Bus stroker motor advice based on parts accumulated: 94x?
travelvw
travelvw is offline
PostPosted: Sat Jun 15, 2013 3:11 pm    Post subject: Bus stroker motor advice based on parts accumulated: 94x? Reply with quote
I'm building my first stroker motor based around parts I've already accumulated for an all around bus motor: power as needed, "economy", longevity, reliability, and ease of assembly. All parts are new. This is not a bug drag race motor. I will be driving in everything from harsh off-road conditions to long road trips; winter thru summer, with a heavy load. The transmission is super beefed, so no worries there (4th gear@65=3370rpm). I prefer to limit expense based on what I already have, but I also don't want to necessarily limit the build because of it.
*DRD 40x35.5 dual spring heads cut 94mm
*CB solid shaft rockers w/swivel, stock ratio
*AA 94mm cylinders
*aluminum case NOT clearanced, cut 94mm, full flow
*aluminum case NOT clearanced OR cut, full flow
*CB forged flywheel 8 pin and 4340 nut (Kennedy stage 1?)
*high flow j-tubes (I'm not running boxes)
*I do happen to have a set of 4340 forged 5.4" I-Beam rods with ARP Bolts, and a Scat C35 cam, lightweight lifters... probably irrelevant for this build and my experience with Scat stuff is its a marginal step up from Empi junk.
I would like to run cheap gas (87) and mild compression (8:1-ish). I have no crank, cam, rods or carb size chosen as of yet. If AA made thick-wall 92 B's, I'd be all over that! I will be running a single CB Weber IDF center mount for simplicity and reliability. I will not be convinced on dual carbs; I've tried it both ways, so I'm not interested in that argument Wink . I could use the advice elsewhere in the build.
I've personally never been happy with Engle cams (100 or 110) on smaller engines. I have been most happy with the CB Eagle 2280 (valve lift 391, duration @ 0.50": 224) on a 1776 with 044 heads and a single weber 40. I know very little about cams, but I do know they can make or break an engine. I certainly don't want any lump-lump idle (this might be an issue with too much cam and not enough engine?). I'm looking for a low to mid range power band.
As for cooling, I am considering a Raby type 1 DTM, but will probably go with a thing shroud and type 4 cooler. Thanks in advance,
K
luckystiff
luckystiff is offline
PostPosted: Sat Jun 15, 2013 4:01 pm    Post subject: Reply with quote
AA DOES make thickwall 92Bs. i have them in my 2021 in my squareback....
ITMC
Secret Service
travelvw
travelvw is offline
PostPosted: Sat Jun 15, 2013 4:04 pm    Post subject: Reply with quote
Didn't realize this was made... I can only find thick-wall and regular A&B's. Seems to me the ideal bus big p&c. I would be more than happy to purchase a set and skip on the 94's, so long as they fit the DRD heads cut to 94mm... what is the cut on these case vs. head?
K
modok
modok is offline
PostPosted: Sat Jun 15, 2013 4:09 pm    Post subject: Reply with quote
since you will use a single carb, stay below 240degrees duration at .050 lift.
the 2280 is ok but with a stroker you will want a bit more cam so it isn't all kneckjerk at low rpms and weak past 3500 rpm.
yeah, AA has 92 B pistons, they are slipper skirt
most will say 1 3/8 exhaust is too small, I say it is too small if your using a stock arrangement header. So 1 3/8 j-tubes just isn't gonna be optimal either way
mark tucker
mark tucker is offline
PostPosted: Sat Jun 15, 2013 4:27 pm    Post subject: Reply with quote
thick wall 92's and 82 stroke,.040" deck(piston to head clearance) low lift cam around [email protected] & 1.25 ~1.33 ratio rockers. add the extra oil galy&slot the lifter bores.deburr the lobe edges.
travelvw
travelvw is offline
PostPosted: Sat Jun 15, 2013 4:36 pm    Post subject: Reply with quote
I don't plan on needing much power past 3500 rpm... probably won't even rev past 4k.
The j's I have look to measure about 1 3/8". Haven't chose the header/muffler yet. Sounds like I'm going to have to move up in size Confused . I don't need anything fancy, as I'll have to customize for clearance and will probably beat it on rocks anyhow.
It looks like 82mm is the "easy" B piston builld... I originally thought it was 78mm.
92mm thick B's are preferred if it fits my heads. I'm guessing they are 90.5mm case, 94mm head?
Thanks for the cam duration advice. Why ratio rockers? I thought they directly relate to the cam and lift and were a "patch" instead of changing out the cam?
