Accelerator Problem spring / sleeve causing higher RPM
NCdad
NCdad is offline
PostPosted: Sat Jun 08, 2013 12:17 pm    Post subject: Accelerator Problem spring / sleeve causing higher RPM Reply with quote
INFO: 1964 Bug 40 hp 28 pict-1
Trying to figure this out:
My accelerator cable sleeve seems to ride on the carb throttle arm, causing it to stick and higher RPM's
I checked the Gallery to see if there was another pic of one, and found this one. I noticed that there is a cap on the end of the return sleeve.
I guess this is the part I need, but not quite sure how it hooks up or works in conjunction with the sleeve / spring?
Does the thick part of the cable wedge in that gap?
how does the sleeve not push the cap up the cable?
Here is the part:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113129909
ROBERT
My VWs & Projects - | - German Invasion VW Show - Sept 07, 2019 Shelby, NC
jhoefer
jhoefer is offline
PostPosted: Sat Jun 08, 2013 1:21 pm    Post subject: Reply with quote
The solid tip is swaged on the end of the cable. The slot in that cap is just large enough to fit around the cable, but not around the solid tip so the cap can't move past that point. The dish in the cap and the spring tension hold the cap in place.
But it also looks like your cable might be a bit too long; it looks like you're mounted almost at the bottom end of the cable end. I don't know if you'll gain enough of a gap between the sleeve and throttle arm even if you add that cap.
NCdad
NCdad is offline
PostPosted: Sat Jun 08, 2013 6:42 pm    Post subject: Reply with quote
Thanks!
the other photo above was from a '62 bug, so I know it is a shorter cable ( 89.3")
where the one I have is 104.3"
looking at the wolfsburg west one, it seems to be one of the longest for a bug.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111721555C
I looked at a '63 which was shorter, but my chassis number came after it.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111721335
ROBERT
jhoefer
jhoefer is offline
PostPosted: Sun Jun 09, 2013 12:18 pm    Post subject: Reply with quote
Well, if you don't want to change the cable, you could add a second barrel nut further down the cable to act as the stop for the sleeve. Just set it back far enough to avoid interference with the throttle linkage. http://www.pacificcustoms.com/129777311.html
Hardware store will probably have them as well.
wayne1230cars
wayne1230cars is offline
PostPosted: Sun Jun 09, 2013 1:55 pm    Post subject: Reply with quote
NCdad wrote:
Thanks!
The first link that you posted should be the accelerator cable that fits your beetle. The second link that you posted is for a clutch cable. The accelerator cable for the 66-71 bugs was about 23 mm shorter. Is your pedal cluster original?
I would order the spring seat retainer and see how the cable then adjusts. BTW those retainers are small and easily dropped and lost. Ordering a spare might not be a bad idea. Always a good idea to also have a spare accelerator cable once you are certain you have the correct length for your car.
1960 beetle
1970 beetle convertible
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Jun 09, 2013 4:45 pm    Post subject: Reply with quote
Also do you have the accelerator cable boden tube??
http://www.thesamba.com/vw/forum/viewtopic.php?t=400171&highlight=accelerator+boden+tube
That tube with correct length can slightly shorten the stock length cable.
In Stereo, Where Available!
NCdad
NCdad is offline
PostPosted: Sun Jun 09, 2013 6:13 pm    Post subject: Reply with quote
Nice, thanks!
I was thinking of modifying a washer for the sleeve to ride against for a temporary fix, as it will take a few days to get over here to the east coast.
Embarassed
yes, as far as I know, the pedals are the originals.
No I don't have a boden tube for the acc. cable.
thought they were used starting in '66
ROBERT
Eric&Barb
PostPosted: Sun Jun 09, 2013 6:22 pm    Post subject: Reply with quote
As in the link, AUG1960 was start of that part in our VWs.
