SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Tue Mar 14, 2017 4:57 pm Post subject: Re: Petrol (gas) smell |
Well I must admit a couple things. I know at least the connections behind the fire wall are seemingly good since I replaced them less than two years ago. As for the upper rear corner connections, I haven't inspected them.
But curious and parts here tomorrow, I tore into the fuel neck to discover this:
As you can see there is a very large rip along the top. Here you can see that it was also ripped along the rear section and the bottom lip too.
This is the setup found in my March 74 Westy. Rubber flex hose from tank to metal tube to rubber fuel neck.
And for the purist and sake of documention, given part #
I'll determine tomorrow evening if this seemingly helped at all. Certainly couldn't hurt anything. I wonder what the effects of running these things in such poor condition does to performance, let alone all the fuel running throughout the circular black port panel cavity. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
DougB Samba Member
Joined: January 09, 2007 Posts: 1076 Location: Falls Church, Virginia, USA
Posted: Mon Apr 24, 2017 5:15 pm Post subject: Re: Petrol (gas) smell |
So here's an interesting question...I had been getting a very faint fuel smell in the van intermittently. Seemed to be most noticeable (and that's barely so) when I fill up and then park the bus, with the full tank. I've checked my hoses and none are leaking. The smell tended to be most noticeable at the right engine bay vent just behind the rear side windows.
Today I was replacing my rear passenger seat belt, and had to remove the lower anchor bolts...and when I removed the bolt, I noticed a fuel smell coming from the seat belt anchor belt hole. Could this indicate something leaking inside the gas tank area? I didn't notice any cracks in the rubber elbow piece by the gas cap.
Thanks!
- Doug _________________ '75 Campmobile (tin-top to SpaceRoof)
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
A very, very understanding wife |
white74westy Samba Member
Posted: Mon Apr 24, 2017 5:36 pm Post subject: Re: Petrol (gas) smell |
DougB wrote: |
Thanks!
- Doug |
There are hoses inside the gas tank compartment that must be tended to, every so often. If that doesn't do it, it is possible the o-ring under the sender may be bad. Finally, you may also want to inspect the filler neck. Hope that helps!
Edit: Thanks to R. Atwell
Check behind the firewall. If you visit Ratwell's site, go under restoration and look at the first image under Fuel tank repair, you'll see two hoses that might be the culprit(s).
Not sure if the link works: http://www.ratwell.com/dotmac/Thumbnails/Tank/01-TankAndStrapsLookGood.JPG-thumb_140_105.jpg |
DougB Samba Member
Posted: Wed Apr 26, 2017 7:33 am Post subject: Re: Petrol (gas) smell |
I got into my gas tank area last night and replaced the 4 small hose segments, as well as the filler neck rubber and the large hose. My bus is a '75, so it originally had the longer, curved rubber hose, but I bought the later longer pipe and the shorter section of large straight hose (didn't know about the MB hose with the middle bulge when I bought the straight hose from Bus Depot).
So, one thing I did notice after installing the later pipe is that it does affect routing of the right side breather pipe that's routed through that same area. I had to adjust placement a bit, and may have bent the breather pipe just a tad to make it all work. This morning's gas fill-up and drive to work was fume-free...I'm going to run out and check the fume situation soon, but I may be in good shape now.
Also, what a pain those two screws that come in from under the car to secure the firewall plate are...I think Bentley could have included a statement about those in the book
Thanks for the guidance!
'73 Fastback
'52 BMW R67/2
'41 Zundapp KS600
'55 Puch SGS250
Posted: Wed Apr 26, 2017 4:07 pm Post subject: Re: Petrol (gas) smell |
DougB wrote: |
- Doug |
Oh man...I totally forgot to mention the two screws. Made an assumption.
When I did my filler tube, I had a piece made at a muffler shop. I took the original long rubber piece in and had it replicated. Worked well.
Glad to help and that it seems to have worked out! |
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
tweeter77 Samba Member
Posted: Tue May 12, 2020 6:54 pm Post subject: Re: Petrol (gas) smell |
Sometimes I forget about this wealth of knowledge and experience on this site. I started troubleshooting a fuel smell. Found one obvious leak. My first task will be replacing the line on the left side above the auxiliary battery. After that I plan on inspecting all the hose that connect to the tank. I did notice some leakage on the right side above the main battery do you think that is the filler tube?
canadadude Samba Member
Joined: November 21, 2015 Posts: 41 Location: Regina ,Sasktachewan
Posted: Fri May 15, 2020 5:58 pm Post subject: Re: Petrol (gas) smell |
I have a 73 transporter van and trying to get my firewall cover off and struggling !Is there 2 screws underneath the van holding the cover on along with the other screws in engine bay?