K
[email protected]
john@aircooled.net is offline
PostPosted: Sat Jun 15, 2013 5:33 pm    Post subject: Reply with quote
http://vwparts.aircooled.net/Piston-Cylinder-Set-92mm-x-82mm-Machine-In-p/vw9200t1s.htm
are 94mm head, and 90.5/92mm case
while
http://vwparts.aircooled.net/Piston-Cylinder-Set-92mm-x-82mm-Machine-In-p/vw9200t1ms.htm
fit a 94mm Case and head machining bore.
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
mark tucker
PostPosted: Sat Jun 15, 2013 11:03 pm    Post subject: Reply with quote
I built a motor for a guys SC ,it tends to see some rpm. as does his bus. do not cut your self off at the knees, it's not any cheeper but it can be disastorious.remember your foot governs the motor.use what you need when you need it. if you need it and dont have it,better hope that big truck has real good brakes&a light load, cause he's fixen to squash the crap out of you.......or pull away from him like he is in reverse.the choice is yours. build it right & it will last.
travelvw
travelvw is offline
PostPosted: Sun Jun 16, 2013 5:51 am    Post subject: Reply with quote
Thank you John, I will grab a set of thick 92 B's from you (94x94 cut), and an 82 stroke crank: 2180 it is! Perfect. I'm guessing this takes stock length rods 5.4" for a mild compression motor?...will the 4340 Scat I-beam set I have be a good choice? Does 8:1 compression sound about right to everyone for running cheap gas? My last few engine builds have been 7.8- 8.2:1, and they ran fine on 87. That said, the engine size was much smaller. I don't want to be creating excessive heat.
Any more info on cam choice... particularly valve lift?... what numbers qualify as "low lift", and how does that effect things?
Mark, unlike most folks, I don't need the power band up high. I want it to kick in right away and fade out by 4k or so. I do very limited interstate driving, especially in traffic. Again, not looking to limit myself, but put the power band in the right place for me: very low range to mid-high at most.
K
luckystiff
PostPosted: Sun Jun 16, 2013 8:02 am    Post subject: Reply with quote
like the guy in the other thread about cam choice don't limit that stroker based on gas thats $0.20 cheaper per gallon. as i said in that thread you're talking $2-3 more per fill up for the ability to bump that cr in the 9:1+ range and use that engine like it can be. i know theres plenty of folks that have and do build low cr strokers. to each their own. theres also guy that build small HIGH compression engines putting out buttloads of power.
the scat c35 is pretty similar is specs to a engle 110. if the objective is to use as much of what you have it may fit into that low cr build range you are talking.
is the case stroker clearanced? if not you'll probably either want to send it to someone to be done so or i've heard several say that 82mm with buick journals and a nice set of H beams puts you in the by hand at home clearance range. cheaper to send the case out for stroker clearancing though...ken....
ITMC
Secret Service
[email protected]
PostPosted: Sun Jun 16, 2013 8:24 am    Post subject: Reply with quote
SCAT rods are outstanding, all the "no-name" rods try to achieve SCAT's level of quality, and rarely do. They are an excellent choice, for another $20 over the generic versions.
5.4" is the proper length for an 82mm crank and B pistons. You will NOT have a loss of low end with a "big" cam because of the stroke increase. One counters the other.
I'd go with dual 2bbls and an Engle 120, and 9:1 CR. Will run very well.
travelvw
travelvw is offline
PostPosted: Sun Jun 16, 2013 8:59 am    Post subject: Reply with quote
Ok, sounds like I've already got my rods. Great!
That's kinda what I was thinking about cam choice: what appears "bad" on a small engine, may work great on a larger engine... something I am not familiar with. That said, a 120 looks to be a little on the mid-to high, even in a big engine... also not really what I'm looking for. Might work better with dual carbs, but I'm running a single Weber IDF... so, what size? 44, 48? I am not running duals, even if everyone else in the world would Smile.
C35 was a typo... I actually have the C45, which is not at all where I want to be on this build.
I will consider upping the CR. Curious as to what a typical ratio is with 82 and B's on a new case, no flycut?
I will likely have the case clearanced locally for an 82mm crank. Thanks,
K
[email protected]
PostPosted: Sun Jun 16, 2013 9:09 am    Post subject: Reply with quote
With a single IDF do not go bigger than 286 adv duration, which is the Engle W110, or SCAT C35. You need a venturi in the 32-34mm range. The 40 IDF comes with a 28, and the 44 comes with a 36. So in either case you need to make a carb change to optimize everything.
travelvw
travelvw is offline
PostPosted: Sun Jun 16, 2013 10:39 am    Post subject: Reply with quote
Thanks again, great info. I will probably go with a single 44 and drop the venturi.
