Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Tue Jun 04, 2013 10:45 pm Post subject: Getting to the starter bolt with the engine in |
Anyone have any magic suggestions for inserting the top engine mount bolt (the one that passes through the starter) with the engine in place? I simply forgot to put it in place before installing the engine.
I'm not a big dude but I can't make my arm go up there. Not enough elbows, I guess.
Any clever suggestions? I really don't want to pull the engine again.
Thanks! |
Clara Samba Member
Posted: Tue Jun 04, 2013 11:21 pm Post subject: Re: Getting to the starter bolt with the engine in |
Major Woody wrote: |
Thanks! |
Lie under the bus with your head towards the front bumper and feet towards the taillights.
from in front of the starter reach one hand up above the starter and reach back towards the motor. slide bolt into place.
With other hand, reach into engine compartment and attach nut.
Some people like to jack the bus up to do this.
Some people remove the heater tube to do this.
Some people disconnect the battery to do this. or at least make sure it is out of gear. |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Wed Jun 05, 2013 2:57 am Post subject: |
If you need clearance, drive the two right wheels up on a curb (natures jackstand). If the bolt doesn't go right in, loosen the lower starter bolt a half turn or so. If it spins when you put the nut on, grip the head of the bolt with the tip of a small pair of vise-grips. The tool will lay neatly on top of the starter. |
thericklang Samba Member
Joined: July 12, 2012 Posts: 24 Location: Cleveland, OH
Posted: Wed Jun 05, 2013 4:12 am Post subject: |
I had to take my heater box off to get my big hands up there... |
flemcadiddlehopper Samba Member
Joined: December 05, 2011 Posts: 2332 Location: Kelowna, BC. Canada.
Posted: Wed Jun 05, 2013 6:49 am Post subject: |
This way may fall under the category of cheating, but...
go to a trailer hitch supply company and get those long wires with a spring looking end. They are made for fishing bolts through holes in frames.
Or wait for geneticists to help you with the extra elbow thing.
Gordo. _________________ Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others. |
KevinAlbrecht Samba Member
Joined: March 07, 2002 Posts: 970 Location: Ocean City > Boca > Pompano > Kirkland > Eugene
Posted: Wed Jun 05, 2013 7:26 am Post subject: Re: Getting to the starter bolt with the engine in |
Clara wrote: |
I am trying to imagine you having one hand wrapped around the starter while the other arm comes out from under the bus & into the engine compartment... _________________ Kevin Albrecht
Wait, what...?
WideFive wrote: |
Single carbs are for lawn mowers! |
Don't forget those seat-belts!
Click to view image |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Wed Jun 05, 2013 7:44 am Post subject: Re: Getting to the starter bolt with the engine in |
KevinAlbrecht wrote: |
Clara wrote: |
I am trying to imagine you having one hand wrapped around the starter while the other arm comes out from under the bus & into the engine compartment... |
X2 |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Wed Jun 05, 2013 7:50 am Post subject: Re: Getting to the starter bolt with the engine in |
Clara wrote: |
Me too!
Major Woody, I am a fairly big guy, not tall and I do it just as Clara noted, but I do have to jack the bus up a bit to get underneath and then contort a lot. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
Sniperx Samba Member
Posted: Wed Jun 05, 2013 8:31 am Post subject: |
6'1" and I have larger hands (shoot a 45 double stack easily) and I am able to snake my hand in there to push the bolt through. You'll want to lie on the ground with head towards front and just find the way in. Once you do it tou'll be amazed how easy it is to get a hold of. Then you forget exactly how you did it last time and make anOther thread about it.
It can be done. I do mine with no jacks and heaters installed. |
Posted: Wed Jun 05, 2013 8:43 am Post subject: |
Sniperx wrote: |
Then you forget exactly how you did it last time and make anOther thread about it. |
I have CRS also. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Clara Samba Member
Posted: Wed Jun 05, 2013 8:47 am Post subject: Re: Getting to the starter bolt with the engine in |
RPGreg2600 wrote: |
Clara wrote: |
X2 |
Just what I wish if there isn't someone around willing and able to help.
My first bus was a 59, with the older tranny/ starter w/o the holder for the D bolt, so it had hex bolts.
I'd put the bolt in so it poked threads into the engine compartment, then climb out from under the bus, climb into the engine compartment, reach past the engine, hold the threads of the bolt with a fine screw driver, thread the nut on, then put vise grips on the nut, then climb back underneath and snug the nut with a socket on a couple extensions and a ratchet.
Then repeat for the upper left hand bolt. |
Clara Samba Member
Posted: Wed Jun 05, 2013 8:55 am Post subject: |
Harleyelf wrote: |
If you need clearance, drive the two right wheels up on a curb (natures jackstand). |
It is awesome how curbs just grow there naturally.
reminds me of how this was kinda a scarey picture for me when I was a kid
Posted: Wed Jun 05, 2013 8:59 am Post subject: |
I will try raising the bus up a few inches more and try again tonight.
I don't want to have to dig through the parts list for this answer--are there supposed to be washers under the nuts? Mine had none--just D-head bolts and nuts.
Thanks for the words of encouragement. |
Posted: Wed Jun 05, 2013 9:12 am Post subject: |
No washer _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Wed Jun 05, 2013 9:19 am Post subject: |
I've never seen a washer under that starter/mount bolt/nut. But I have seen them on the two bottom mount nuts. These were on engines that appeared to have been original, and possibly never previously removed form the car.
If you have the later style D-bolt, and a 12 volt starter, I think you may have to loosen the lower starter mounting bolt to give enough clearance for the long bolt to pass through. As I recall, it will not go through with the starter bolted up tight. the bolt head hits the outer starter casing, and prevents the bolt from fitting through the hole.
I like to use some plumber's putty under the head of the D-bolt to hold it in place while I start the nut from the engine compartment. Then a ratcheting box end 17mm to finish it off. _________________ nothing |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Jun 05, 2013 9:49 am Post subject: |
Everyones a critic.
cdennisg wrote: |
I like to use some plumber's putty under the head of the D-bolt to hold it in place while I start the nut from the engine compartment. Then a ratcheting box end 17mm to finish it off. |
good advice. I like to clean the threads on that bolt if its old so it will thread easily once it's pushed through. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Clara Samba Member
Posted: Wed Jun 05, 2013 10:07 am Post subject: |
I like to use washers under the nuts.
I've never had to loosen up the lower starter nut to fit the upper starter bolt.
I did have a bus where I had to make sure the upper left bolt was through before I snugged the lower nuts.
It was only that one bus, but it was definately like that.
As you put that starter bolt in place, hug your transmission.
It needs love too.
Then give your sweetie a hug, cause you'll smell good, like gear oil. |
Posted: Wed Jun 05, 2013 11:24 am Post subject: |
Heh.
I found after snugging the lower nuts that the upper left bolt now won't line up with the threaded insert in the case, so I'll need to loosen them anyway. I'll put washers on them at that time, just because.
Somehow I misplaced that cap screw, too. M10 X 7cm...hope they have those at the hardware store. |
quartermilecamel Samba Member
Posted: Wed Jun 05, 2013 12:21 pm Post subject: |
I put rtv under the head of the D nut, and some on the nut shaft. When its broken loose next time, it didnt have the ease of sliding out when I tried to nut it. Really havnt put any on that bolt since. Theres still enough rtv to make it have a rubbery grip on its suroundings. _________________ Waiting for santa to drop off funky green. I can wish can't I???? |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Wed Jun 05, 2013 12:30 pm Post subject: |
yall are a lot smarter than one of the previous owners of my truck. I can't think why else they would have done this
