zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Mon Jun 11, 2012 5:49 pm Post subject: |
Was there ever such a thing from the factory, or at least from the dealer? |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Mon Jun 11, 2012 6:21 pm Post subject: |
Absolutely! I have had both a Hirschmann and a Bosch. I think the rare ones are for the PS. Haven't seen one of those yet. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
islandveedub Samba Member
Joined: March 10, 2003 Posts: 157 Location: Honolulu, Hawaii
Posted: Mon Jun 11, 2012 7:08 pm Post subject: |
@fusium - pm sent _________________ Alex
60 Doublecab
62 23 Window Walkthrough Bus |
Posted: Sat Nov 24, 2012 2:06 pm Post subject: |
UPDATE: Could not update my original post, so:
I was helping a friend with his antenna and realized that his antenna hole was further away from the drip rail than both my buses. If you are following the instructions I posted earlier, it will become evident after you make the first bend if my measurements will work or not. Just take your time, and make adjustments as you go and things should go just fine.
Also, the first bend at 2 1/2" can be shortened to 2" for a little better clearance, although 2 1/2" will clear.
I found a much faster way to sand down the aluminum rod. Use a DA sander with 80 grit sandpaper for a few seconds on 4 "edges" of the rod, then a few seconds more on the edges created to round it back out and that will be sufficient. No need to take off a lot of material. It goes by really fast. Now the thing that takes the longest is carefully cutting the black plastic base piece. Need to figure out a way to speed that up too. _________________ Alex
60 Doublecab
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Sat Nov 24, 2012 5:14 pm Post subject: |
I did a standard antenna on my former 67 Deluxe with Safari windows. I put fuel line over the section I wanted to bend, and then use a pipe bender. It worked perfectly and I did not have to do such extreme bends.
_________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Mon Nov 26, 2012 11:14 pm Post subject: |
Very informative thread!!
Thank you very much for the step-by-step description, that is inspiring. _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
Dadnova Samba Member
Posted: Wed May 15, 2013 5:32 pm Post subject: Buying one already done |
I am new here, however I just had Safari windows installed on my 66 Bus.
I have been told there is a guy in Ca. that makes them and sells them.
714-516-9756 is their number |
tommeke Samba Member
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
cru62 Samba Member
Posted: Sat Jan 16, 2016 6:39 pm Post subject: Re: Bending a Safari Antenna...No Problem! |
I made this. But have not bent it yet as I am undecided which side to use it on-
matthew henricks Samba Member
Joined: January 02, 2002 Posts: 1219 Location: So. Cal
Posted: Mon Jan 18, 2016 8:51 am Post subject: Re: Bending a Safari Antenna...No Problem! |
Nice Tutorial. |
Millerz13 Samba Member
Joined: November 25, 2018 Posts: 42 Location: Sacramento
Posted: Sat Feb 10, 2024 10:16 pm Post subject: Re: Bending a Safari Antenna...No Problem! |
Anyone know where/how to get a bent antenna for safari windows that is dual mount vs the single mount ones that are currently sold? |
volksbus Samba Member
Joined: November 02, 2005 Posts: 151 Location: Chicago, Illinois U.S.A.
Posted: Mon Mar 04, 2024 1:26 pm Post subject: Re: Bending a Safari Antenna...No Problem! |
I have an OG one if someone is looking for one. _________________ "Get in the bus!"
1967 SO-42 "Klaus"
1964 DC Truck
1967 Dodge A-108 CampWagon |
onemorodeo Samba Member
Posted: Tue Mar 12, 2024 6:55 pm Post subject: Re: Bending a Safari Antenna...No Problem! |
I have a 66 SO42 that I installed safari’s on and apparently the holes are in a different location so that the aftermarket safari antennas won’t work. I’d there anyone that custom makes these? Thanks. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14270 Location: Casa de Oro, California
Posted: Wed Mar 13, 2024 6:16 pm Post subject: Re: Bending a Safari Antenna...No Problem! |
onemorodeo wrote: |
volksbus wrote: |
I have an OG one if someone is looking for one. |
If he still has it maybe ask him for measurements and buy his. |
Posted: Thu Mar 14, 2024 9:27 pm Post subject: Re: Bending a Safari Antenna...No Problem! |
Pics of the antennae that came on my June 9, 1967 SO-42. I cannot explain why!
https://photos.app.goo.gl/Wgkw8BJdueK9DvRCA _________________ "Get in the bus!"
1967 SO-42 "Klaus"
1964 DC Truck
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Fri Mar 15, 2024 8:25 am Post subject: Re: Bending a Safari Antenna...No Problem! |
You guys are doing it all wrong.
_________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
kintail Samba Member
Posted: Thu Mar 21, 2024 3:37 pm Post subject: Re: Bending a Safari Antenna...No Problem! |
Decided to go roof mount and avoid the bends....
_________________ Scott |
