modok Samba Member
Posted: Thu Feb 08, 2018 12:56 am Post subject: Re: Billet heads at near future: what is stock headstudspacing? |
2618 seems reasonable, and easier to work with.
"Creep" is more of a factor in the long haul, slightly different from pure strength values. TIME is a factor in creep.
It IS strange that many high dollar heads seem like they are made of the "wrong" alloy, but I think most billet heads do not actually run for many hours or many heat cycles. |
-Alex77- Samba Member
Joined: December 09, 2008 Posts: 513 Location: Finland
modok Samba Member
Posted: Thu Feb 08, 2018 4:05 am Post subject: Re: Billet heads |
"2618 aluminum alloy, as commonly used for F1 & GT race pistons which has the highest possible material strength at elevated temperatures"
highest possible, no, there is always something better.
I'd like some BRONZE cylinder heads |
Posted: Thu Feb 08, 2018 5:25 am Post subject: Re: Billet heads |
I asked today price for 280x180x140 blocks from 2219 T6 and 2618 T6 materials, lets see how much the material costs.. _________________ Lasercut parts and CAD design |
Posted: Fri Feb 09, 2018 1:37 am Post subject: Re: Billet heads |
So far got some material prices per one head:
2219 T6 around $450
6082 T651 around $195€ _________________ Lasercut parts and CAD design |
Tobias Bylund Samba Member
Joined: December 10, 2007 Posts: 202 Location: Varberg - Sweden
Posted: Fri Feb 09, 2018 4:59 am Post subject: Re: Billet heads |
Comp eliminators are 356 T6 i believe, have you heard anything indicating that they have problems with longevity? They have been around for quite a number of years now. I would have to imagine that as a cheaper material option... What is used in the MS230 heads from JPM? |
mark tucker Samba Member
Posted: Fri Feb 09, 2018 9:26 am Post subject: Re: Billet heads |
be sure to factor everything when you choose a alloy, repair,corosion,hardness,soft ness, brinnellability etc. everything. 355,356& Ive heard some 345 for air cooled.personaly if I wanted to see if my system&thinking was going to work Im not sure I would put the highest cost alloy for a test bed...hell acast block would be cheep and you can work it all out inexpensivily then get to the exspurts for the "right" alloy once you have it perfected. |
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Fri Feb 09, 2018 9:41 am Post subject: Re: Billet heads |
Try milling Styrofoam and make the casting from that...same process gm uses to cast their blocks. |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Posted: Fri Feb 09, 2018 10:31 am Post subject: Re: Billet heads |
Depends where there are proven...I think mostly JPM is proven all around with big flow and HP numbers that are truely streetable.
Mexxspeed is only for race use which does not use single standard parts on valvetrain either..
Dual ignition? What a waste...
JPM uses A356 which is less stronger and loses its strength at high temperatures at same pace as 6061 T6, as you can see in earlier posted charts.
At the moment mostly for me and few other interested i am getting heads done.
I'v got other company that is on my list, they have been making billet heads long time now, they have their own "secret" , but proven material:
http://www.specialmotorsengineering.fi/fi/TUOTTEET/Sylinterikannet/Billet+kannet.html _________________ Lasercut parts and CAD design |
Posted: Fri Feb 09, 2018 5:44 pm Post subject: Re: Billet heads |
No worries One CNC machine company is interested to make the heads few sets, but they are still calculating the price - which obviosly needs to low enough for worldwide market.. _________________ Lasercut parts and CAD design |
Posted: Wed Jul 25, 2018 1:06 pm Post subject: Re: Billet heads |
First pair of Type 1 billet heads are ready. These heads will go with 50x40 type 4 valves to street/strip 90x101.6=2919cc engine which will run with E85 fuel.
We will be using stock bails with billet valvecovers, but valvecover seal flange at bottom ends have smaller radius, this will make possible to have up to 54x40 valves with pauter rockers.
jason Samba Member
Posted: Wed Jul 25, 2018 5:57 pm Post subject: Re: Billet heads |
cost? |
Posted: Wed Jul 25, 2018 6:07 pm Post subject: Re: Billet heads |
round ex port??? be a shame to sand blast those pretty heads to get them to release more heat. nice pair of jugs !! i would heat cycle them quite a few times bolted togeather (on dummy case) before the final machininh&assy. |
Posted: Wed Aug 08, 2018 12:55 am Post subject: Re: Billet heads |
I 'v got the first time now the billet head to my own hands from my friend.
2mm thick and with 3mm gap the cooling fins look very good.
Ports have good size short side radius and very little porting to be done. At end of this year, heads will go the hearporter to get finished and for flowbench testing.
Tested Pauter 1.4 rockers and they fit very well, roller end of the rocker is at center of the valvestem.
Got one valvecover from my friend who made them with 3 Axis CNC machine, they fit very tight and bails work like on stock valvecovers.
Overall quality of the heads is nice, but i was hoping a bit improvement at machining quality if order my own heads from Elmer Racing later at this year, as they have better tools and experience. Material would be 6082 T651
https://www.facebook.com/ElmerRacingDotCom/
Only problem though, i need to buy 3 pairs at same time, to get price around to 2300€ per pair. Anyone interested?
I am sure that eventually price will drop more.
Valvecovers would be 300€/pair, either for stock bails or bolt on with M18x1.5 vent hose thread at ends.
Heads can be either 94mm bore or 101.6mm bore, ports for 48x38, 50x40 or 54x40 valves or specific setup. 54x40 choice needs exhaust valves moved outwards about 1,5-2mm.
Chamber on the 101.6mm head is about 55-58cc
Chamber on the 94mm head is about 50-53cc
Larger turbo specific chamber can be also designed invidually.
Posted: Wed Aug 08, 2018 12:58 am Post subject: Re: Billet heads |
jason Samba Member
Posted: Wed Aug 08, 2018 12:06 pm Post subject: Re: Billet heads |
They look nice but the price would be a factor, the JPM heads are only a little more and have a service record. |
Posted: Wed Aug 08, 2018 12:48 pm Post subject: Re: Billet heads |
That is somewhat true, especially because at the moment billet heads are not massproduced. Only "Problem" JPM heads that valvesize is limited about to 49x39 or so, as 94mm and 101.6mm bore have same valvespacing.
Billet heads can made basically without any extra cost with different port sizes ,custom valvespacing and chambers. _________________ Lasercut parts and CAD design |
Posted: Wed Aug 08, 2018 2:00 pm Post subject: Re: Billet heads |
and canted valves, and rotated chambers, and.....the list go's on!!!! |
