1961bluebug Samba Member
Joined: November 11, 2002 Posts: 1137 Location: Czech Republic, Europe
Posted: Wed Jun 12, 2013 7:32 am Post subject: Please help me design a gearbox to match my 2276 engine |
Finally due to money and time issues I purchased and ran Pro Street transmission in stock trim with 4.12 RP and ran it for two seasons. It runs very good in town and countryside driving I´m under impression it kills my 1/4 mile times a lot.
What gear ratios would you suggest for my 2276 with 86C cam, 11:1 CR , 48DRLAs, 1 3/4 CPS python. I run a full metal VW Thing on swingaxles, good rubber mounts, CSP trapese system, no problem with wheel hop whatsoever. Berg shifter, new shifter bar bushing, Dieken Copper disc and Stage 1 KEP plate. The car still weight around 2000 lbs with me.
I´m ready to run ERCOs with 215/65 m+H DOTs on the rear for the races, otherwise I´m driving on 205/65 Pirellis.
My gearing is:
4.12 RP,
1st Gear: 3,78
2nd Gear: 2,06
3rd Gear: 1,26
4th Gear: 0,89
I´m prepared to run close ratios if it still allows me to get to races at reasonable speed (no autobahns). Please design me a gerabox of your opinion. _________________
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold) |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Wed Jun 12, 2013 8:14 am Post subject: |
A 1.04 4th wont be too bad to drive on the highway and still have some ratio umph. Call up Rancho and see what they say. How does your temp run atm with your current trans set up? THing going to take probably an extra fan cooler. A thing isnt exactly an aerodynamic deal also. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Wed Jun 12, 2013 9:32 am Post subject: |
Shorter gears are great for acceleration, but will affect highway speeds. You'll have to decide if it it's something you can live with. In my youth I at one point went to a gearbox with 4.37 r&p, 1.48 3rd and 1.12 4th gears (from a 4.125 r&p and stock gears) in my transportation. With the close ratios and shorter r&p, 3500 in 4th was about 52mph and it took forever to get places (but the car ran mid 14's at 88mph with a 1750). With the 4.125 r&p and stock gears 3500 happened at about 70mph and was probably 3/4 second slower in the 1/4 mile.
3500 x 1.04- 60mph
3500 x 1.12- 55mph
These figures all use a 24 1/2" rear tire. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Jun 12, 2013 2:41 pm Post subject: |
You can build a close ratio racing gearbox or a stock ratio street gearbox. Anything else will be a compromise between fast 1/4 mile ET's and happy highway driving. The only way you can have both is with a 5 speed. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu Jun 13, 2013 12:19 am Post subject: |
Thanks so far. I have other aircooled VWs for highway driving. So what would be your choice for real close ratio 4 speed?
Thanks,
J. _________________
|82x94|
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Thu Jun 13, 2013 4:34 am Post subject: |
Keep the 4:12 R&P and 1-2 gears and install 1:48 3rd & 1:12 4th and weld the hubs to the gears ,get a Super diff too _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
ALB Samba Member
Posted: Thu Jun 13, 2013 6:50 am Post subject: |
For a car that sees a lot of street time and only is on the track occasionally, Madmike's suggestion X2. 7000 rpm in top gear will be about 110 mph (again, assuming a 24 1/2" tire) and would be a good place to start.
For a 1/4 mile only transaxle a 3.88 ring & pinion is stronger, but for the best results custom 1st and 2nd gears will be needed as well, so it could get expensive. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
ALB Samba Member
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Thu Jun 13, 2013 7:48 pm Post subject: gears |
My 2332 cc, Web 86C, 1.75" header, IDA's, M&H 215's, etc, I first tried a Rancho 4.125 with 3.78/2.26/1.48/1.04 running low 13's in the 1/4-mile. However, it died noticeably on the 1/4-mile when shifting from 3rd to 4th.
Sold that transaxle and next I went with a 3.875 Rancho with 3.78/2.35/1.65/1.31 and all of a sudden I was down in the 12's. Of course, this limits the freeway speeds, as the rpms at 100 KM/H are getting up there _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
ALB Samba Member
Posted: Thu Jun 13, 2013 9:22 pm Post subject: Re: gears |
neil68 wrote: |
Sold that transaxle and next I went with a 3.875 Rancho with 3.78/2.35/1.65/1.31 and all of a sudden I was down in the 12's. Of course, this limits the freeway speeds, as the rpms at 100 KM/H are getting up there |
Neil- What rpms are you going through the lights at? _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
Chip Samba Member
Posted: Thu Jun 13, 2013 11:48 pm Post subject: |
vwracerdave wrote: |
You can build a close ratio racing gearbox or a stock ratio street gearbox. Anything else will be a compromise between fast 1/4 mile ET's and happy highway driving. The only way you can have both is with a 5 speed. |
Or a turbo
That said, I have a 3.88 with a 1.04 4th and a 215x65x15, and it cruises along on the freeway decently. A little better than my stock 4.37 gearbox with 195x60x15s. I do have the power to pull the gear on the track though, so it was worth going that route to me.
