RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Sat Sep 03, 2016 7:16 am Post subject: Re: Hot Start Problem - What exactly is it? |
Not wanting to get off the original posters question but... GOOD to see you again on Samba mightyart. Ive learned a lot from your past postings. Safe travels to you and yours. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Sat Sep 03, 2016 9:31 am Post subject: Re: Hot Start Problem - What exactly is it? |
RCB wrote: |
Thanks RCB, my poor little Westy has been sitting for a couple years waiting for me to get a job that pays more then just enough to eat. Well I got a decent job now, and it's time to get her going. So I'm back and ready to share all my misadventures in getting her going again. One thing I do have going for me is that now I live in the land of Vanagons (Portland, Oregon) so parts and help are plentiful. |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Buick Truck guy Samba Member
Joined: September 02, 2016 Posts: 3 Location: Motor City
Posted: Mon Sep 05, 2016 2:31 pm Post subject: Re: Hot Start Problem - What exactly is it? |
Thanks to everyone for their suggestions. I am going to start with an ignition switch since it is the easiest and least expensive item and then work down the list that I will print off.
Regards, |
pablum Samba Member
Posted: Mon Sep 05, 2016 2:36 pm Post subject: Re: Hot Start Problem - What exactly is it? |
You can save on shipping if you buy all the parts at once. _________________ The wise man learns from history, the fool from experience.
I see [a cat] in the street and i aim for the pest with my car. -- bluebus86 |
Posted: Mon Sep 05, 2016 5:22 pm Post subject: Re: Hot Start Problem - What exactly is it? |
"You can save on shipping if you buy all the parts at once. "
I might just do that. Thanks for the suggestion. |
cyclecast Samba Member
Joined: January 23, 2017 Posts: 17 Location: Iowa City, IA
Posted: Thu Jan 30, 2020 11:54 am Post subject: Re: Hot Start Problem - What exactly is it? |
I finally found the problem on an 85 westy after replacing:
starter
solenoid wiring
ignition switch
battery
battery cables (including long ground with super thick one)
It would start when cold. Then after going somewhere and stopping (like store) wouldn't start back up. Had to wait about 20 minutes. Problem is result of design flaw. When the van is running, the starter gets cooled down with airflow and it might start back up right after shutting off. But after you are stopped for a bit, the starter is sitting right above the engine, and continues to heat up a bit ("heat soak"). While hot, it takes more current to start.
At the same time, the ignition switch runs the FULL current though it instead of using another relay. This wears it out. Those 2 things together cause this problem.
I got a $3 push button switch from O'reilley's that could handle the current. Drilled a hole in the dash. I left the "aux" wires for the key (so you still need the key) on the ignition switch. I routed the starter wires through the push button (instead of turning the key). STARTS EVERY FREAKING TIME. Like a champ. No problems for over a year. I meant to upload this info earlier but forgot.
Merian Samba Member
Posted: Thu Jan 30, 2020 1:43 pm Post subject: Re: Hot Start Problem - What exactly is it? |
yup - this needs to be done, in addition to any thing else like a new ignition switch etc. _________________ .... |
Posted: Tue Jul 19, 2022 3:09 am Post subject: Re: Hot Start Problem - What exactly is it? |
Upgraded the push button with one from billet auto. It has an LED to see at night, can handle the amps. Is more robust and explains it's function. Took a bit for it to arrive from Australia but it was well worth it.
https://billetautomotivebuttons.com/
Posted my schematic changes for this push button and the wiring before tucking it back up under the dash. Van always starts now, it's great.
This mod still requires the key to be in the on position, so it can't be started without the key. Just bypasses putting all the amps through the ignition switch to engage the starter solenoid.
