vdub411 Samba Member
Joined: August 14, 2007 Posts: 264 Location: Mid Michigan
Posted: Fri Jun 21, 2013 2:31 pm Post subject: Anyone else running a blow through turbo buggy??? |
Trying to get some ideas of how to run my lines for an external oil cooler. I don't have much room to work with at all because of my crazy lines for the turbo. I have a 1776 full flow case and I'm adding a Schadek 8mm oil pump with 30mm gears where my oil filter is now. Then a new external oil filter up to a thermostat then to the oil cooler (which I have no idea where I'm putting.)
My ideas so far have been mount it to the roof. I don't really want to do that until I get my roof rack finished. Then I thought about mounting it in the parcels tray in the rear with a hole cut out to blow in/out air. The problem with that is I play in deep mud and water. I've already had to put drain plugs in my floorpans and trunk. Maybe mount it to the roof rack, but then where to run the lines??? Any pics would be greatly appreciated.
Here is the mess I'm working with.
_________________ 1975 Baja Bug
1972 Type III Fastback
B&N Rattler Buggy
SandRails Coming Soon!!! |
BoomerDC Samba Member
Joined: September 10, 2012 Posts: 15 Location: Flushing MI
Posted: Sun Jun 23, 2013 10:02 am Post subject: |
you mean something like this?
Posted: Sun Jun 23, 2013 10:28 am Post subject: |
Wow, that's sweet!!! Yup just like that and your right up the road. I'm in New Lothrop. Did you build it or have someone build it? _________________ 1975 Baja Bug
B&N Rattler Buggy
Posted: Sun Jun 23, 2013 10:51 am Post subject: |
nope, built it all myself. it was a winter project I just completed this summer.
a friend of mine and myself did all the custom welding, piping and duct work |
ret1614 Samba Member
Joined: March 30, 2009 Posts: 130 Location: Sonora, CA
Posted: Sun Jun 23, 2013 1:55 pm Post subject: |
Mine doesn't have a blown through turbo, but I just recently tried to simplify my external oil hoses.
I put the filter and a cooler on the inside of the firewall (mostly for heat in the winter), but I figure you could do this and put a shroud around it with holes in the firewall for ventilation... And holes in the parcel shelf for drainage.
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20 _________________ 1970 2180cc Baja Bug. All go and no show...
Rattlecan white to cover the hideous 49er warpaint.
Looks like Hell, but she goes the same way.
______________
Mal evolent wrote: |
beer after, not during |
