1974 VW Bus Hi top W/Subaru EJ25 swap Pics!
Page: Previous  1, 2
mack00
mack00 is offline
PostPosted: Wed Apr 30, 2014 11:42 am    Post subject: Reply with quote
Hey Jay-
You stated that the fuel injection return line goes to the fuel tank vent line. How is your tank venting?
Note also the Fuel Injection "return" line penetrating firewall. This line goes into the stock VW "vent" gas line.
jaycanode
jaycanode is offline
PostPosted: Wed Apr 30, 2014 5:34 pm    Post subject: Reply with quote
Mack, I have since changed my setup. I welded return bung into filler neck. I now use stock purge valve and charcoal can from stock vents. But originally since there are 2 vents on this bus, one was always left to vent to atmosphere.
alaskadan
alaskadan is offline
PostPosted: Fri Jul 17, 2015 8:05 am    Post subject: Reply with quote
Bump. So any new issues and or fixes? I just met with someone who wants to put a 2.5 in a 78 riviera. We will be tackling this in the fall/ winter. Will likely put the rad underneath between frame rails. Curious about the vss and removing the groundstrap. Ive put a 2.5 in my 87 syncro already using a small car setup. Thus im usually cruising the vanagon forum. Now researching the bay suby conversions. Any tips or posts that would be suggested are appreciated.
jaycanode
PostPosted: Fri Jul 17, 2015 10:27 am    Post subject: Reply with quote
No Huge issues once the crazy ground strap issue was resolved. Pretty sure there was a ground loop through the starter robbing the ignition of power. Dont know how/why. Loving the bus. Upgraded to freeway flyer R&P transmission. Plenty of power to spare. I think keeping radiator out of engine bay is crucial. If you have rads under frame make sure there is a LED indicator for when fans switch on. I might recommend a manual transmission suby engine/ECM. Mine is auto and its a bit qwirky when engine is cold. (ENgine ramps down very slowly with clutch in changing gears.) Cheers. Contact me with any questions.
thebusandus
thebusandus is offline
PostPosted: Fri Jul 17, 2015 11:37 am    Post subject: Reply with quote
That really makes no sense! How did you figure out the issue? Subaru uses quite a bit of ground normally so to remove your main ground means it is no grounding through the clutch cable? I've had two mechanics, well the only two who have seen my swap, both tell me they think I should run another ground cable to my swap (2.2)
Driving the Americas - Alaska to Argentina and Back!
2.2 Subaru powered 75 Westfalia
www.TheBusandUs.com
www.facebook.com/busandus
https://instagram.com/thebusandus/
Where it all began, build thread - http://www.thesamba.com/vw/forum/viewtopic.php?t=586470&highlight=divo
[email protected]
Samba Peckerhead
PostPosted: Fri Jul 17, 2015 1:24 pm    Post subject: Reply with quote
jaycanode wrote:
If you have rads under frame make sure there is a LED indicator for when fans switch on..
why?
as far as the auto trans, is your a/t m/t identifier terminal hooked up? are you running a VSS? my swap was from an auto, and no real issues. the idle "creeps" down just as it should.
how is the wiring for the NPS handled?
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
alaskadan
PostPosted: Sat Jul 18, 2015 12:21 am    Post subject: Reply with quote
Ok cool will contact you guys with more questions as i come up with them. Have a couple months to research and fish and moose to get right now. Smile
haydenslides
haydenslides is offline
PostPosted: Thu Jul 27, 2017 9:07 am    Post subject: Re: 1974 VW Bus Hi top W/Subaru EJ25 swap Pics! Reply with quote
I am digging your bus! I'm doing and EJ22 swap into my '74 Riviera. I'm going to do a front mounted radiator as well. What did you use for coolant lines?
Page: Previous  1, 2
Page 2 of 2
