scottjk Samba Member
Joined: May 31, 2006 Posts: 485 Location: Salt Lake City, UT
Posted: Sun Jun 02, 2013 10:57 am Post subject: Addco 719 Bushing Slop - HELP |
I'm rebuilding my entire front end and have the Addco 719 large diameter front sway bar. My van is a 1985 that originally came with two mounting holes and bracket for the body bushings. As you can see from the picture there is a TON of slop between the bushing, bar and body. It appears to me that the bend in the body doesn't work well with the Addco bushing and bracket.
Had anyone else had this problem? How critical is this slop? Does most of the energy transfer between end links or do the body bushings play a critical role?
I'm going to contact Addco also but I'd appreciate any input.
Scott
_________________ 1985 Westfalia 2.5L EJ |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Jun 02, 2013 11:33 am Post subject: |
I don't see why you couldn't make a steel/nylon/white oak shim to fit in behind the bushing and tighten all that up but I'd be calling Chris at T3 technique to get a Powerflex body bushing.
The fit on those is perfect. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Sun Jun 02, 2013 12:04 pm Post subject: PowerFlex |
At the time of installation PowerFlex didn't make a front 7/8 sway bar bushing. I have an email in to him to see if that has changed.
I'm guessing that the 1986 and newer vans have their body mounts slightly rearward allowing the bushing and bracket to sit flush to the body instead of the slight angle I have in my 1985.
Thanks
Scott _________________ 1985 Westfalia 2.5L EJ |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sun Jun 02, 2013 1:52 pm Post subject: |
What is your impression of the sway bars so far. ? in comparison to the original sway bars? _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Sun Jun 02, 2013 2:15 pm Post subject: Impression |
Awesome! Body roll significantly reduced. Semi-Truck shutter while driving behind reduced. _________________ 1985 Westfalia 2.5L EJ |
boof1306 Samba Member
Joined: July 10, 2010 Posts: 304 Location: MELBOURNE AUSTRALIA
Posted: Sun Jun 02, 2013 3:37 pm Post subject: |
A used genuine bushing would probably fit just right. Breakers yard? |
Posted: Sun Jun 02, 2013 3:44 pm Post subject: Used Genuine Bushing? |
Not sure a OEM small diameter bushing would fit a 7/8 inch bar. _________________ 1985 Westfalia 2.5L EJ |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
Franklinstower Samba Member
Posted: Mon Jun 03, 2013 7:38 am Post subject: |
As I recall (its been a while), I either modified the bracket, or redrilled the mount points so the bushing would be tight on the body.
I'll check and take a picture for you.
Paul _________________ '89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug |
Posted: Mon Jun 03, 2013 8:21 am Post subject: Redrill |
Thanks FT... that is the conclusion I was leaning toward. I'd love to see a photo if you have the time. _________________ 1985 Westfalia 2.5L EJ |
Posted: Mon Jun 03, 2013 9:30 am Post subject: T3 Technique |
Here is a reply I got from Chris at T3 Technique
"Yes, this is an issue with the Addco products. You have the early style sway bar mounts and Addco does not make a bushing for that application. Neither does Powerflex or Whiteline. I have toyed with the idea of machining a set of the Whiteline bushings to fit".
I'm a bit pissed that Addco markets these for all Vanagon models. _________________ 1985 Westfalia 2.5L EJ |
Vango Conversions Samba Member
Joined: October 04, 2010 Posts: 1054 Location: Seattle, WA
Posted: Mon Jun 03, 2013 11:31 am Post subject: |
Can you bend the tab a little more so it sits flat? seems like that would tighten it up a little bit. Then shim what's left of the slop. |
wasserbox Samba Member
Joined: April 08, 2008 Posts: 533 Location: Durango, CO
Posted: Mon Jun 03, 2013 11:42 am Post subject: Re: Addco 719 Bushing Slop - HELP |
scottjk wrote: |
Scott
Same thing here- but mine started knocking when I'd hit a bump. Awesome down my dirt road. whap whap whap whap whap whap whap whap
I contacted ADDCO - they shipped out some beefier mounts with polyurethane bushings.
They do have a lifetime warranty on all their products. |
Posted: Mon Jun 03, 2013 11:46 am Post subject: Addco |
Oh sweet... I have an email and phone call in to Addco. _________________ 1985 Westfalia 2.5L EJ |
