ShootingFish Samba Member
Joined: July 25, 2010 Posts: 330 Location: Portland, OR
Posted: Fri Jun 14, 2013 5:26 pm Post subject: Diesel Guru Question |
Here is the deal...
My Doka has an AFN TDI in it... Euro-spec I know...
I am wondering if one might be able to use a USA spec wiring harness and ECU with the unit along with some of the other electrical bits to make the turbo work correctly.
It would be really nice to have the OBD-II diagnostic ports and the like for troubleshooting.
I realize that the AFN is 108 hp and the US Spec engines are less, but can be modded and chipped to put out similar HP and TQ. My thought is that the injectors and fuel pump are already upgraded, that this could be a workable solution?
Thoughts?
Thanks! _________________ SF
Props aren't just for boats....
'88 2WD ALH-TDI Westy
'90 Syncro 16 Doka |
