Canoli Samba Member
Joined: September 01, 2014 Posts: 47 Location: Rockford Il
Posted: Wed Nov 09, 2016 4:47 pm Post subject: Trying to figure out what the PO did |
I'm trying to figure out what the PO did with the wiring. In the ICU picture someone spliced the wire that goes to the ign coil( that's what the bentley says. They spliced it from number 5 which goes to the fuel pump relay. In the fuel pump reply pic they pigtailed the blk/wht wire , one to the relay the other to the ign coil. If i disconnect the wire from the ign coli the van doesn't start(no fuel pump). I've cut the one at the ICU and seems like nothing happened. Also I'm only getting 8 volts at cold start at the ICV, when she warms up it goes up to 10. Sorry if this doesn't make any sense, did the best I could explaining it.
Any help would be grateful.
dyldebus Samba Member
Posted: Wed Nov 09, 2016 5:28 pm Post subject: Re: Trying to figure out what the PO did |
It looks like they tried installing a kill switch. Do you have any toggle switches hidden on the back wall behind the drivers seat or under the dash? |
Canoli Samba Member
Posted: Wed Nov 09, 2016 5:46 pm Post subject: Re: Trying to figure out what the PO did |
I haven't seen any. I had the dash off and never saw one. |
bluebus86 Banned
Posted: Thu Nov 10, 2016 9:17 am Post subject: Re: Trying to figure out what the PO did |
what model van is it?
On my 1986 van I added a coil relay to give coil full voltage verses the dropped voltage from the ignition switch, put the realy in the engine bay relay box, also added a dedicated relay for the ecu. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Terry Kay Banned
Posted: Thu Nov 10, 2016 9:52 am Post subject: Re: Trying to figure out what the PO did |
The problem is that nobody here could possibly tell you what the hack had on his mind when he started adding his shade tree updates.
Look in the Bentley, find that specific connector, and see what it does or where it goes.
Undo what the hack artist did for you, rewire that connector.
The joys of buying somebody's bad idea's. _________________ T.K. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 9415 Location: Sunshine Coast B.C.
Posted: Thu Nov 10, 2016 10:00 am Post subject: Re: Trying to figure out what the PO did |
I'm not sure what you mean. Do you mean the PO connected (piggy backed) a wire from the ICU connector to the fuel pump relay?
Can you draw a diagram of what you're seeing?
Neil. _________________ 1981 Westy air cooled to 15º ABA swap: http://tinyurl.com/y9n4xob8
50º ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN |
Canoli Samba Member
Posted: Thu Nov 10, 2016 3:53 pm Post subject: Re: Trying to figure out what the PO did |
Sorry, I always for get the year its a 86 gl, 2.1. Fuel pump replay should be 2 not 1. Hope this helps
Posted: Thu Nov 10, 2016 7:49 pm Post subject: Re: Trying to figure out what the PO did |
Well I'm stuck in a ferry lineup in my westy so I have time to peruse my Bentley.
Your VIN could figure into this; there's two different 1986 diagrams. You note a green wire from ICU 17 so my guess is you're dealing with an early 86 wiring,
In the early diagram, the ecu relay is incorrectly labeled as fuel pump relay.
Sorry if this had been said already but....
I don't know enough about DC circuits to say for sure but I agree with [edit: dyldebus]. It's an ignition disabled? The wire between ICU plug wires 17 and 5 is intended to short out the ecu relay if someone cranks engine creating a signal from the coil?? But then I thought the 1 buss was negative?
If the PO took a positive feed from 15 of ignition coil, maybe they were trying to establish a better path of positive to ecu relay? Or, maybe there's a switch somewhere that controls that positive path? (Kill switch) _________________ 1981 Westy air cooled to 15º ABA swap: http://tinyurl.com/y9n4xob8
VE7TBN |
