mxracer Samba Member
Posted: Tue Jun 11, 2013 10:21 am Post subject: The way extension tubes should be made.... |
Building an engine for a customer and he has a 1.5 qt sump but it didn't have an extension tube. He ordered one but it didn't fit.
So I figured I'd make one. My first instinct was to make a "heat" fit like the crank gears. Did that but didn't like the idea of having to heat it back up in the case it needed to come off for some reason without cleaning everything up first.
I had some time the last 2 evenings so I made a shaft collar type clamp for it. Now that I have made it and test fit it IMO this is the way they should be made. It is solid and easily installed/removed, which I like cause now I can break the cam in without the sump and then install it, saving him a couple quarts of break-in oil.
I know many people don't have issues with the hose clamp method. I just see this as an alternative and IMO a sturdier one.
tobiism Samba Member
Joined: January 21, 2004 Posts: 502 Location: Chandler AZ
Posted: Tue Jun 11, 2013 10:34 am Post subject: |
Nice work, that looks solid! _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
ralf Samba Member
Posted: Tue Jun 11, 2013 11:05 am Post subject: |
so how much?
trick work man! _________________ Flow Through a Curved Conduit
porting my SP head for my brother's project
https://youtu.be/OS_mVjQuqgk |
luckystiff Samba Member
Joined: September 28, 2005 Posts: 2252 Location: hickory,nc
Posted: Tue Jun 11, 2013 11:07 am Post subject: |
looks nice. reminds me of a nice quality bike seatpost clamp ...ken.... _________________ ITMC
Secret Service |
Posted: Tue Jun 11, 2013 11:08 am Post subject: |
oh and you gotta be one of the only people i know that would make a custom piece and be thinking of it saving a coupla quarts of break-in oil as a plus hahahhaa....... _________________ ITMC
Secret Service |
mark tucker Samba Member
Posted: Tue Jun 11, 2013 1:57 pm Post subject: |
I started to make some like that,but got side tracked & brazed it on.adding a "o" ring grove to each end of the collar was my plan,Ill probably do it for my next motor. a push lock type would also be nice. nbrazing is a pain in the ass but the way some of the tube are effed up nowdays makes it nessary.gladd I have some good tubes for my stuff. |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Wed Jun 12, 2013 6:19 am Post subject: |
Looks nice. How about the length? Is it going to 'bottom' out in a stock filter or the drain plate. Stock pick-up tubes where modified by the factory to have a angle cut on the end when they came out with the 1600. IMO, drill holes along the length to increase the suction 'area'. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Wed Jun 12, 2013 6:25 am Post subject: |
Length is "standard" for the 1.5 sump. I made it the same length and the one he purchased. I need to mock it up with the sump and screen in it but it should be right. If not I can chuck it back up in the lathe and trim it as needed. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Thu Jun 13, 2013 7:34 pm Post subject: |
I just TIG mine on. Nice machine work though! _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
ONEBADBUG Samba Member
Joined: January 27, 2004 Posts: 183 Location: SPOKANE, WA
Posted: Thu Jun 13, 2013 8:06 pm Post subject: |
You can buy those collars made in different diameters. Maybe not the right size for a pickup tube though. |
