Vango Conversions Samba Member
Joined: October 04, 2010 Posts: 1054 Location: Seattle, WA
Posted: Wed Jun 05, 2013 1:38 pm Post subject: |
Pretty sure the Meyle HD ball joints are just marketing. Do they actually say "heavy duty" or just "HD"? They should be stock replacements although you'd have to check dimensions to be sure. It wouldn't machine the spindle oversize to accept larger than stock ball joints as you'd weaken the spindle, there isn't a ton of extra material there. Most ball joints last until the boot tears, then dirt gets in there and they fail quickly. Probably not much to be gained with oversize ones.
Meyle quality is hit and mis. There is no way to tell where the part is made as they just have stuf made where ever the labor costs are lowest. They stamp "Meyle Germany" on the parts made for german cars but I bought some brake parts for a jeep and it said "Meyle USA" and then on some sticker "made in china" some stuff lasts and some fails right away. |
jensjakob Samba Member
Joined: April 01, 2006 Posts: 94 Location: Denmark, Europe
Posted: Wed Jun 05, 2013 1:30 pm Post subject: |
The HD are made by Meyle.
I am researching in German forums, and some like the Myle HD - some says that they dont last. _________________ http://www.t3nettet.dk
Telebus: 1985 Vanagon, 1.9 DG engine, 4 gear
Ms Grey: 1983 Vanagon, Golf III 1995 1.8i 9hp engine - 5 gear |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Wed Jun 05, 2013 1:29 pm Post subject: |
If you were going to adapt the spindles for a larger ball joint, you'd probably have to have the larger ones in hand and a machinist would need to machine out the ID. It is an interference fit and is actually a little bigger than the hole. I don't think grinding is an option. The taper end would not be as big a deal. Post a link to the ball joints you have in mind. Christopher at T-3 Technique knows about as much as any member here about suspension. The other question would be is something causing them to prematurely fail? Did you fit grease fittings in the replacement ones? _________________ ☮️
Posted: Wed Jun 05, 2013 1:15 pm Post subject: |
Who makes the "heavy duty" version? Those things are such a pain to replace that any increase in durability would be great. seems like they're normally god until to boot tears though, so i'm not sure how much is really gained. |
Posted: Wed Jun 05, 2013 1:02 pm Post subject: |
Thanks. Press. Indeed. Did them last year. Broke one hydraulic press
But - do you have any idea of the diameter of the normal lower balljoint?
And how much grinding is needed to make room for the oversized HD version (48,5 mm diameter)?
Happy driVWing
Jens Jakob _________________ http://www.t3nettet.dk
Posted: Wed Jun 05, 2013 12:55 pm Post subject: |
You'll need a press. We used a torch and an air hammer to remove them. We removed the boot on the new one, made a tool and were able to press the new ones in. I don't think there is room for a conventional universal ball joint tool to get in there. We made a tool similar to the one in the Bentley manual from a peice of exhaust pipe. Pain in the butt. Normally I would never apply torch heat to a suspension peice, but that was the only way it was coming out. _________________ ☮️ |
Posted: Wed Jun 05, 2013 12:48 pm Post subject: Heavy Duty lower balljoints? |
Hi,
Can someone explain me what is needed to install heavy duty lower balljoints in a 1983 T25?
Is it just wear and tear - and maybe a little sanding here and there - or does a machineshop need to be involved and a large drill or even a lathe?
I can see that the HD lower balljoints are 48.5 mm diameter. But what are the norma lower balljoints in diameter?
Best regards
