BusBerd Samba Member
Joined: November 19, 2005 Posts: 834 Location: Minneapolis, MN
Posted: Wed Jun 19, 2013 12:21 am Post subject: no third or fourth gear |
I just put my engine back in after doing some work to the shift linkage too. But now it will not go into either 3rd or 4th gear. I can't find them. while driving I reach over to put it into 3rd and there is nothing there but 1st and 2nd. where is the most likely culprit in the shifting linkage?
Among other things in the linkage, I replaced the coupling. could I have installed it incorrectly?? It seemed fairly simple.
It feels like there is not enough clearance to push the stick over to find 3rd or 4th gear.
(my apologies if I am not explaining this too succinctly. It is late-night but I wanted to get this question in before I hit the hay.)
Thanks!!! _________________ "The large print giveth and the small print taketh away."
1977 Westfalia Camper Bus 2.0L Fuel Injected Engine, Manual Transmission |
nodrenim Samba Member
Joined: October 06, 2006 Posts: 843 Location: Dobson, North Carolina
Posted: Wed Jun 19, 2013 4:54 am Post subject: |
Did you remember to tighten the grunge pin and safety wire it? Did you have the shifter out? It may need to be re-adjusted, if you had it out or loose. Just my 2 pennies. Good Luck! |
Posted: Wed Jun 19, 2013 9:21 am Post subject: |
I had installed the stop plate incorrectly. _________________ "The large print giveth and the small print taketh away."
1967250s Samba Member
Posted: Fri Jun 21, 2013 7:44 pm Post subject: |
Razzz, LOL. Just kidding, amazing how simple things are to fix. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51121 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jun 21, 2013 8:04 pm Post subject: |
BusBerd wrote: |
I had installed the stop plate incorrectly. |
Bet you'll never ever do that again, mistakes are valuable lessons and even better when nobody gets hurt and nothing is damaged but an ego, you're not the first to do that. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jun 21, 2013 8:24 pm Post subject: |
I'm quite happy and elated it was just a stupid mistake. _________________ "The large print giveth and the small print taketh away."
