DeVertible Samba Member
Joined: May 23, 2013 Posts: 85 Location: Sequim, Washington
Posted: Wed Jun 12, 2013 8:19 am Post subject: Installing 1967 12 volt 1500 in a 1965 bug |
Can anyone list the issues and changes that go along with instaling a 12 volt 1500cc engine in a 1965 bug? Some things are obvious but these swaps alway end up having a few hidden surprises that make the change more than just interesting. I read somewhere the 1967 engine compartment was larger than the earlier editions so fit and tin is one concern, along with the electrical conversion. Any thought and help from experience would be appreciated. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26524 Location: Douglas, WY
Posted: Wed Jun 12, 2013 9:28 am Post subject: More questions regarding 67 Engine swap |
Thanks for your knowledge. The engine I am considering is complete with tin and all externals (including flywheel) except for exhaust. I am really not interested in altering my trans unless that is the only option. Is retaining the 6 volt system a viable option on a 1500cc motor or is that just stupid? Glad to hear the engine fit should be fine. |
risk Samba Member
Joined: June 24, 2004 Posts: 724 Location: Stumpbroke, Arkansas
Posted: Wed Jun 12, 2013 10:08 am Post subject: Re: More questions regarding 67 Engine swap |
DeVertible wrote: |
Is retaining the 6 volt system a viable option on a 1500cc motor or is that just stupid? |
The 6 volt flywheel won't fit on the 1500 crank... at least it wouldn't work on my friends 64. We just did the swap on his car, no big deal to modify the trans as Glut suggested. You can only see the mods inside the trans, not visible from the outside. |
Posted: Wed Jun 12, 2013 10:26 am Post subject: |
Back when I was working on VWs, we sold ATK/Vege remanufactured engines that came with the late O-ring style flywheel. Their installation book said you could use a 6V flywheel on their engines - I wish I had one of those booklets around actually, I'd scan and post it. I think it said to use the metal sealing washer between crank and flywheel and reset the endplay. ATK had a pretty good 1-year/12K warranty and I don't think they'd have allowed this kind of thing if it wasn't OK. I have to add though, that we never actually had to do it.
Now, putting an O-ring flywheel onto the early "step" crankshaft, now that is a no-no!
Actually, the last few months of 1966 production used an 109-tooth, 180mm-clutch flywheel with the O-ring crankshaft/flywheel... but those aren't exactly easy to come by. |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Wed Jun 12, 2013 11:29 am Post subject: |
Takes less than an hour to make the larger flywheel fit into your early transmission. Here's what my '63 trans looked like - the shiny spots are all that need the touching up, not the entire transmission.
Install the engine and flywheel until it touches. Remove all spark plugs from the engine and turn it with a wrench/ratchet until it leaves score marks. Back the engine out and remove the material. It may take a cooupla' times to get the flywheel to spin without hitting the transaxle. I used a flap wheel on a 4" grinder and a Dremel with a small spiral cutter to get rid of very little material.