_________________ 66 VW Beetle |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Fri May 15, 2020 7:00 pm Post subject: Re: Petrol (gas) smell |
Yes _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Fri May 15, 2020 7:57 pm Post subject: Re: Petrol (gas) smell |
sometimes more but 2 is normal _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
ac78 Samba Member
Joined: March 18, 2008 Posts: 330 Location: Nashville
Posted: Fri May 15, 2020 10:43 pm Post subject: Re: Petrol (gas) smell |
I wanted add my leak scenario from a few years ago. I was able to smell gas from the back seat, but was more prominent from outside the bus. The original metal tube which I believe is "12" on the diagram was weeping when under pressure. When inspecting the pipe, there was no visible hole, only pitting in the metal. I removed the pipe and filled with water. Held one end with my finger while blowing on the other end I was able see it seep out the middle of the pipe. Don't forget to really check that one as well when replacing your rubber fuel lines. _________________ 78 Westy 2.0l hydr. FI
VW Campmobile
For people who believe a family's
car should be it's castle ! |
Posted: Sat May 16, 2020 9:57 am Post subject: Re: Petrol (gas) smell |
Anyone have any further info where the two screws are?I can’t seem to see anything from underneath? _________________ 66 VW Beetle |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sat May 16, 2020 11:05 am Post subject: Re: Petrol (gas) smell |
canadadude wrote: |
Anyone have any further info where the two screws are?I can’t seem to see anything from underneath? |
Early bays have four:
Late bays have two:
The factory painted them white for this reason, so you will too when you find them, right?
www.airschooled.com |
Posted: Sat May 16, 2020 11:46 am Post subject: Re: Petrol (gas) smell |
Thanks for the pics mines undercoated from new so I should be able to find them now! _________________ 66 VW Beetle |
Posted: Sat May 16, 2020 12:37 pm Post subject: Re: Petrol (gas) smell |
Rubber hose 1/2 inch 90 degree one was cracked wide open !Appreciate the help everyone!Gotta find a kit and do all hoses at once. _________________ 66 VW Beetle |
SGKent Samba Member
Posted: Sat May 16, 2020 1:11 pm Post subject: Re: Petrol (gas) smell |
canadadude wrote: |
Rubber hose 1/2 inch 90 degree one was cracked wide open !Appreciate the help everyone!Gotta find a kit and do all hoses at once. |
read this thread the whole way thru. I think it is what you are dealing with https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun May 17, 2020 4:49 pm Post subject: Re: Petrol (gas) smell |
I’m removing my gas heater and there will be the spot on left side of cover left open after the duct is removed what have others used to cover this hole up?
peagreenbus Samba Member
Joined: December 07, 2014 Posts: 22 Location: SW France
Posted: Sun Jun 14, 2020 11:03 am Post subject: Re: Petrol (gas) smell |
I too am trying to solve a petrol smell.
78 bay with type 4 engine (originally from California). Some PO has ripped out the FI and fitted a daft empi thing, which I have replaced with twin dellortos.
I have replaced most of the number 24 pipes. The red hard to get at one was rotten and in two bits. Its a bit of a fiddle to get a new one back on but a bit of washing up liquid helps.
So now on to the breather pipe that comes off the tee junction strapped to the top right inside of the engine bay. It goes off to a carbon filter (I guess that's what it is) tucked between the battery and right back light unit.
This black canister has a crack in it (smell ?) and a transparent pipe coming out of the top of it which is not connected to anything! (Smell?)
There is also another exit pipe connection at the bottom which is not connected to anything. (Smell?)
Can anyone tell me what to connect the two unconnected exit pipes to and also where I can find a new canister if it is still required without the original FI unit. I am presuming it is a carbon filter.
I can find no reference or photo for it.
Many thanks
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jun 14, 2020 11:39 am Post subject: Re: Petrol (gas) smell |
It's not an FI only thing, carbed versions used one too.
A crack will definitely let the stink out. That's indeed a charcoal canister, the 2 pipes from the fuel tank vents Tee together and connect to the small nipple on the top. The large nipple on the top can go to one of your air cleaner lids, the lower nipple connects to a nipple on the cooling tin over cylinder #2.
New ones show up occasionally, some are a slightly different shape, as long as it has a big nipple on each end and one small one it'll work. Or you can try repairing yours with JB weld or Shoo goo (not sure if it's called that in Europe). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jun 14, 2020 10:18 pm Post subject: Re: Petrol (gas) smell |
Many thanks busdaddy
Very clear. |
