wolfej1 Samba Member
Joined: August 15, 2005 Posts: 679 Location: North Royalton, Ohio
Posted: Thu Jun 27, 2013 11:03 am Post subject: Intake Runner (air-cooled) |
On air cooled engine - do I need to pull the engine to replace the intake runner?
thanks _________________ 1982 Westy
2004 KDX200
2008 Kawasaki KLR 650
1979 Yamaha DT 175
1995 Toyota 4Runner |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Thu Jun 27, 2013 11:56 am Post subject: |
no.
you should do new sleeves & injector seals while you're there.
and you will need a new phenolic spacer too.
that's all assuming that you are still fuel injected. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Fri Jun 28, 2013 8:43 am Post subject: |
borninabus wrote: |
no.
that's all assuming that you are still fuel injected. |
Is the phenolic spacer a factory VW part, or is it an aftermarket part used in lieu of a metal type gasket.
I tightened the bolts down pretty good and the leak is still there albeit not quite so bad - so it has to come off and be replaced.
thx _________________ 1982 Westy
2004 KDX200
1979 Yamaha DT 175
Randy in Maine Samba Member
Posted: Fri Jun 28, 2013 9:41 am Post subject: |
Injector seals http://www.busdepot.com/311198261a
Intake Runners http://www.busdepot.com/039133241
Try putting a dusting of wheel bearing grease or hylomar or Locktite 565 on the intake phoenalitic gasket and tighten evenly starting from the inside studs to the outside. I can't find a part number for the new ones (although I have a pair on my bench at home right now).
Work from the left side to the right side. |
Posted: Fri Jun 28, 2013 12:09 pm Post subject: |
Thanks for the advice. I am glad I found that leak it was driving me crazy for the past few years......I hope i did not do any damage by tightening things up like i did. _________________ 1982 Westy
2004 KDX200
1979 Yamaha DT 175
Posted: Tue Jul 23, 2013 3:34 pm Post subject: |
Randy in Maine wrote: |
Do i put the dusting of wheel bearing grease on both sides of the gasket?
2004 KDX200
1979 Yamaha DT 175
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Tue Jul 23, 2013 4:06 pm Post subject: |
Just to be clear, you can reuse the spacer if it is not cracked but you need to renew the paper gasket on both sides of the plastic spacer.
Good news is you can just trace and cut new ones on your workbench....... I used an old Cheerios box on the last set I redid. A light smear of grease is a good suggestion.
Good Luck. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
Posted: Tue Jul 23, 2013 4:53 pm Post subject: |
i have a new one that has the paper gaskets on it. Do i put the smear of grease on both of the paper gaskets - on the sides that contacting the metal? In essence, like a sealer on both sides?
Actually i was thinking of putting a light coat of grease on the head and on the intake pipe, setting the spacer into place, putting the runner back on and tightening up to 11 ft lbs....
Is that ok
I am probably making this into more than it is. _________________ 1982 Westy
2004 KDX200
1979 Yamaha DT 175
Posted: Tue Jul 23, 2013 7:20 pm Post subject: |
That will be fine. |
Posted: Tue Jul 23, 2013 7:27 pm Post subject: |
thanks for the reply _________________ 1982 Westy
2004 KDX200
1979 Yamaha DT 175
2004 KDX200
1979 Yamaha DT 175
Posted: Tue Jul 23, 2013 7:28 pm Post subject: |
2004 KDX200
1979 Yamaha DT 175
Posted: Thu Jul 25, 2013 7:49 pm Post subject: |
Replaced the spacer/gaskets and used hylomar on the head and runner surfaces. What a difference in how the engine is running - much smoother and seems to have a bit more power especially in 4th gear. Idle is now the same regardless of whether the engine is cold or hot - prior to this the idle would increase as the engine got hot.
When refueling I always fill until the nozzle clicks and then thats all the fuel that goes in. Prior to the fix I would get about 17 miles on the odometer before the fuel gauge needle would move off of the "Full" line. This time I got 35 miles before that happened. No kidding. I have been running that engine into the ground - I am glad I finally figured that out.
I am also wondering if that would be the cause of my bad compression on the number 1 cylinder - air getting past that gasket.
Moral of the story...if you are having idling issues check those pesky intake runner spacer/gaskets...
Regardless it is good to do something that actually worked. _________________ 1982 Westy
2004 KDX200
1979 Yamaha DT 175