These are the specs on the cam I was most happy with:
Adv. Duration 274°
Dur. @ .050" 222°
Lift @ cam .359"
Lift w/1.1:1 Rocker Arms .394"
K
luckystiff
PostPosted: Sun Jun 16, 2013 1:01 pm    Post subject: Reply with quote
i deff don't want to make this seem argumentative but have you seen the Revmaster I Beams? my buddy was building a 1955 for another friend alongside building my 2021. i used revmasters he used scats and everybody that saw them liked the revmasters more and the scats needed a bit of work when it came balancing time and the revmasters were dead on out of the box. maybe i got lucky or maybe his were and unusual set for scats but i'd have to say for the price i put the revmasters right there with them. if you haven't seen them they are surely worth checking out...ken....
ITMC
Secret Service
jfats808
jfats808 is offline
PostPosted: Sun Jun 16, 2013 1:26 pm    Post subject: Reply with quote
i deff don't want to make this seem argumentative but have you seen the Revmaster I Beams? my buddy was building a 1955 for another friend alongside building my 2021. i used revmasters he used scats and everybody that saw them liked the revmastersrods more and the scats needed a bit of work when it came balancing time and the revmasters were dead on out of the box. maybe i got lucky or maybe his were and unusual set for scats but i'd have to say for the price i put the revmasters right there with them. if you haven't seen them they are surely worth checking out...ken....
Ive take a look at those rods for a build before but the major limitation is they only list a 5.5 vw journal rod. To complement a wider range of combos, it would be nice if they offered 5.4 /5.5 vw and chevy journal versions. For the price and 4340 quality 125.00 shipped is a decent price.
2276 IDA's 86C 11-1 DD
Rockstar Suzuki wrote:
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick
You can always learn something new, even from a fool.
Check your oil levels routinely!
luckystiff
PostPosted: Sun Jun 16, 2013 8:05 pm    Post subject: Reply with quote
they do also offer chevy/buick journal'd but i think only in maybe 5.5, 5.6 or something like that. so yeah all longer choices.
oddly enough i ended up digging those up because CB was out of the unitechs when i was ordering parts. after dealing with them i wish i would have known that before i bought my crank from CB as i probably would have ordered my crank from them also. great folks to deal with, nice products for a reasonable price, and fast shipping. i ordered my rods on a friday and they were here the following monday....ken....
ITMC
Secret Service
sactojesse
sactojesse is offline
PostPosted: Sun Jun 16, 2013 9:18 pm    Post subject: Re: Bus stroker motor advice based on parts accumulated: 94x Reply with quote
Listen to the experts. I'm no expert, but your Luddite approach, i.e., irrational fear of dual carbs, is compromising your build. If you want all-around driveability, your best bet is with dual IDFs or DRLAs. You will bet better mpg as well.
1966 Karmann-Ghia convertible
travelvw
travelvw is offline
PostPosted: Mon Jun 17, 2013 7:31 am    Post subject: Re: Bus stroker motor advice based on parts accumulated: 94x Reply with quote
This is my build, not theirs. Laughing I am not normal, so don't worry about me Wink. Interesting you know all about my fear of duals; I've run them more often than not, for many, many miles.
This will not be a street/strip racer. We will eventually be driving this rig to Alaska and back, often to the middle of nowhere out West, with lots of camping and offroading on a regular basis.
A single carb is somewhat restrictive, yes. It moves the power band lower, duals move it up. One carb means no linkage, half the potential for clogged jets and such, less than half the parts, and a super sweet sheathed cable setup, so no clogged or frozen accelerator cables. Driving rough trails for long periods of time, I have had zero flooding issues with a single center mount... just a clogged idle jet once after months of desert dust conditions. Its the only carb setup in 20k miles I've basically never had to screw with from sea level to 10k feet, cold, hot, doesn't matter: absolute reliability. This is of the utmost importance to me, not power. The following setup is more than enough:
2180cc
*Fan shroud TBD (DTM/Thing)
*Single Weber 44 (32-34 venturi etc)
*CR TBD (8-9:1)
*CB solid shaft rockers stock ratio
*AA 92mm super thick walls
*4340 5.4" VW rods
*Aluminum case, cut 94mm, full flow
*4340 82mm crank
*Cam TBD (-286 adv, -250@50)
*CB forged flywheel, Kennedy stage 1
Appreciate all the good advice from everyone.
K
stingah2
stingah2 is offline
PostPosted: Mon Jun 17, 2013 10:17 am    Post subject: Reply with quote
Kevin, if there's one thing about you it's that you are not normal. Normal is boring. I have run duals on everything for 20 years but for what you do I really can see and appreciate that a single is a great choice. I personally like your abnormal build Laughing
62 Singlecab - I kinda like it
76 wanna be Porsche
Rust never sleeps, Stainless never rusts.
