cdavisw Samba Member
Posted: Fri Nov 14, 2003 7:45 am Post subject: Custom wheels for '77 Westy... |
are there any custom wheels available for my '77 westy (other than the BRM replicas) with the 5 112mm bolt pattern???[/b] |
VW Addict Samba Salesman
Posted: Fri Nov 14, 2003 10:39 am Post subject: |
Customed? Like Riveria? Ansen? Want a VW Rim? Or anything that fits? |
Billet_Bus Samba Member
Posted: Fri Nov 14, 2003 10:45 pm Post subject: |
Audi and Mercedes come in 5-112 patterns also. I have my eye on a set of new Clk 18s |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Sat Nov 15, 2003 1:18 am Post subject: |
Be very careful when choosing Mercedes wheels....yes, they are all 5 x 112 [except for the G-wagon] BUT the wheel bolt holes are 2 different sizes. 12mm and 14mm. The bus wheel bolts are 14mm. This means you need the S class wheels; 140 body, 215 body, and 220 body. But the offset and width will be totally different. |
Island Bwoy 420 Samba Member
Joined: September 22, 2003 Posts: 108 Location: Palm Beach Gardens, Fl
Posted: Mon Dec 08, 2003 10:35 am Post subject: |
So Karl, I have a set of S 500 16 inch wheels. Will they be able to be a adapted to my 78 bus? They look sweet I really want to put them on. Thanks _________________ 4-2-0 Theres no time to be taking your time so spark it up! |
Randy in Maine Samba Member
Posted: Mon Dec 08, 2003 1:39 pm Post subject: |
I will put in my little shameless plug for the GoWesty alloys which (as they used to say in californianese from the 70's) are "knarly bitchin cool". I think they are made well, fit well, and stay in balance. I think they were about 5 bills for the 4.
I am running 215/65/15 Michelins on them.
http://www.john-perry.com/vw/gallery.html
You have to go to visitor photos, and they are there under "alloys" and "braless". |
WAVEPIMP Samba Member
Joined: February 13, 2002 Posts: 156 Location: Houston, Texas
Posted: Mon Dec 08, 2003 9:11 pm Post subject: |
You may have to open the hub area up some as well. Your wheel hubs may be bigger than the middle hole of your rim. I had to use a high speed file bit on a air die grinder to open up mine to get them on.
Just another thought to think about as well. 14mm bolt holes are what you need and you may have to get longer wheel studs also. Porsche 911 and 911 turbo studs are what I had to use. 911 turbo are a bit longer than the regular 911. I think I had to use the turbo's on the front if I'm not mistaken. I have 17" porsche cups that were blanks and drilled to 5x112 pattern with 14mm studs. Do some research or if you can, see if they will fit first befor you buy.
Laters James |
GermanLookT2 Samba Member
Joined: December 12, 2003 Posts: 74 Location: Maryland
Posted: Fri Dec 12, 2003 6:59 pm Post subject: width? and what about the axle nuts |
umm what about fitting wheels over the massive axle nut on the rear??? I just read what you said on the sizes I found a massive amount of benz rims, but some look like they woul be tooo close whats the widest youd go too? |
