Vw thing ignition switch removal
crsgrant
crsgrant is offline
PostPosted: Sat Jun 08, 2013 12:07 am    Post subject: Vw thing ignition switch removal Reply with quote
There is no screw hole anywhere on my ignition tree to remove the ignition switch on my 1973 thing. WTF how do I get it out? Just about ready to hammer the hell out of it! Please help:)
n0limdon
n0limdon is offline
PostPosted: Sat Jun 08, 2013 2:42 pm    Post subject: Reply with quote
I have a copy of a document Thomas M. Ainlay had on one of these VW Things sites. It is for a 74 Thing but I would imagine a 73 would be about the same. Does anyone recall Mr Ainlay? How to get ahold of him?
"Lili Marlene"
Cresco, Ia.
Semper_Dad
Semper_Dad is offline
PostPosted: Sat Jun 08, 2013 2:50 pm    Post subject: Reply with quote
See if this helps
Under ignition switch replacement (late model)
http://www.vw-resource.com/ignition_switch_replacement.html#ignition
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map:
http://bit.ly/1axDF1r
Gitm registared boys!
Officially, there are only 112 181s in the world
Bashr52
Bashr52 is offline
PostPosted: Sat Jun 08, 2013 6:14 pm    Post subject: Reply with quote
I just replaced mine today. Are you trying to replace the key part or the plastic part at the bottom where the harness plugs in?
vwwestyman
vwwestyman is offline
PostPosted: Sat Oct 28, 2017 8:55 pm    Post subject: Re: Vw thing ignition switch removal Reply with quote
I need to replace the plastic part in mine, the electrical portion.
I got the German switch from Bus Depot in today, so I'm hopeful that'll fix my problem.
The key currently doesn't spring back after starting. I always just did it myself, but the starter was ruined last weekend when I had someone else drive it.
New starter is in, and cranking faster than ever! (Also cleaned up connections while I was down there.) But I don't want the wonky switch to destroy another starter. (I could hear parts rattling around in there when it took the old one out!)
Dave Cook
Stuartzickefoose wrote:
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
www.thefosterdads.com