I also had a 3.88 with 1.12 4th that wasn't super fun on the freeway, but acceptable for a high strung street car.
I am a turbo guy through and through, my trannies are geared to get me through the traps between 6000-7000rpm. I don't need the RPM to make power. If you want RPM Neils setup may be the way to go. I definitely prefer the 3.88 setup over the 4.12. Especially since you NA guys launch with a lot of RPM as a general rule. If you go 3.88 you are going to need to do all 4 gears though, which can be big $$$. Good luck, it sounds like you have a fun ride! |
Posted: Wed Sep 25, 2013 7:00 am Post subject: |
Rviving my old thread. i modeled two graphs here:
http://www.teammfactory.com/gearcalculator.php?kmh...on+1+%26+2
First transmission is my actual transmission, second one is close ratio which I want to make out of my Pro Street. Would it work good for my application?
I´m still wondering if 1.125 or 1.21 4th would be better... I´m somehow copying neil68´s setup and want to get rid of the 3rd to 4th shift drop he mentioned above.. I also believe that my engine is similar to the engine he used...
Thanks. _________________
|82x94|
modok Samba Member
Posted: Wed Sep 25, 2013 4:38 pm Post subject: |
He said he had a 1.04 fourth, and yeah that is too big a drop from the 1.48 third.
the fourth 1.48/1.125 should be perfect IMO if you don't change the mainshaft, if you space them any closer it won't feel like you even shifted
if you DO spring for a mainshaft, then maybe 3.78/2.26/1.58/1.21 |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Sep 25, 2013 4:48 pm Post subject: |
I'd advise against a swing axle super diff for street use. I've had better long term service using 15 tooth Euro side gears with dual circlips. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
neil68 Samba Member
Posted: Wed Sep 25, 2013 9:49 pm Post subject: gearing |
Following up on your PM.
The 4.125 with 1.21 4th is somewhat similar to my 3.875 with 1.31 4th, so great for racing...but, a bit high strung for higher speed road traffic (freeway/autobahn). I stay on roads that are 80-90 km/h only, as at 100 km/h the drivetrain is screaming a bit too much for me
The 1.12 4th might be a better choice, as others have suggested... _________________ Neil.
AlteWagen Troll
Posted: Wed Sep 25, 2013 11:47 pm Post subject: |
gears wrote: |
I'd advise against a swing axle super diff for street use. I've had better long term service using 15 tooth Euro side gears with dual circlips. |
I have an old "1/4 mile" trans from back in the 80s that i am going to go through with:
4.37
3.80
2.06
1.48
1.12
It has a threaded super diff with SAW short axles. Since you advise against a super diff for the street is it the same for the threaded diff? |
gears Samba Member
Posted: Thu Sep 26, 2013 1:01 am Post subject: |
They all have oiling problems, and show excessive wear eventually. The stock diffs are wide open, and oil properly over the long haul.
Other options are LSD or TBD (although these are expensive). _________________ aka Pablo, Geary
'87 Syncro GL 2.5
Posted: Wed May 30, 2018 7:00 am Post subject: Re: Please help me design a gearbox to match my 2276 engine |
So here I am 6 years later and my car hasn´t changed yet. Ïn fact it stood in a storage for last 4 years. With early bay coming home as a 2 yr restoration project, and another 1961 bug that kept me busy.
But now I pulled the trigger and the transmission is being built. It will be Berg 5,
3.875:1 RP
3.75/2.25/1.65/1.31/0.89 gear stack.
Looking forward! _________________
|82x94|
King_vw61 Samba Member
Joined: February 03, 2018 Posts: 1383 Location: Southern California
Posted: Wed May 30, 2018 4:02 pm Post subject: |
gears wrote: |
Other options are LSD or TBD (although these are expensive). |
Soooo true 1400 just for the diff... |
gears Samba Member
Posted: Wed May 30, 2018 4:41 pm Post subject: Re: Please help me design a gearbox to match my 2276 engine |
For swingaxle you'd step up to one of these:
Then again, the IRS super diffs don't suffer from the same oiling issues as the swingaxle SDs. _________________ aka Pablo, Geary
'87 Syncro GL 2.5
