t-stat... I'd rather pay someone to fix it all while I'm at work instead of burn another weekend.
I'll post what I find out. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
onslowb Samba Member
Joined: November 20, 2006 Posts: 315 Location: Woodland Hills
