24E Manx Build
1madmanx
1madmanx is offline
PostPosted: Tue Sep 10, 2013 6:22 pm    Post subject: Reply with quote
Tim H wrote:
Love the buggy and the color. But what is the MOTB and where is it held at? Thank you
The MOTB is the largest Manx Club sponsored dune buggy event on the east coast. It is held in the Outer Banks of NC. All the information is at www.manxonthebanx.com. Check it out.
Bud (1Madmanx)
Wilmington, NC
'68 Meyers Manx Dune Buggy
'66 Kombi Bus
'73 Thing
Visit: www.manxclub.com
Visit: www.manxonthebanx.com - The premier east coast Manx Club event
Galleries:
http://manxclub.com/forum/gallery/album.php?album_id=44
http://www.manxgallery.org/gallery/album208
surfnc
surfnc is offline
PostPosted: Wed Sep 11, 2013 6:34 pm    Post subject: Reply with quote
Joe
I know you want to add to your collection, but I think I will keep these. Wink How much more do you need to do on yours?
Rathbone
Thanks! I have been thinking about using Sharkhide. What is the application process and does it dull the finish?
Scott
Thanks, I hope to see you here as well.
I got the center console from Mid America
http://www.mamotorworkstv.com/vw/product/basic-black-center-console-304734/
Bryan
Thanks, I understand the the Towd's won't be in your area till after the event waiting for pick up.
Dave,
Thanks for the compliment, it means a lot coming from you. (I know how much you like metal flake) I am spraying a small area with a thin coat of clear. (about 1 foot square) I am then using a "Flake Buster" gun to spray the flake on dry. It will only stick to the wet area. I then blow off the area with an air gun. Then move on to the next area. After I finish the panel, fender etc, I use a 3"-4" "chip" brush (throw away brush) to flatten the flake and remove any loose flake. I then let the area dry for about 1/2 hour. I then do the same process to fill in the areas not completely covered by the flake. So after I am done I have gone over the same spot 3-4 times and have complete flake coverage and no base color showing through. If you are careful and patient the result is a fairly flat surface that can be covered by 3-4 coats of clear and cut and buffed to a great finish. I have to say that this is not a process for the faint of heart and the learning curve is steep. For example if you pile too much flake up on uncured clear you will get a "land slide" effect with your flake. This makes a very lumpy spot that you cannot get rid of without waiting for it to dry so you can sand it all flat so you can start again. You also have to do it in 2 coat steps doing 3 or more coats can cause the paint on the surface to dry before the lower coats have a chance to "off gas" the solvent causing very small bubbles called solvent pop. The only way to get rid of this is to let it dry, sand it and start the process all over. (ask me how I know this) After all that you do get a feel for how it will work and if you do it in the 2 coat process you will save allot of time and materials. So my next one (a Moss Green Manx 2) will go faster and should turn out better.
Hecubus
Thanks for the kind words. Do you have a build thread going?
Tim H
Thanks and hopefully you can make the event.
Update 9/11
Got the buggy tagged and drove it about 90 miles today. I just put the drivers seat in and drove it. I still have more to do to have it ready for the MOTB.
I will take pictures when I get the rims polished and the new tires installed.
Vince
LOOKING FOR VINTAGE MEYERS MANX STUFF!!!
http://www.thesamba.com/vw/classifieds/detail.php?id=1105228
joescoolcustoms
joescoolcustoms is offline
PostPosted: Wed Sep 11, 2013 6:59 pm    Post subject: Reply with quote
A man can never have enough rims Vince.
If I could get one weekend to dedicate on the buggy, it would be done. But, I also bought a new enclosed trailer that I need to outfit with winch, tie downs, cabinets and so forth. Then working 14 to 15 hour days is sucking the life out of me.
But I am looking forward to a needed break, seafood, cruising with fellow buggy people and a little R&R. Closing in on 30 days quickly. See you soon!
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
Member of Wagenfolks
http://images.thesamba.com/vw/gallery/pix/870707.jpg
http://www.thesamba.com/vw/forum/viewtopic.php?t=479740
frizzardking
frizzardking is offline
PostPosted: Thu Sep 12, 2013 3:58 pm    Post subject: manx 2 Reply with quote
Hey Vince ,buggy is looking very nice , Did you use a Manx 2 sticker on the nose badge , and if you did, is it the one from the Manx store from Winnie , or did you find a vintage Manx 2 sticker like the old school ones.
The reason I ask is on my yellow Manx 2 it has the holes for the emblem, I have that spare I showed you last year , but I am not sure if i should get a Manx 2 sticker from Winnie on it , it has the holes and I dont know if you would see the hole marks under the sticker?
Rathbone
Rathbone is offline
PostPosted: Thu Sep 12, 2013 6:22 pm    Post subject: Reply with quote
surfnc wrote:
Joe
Rathbone
It's so easy to use that even I can do it. Use a lint free cloth because it gets sticky quickly. You just dampen the cloth and wipe it on. It usually flows out and leaves no streaks. If you get a streak you can immediately wipe it again, or if it has dried then clean the old product off (I used gasoline) and try again. It doesn't make it any more or less shiny. The only difference you will see is that in some light there will be a more rainbow appearance to the shine than is on standard chrome. If you know chrome you know all chrome used to shine with a blue hue, but they removed the hexavalents and now it has a yellow hue. This resembles the blue hue that chrome once had.
(o\_i_/o) what you've just said ... is one of the most insanely idiotic things I have ever heard. At no point in your rambling, incoherent response were you even close to anything that could be considered a rational thought. Everyone in this room is now dumber for having listened to it. I award you no points, and may God have mercy on your soul - Mr. Oblaski, Principal
surfnc
surfnc is offline
PostPosted: Fri Sep 13, 2013 8:20 pm    Post subject: Reply with quote
Joe
I hope you get some time soon. I know that you will have an awesome buggy for the event.
Marc
The sticker is a die cut vinyl one that I made to put on the hood bump. (I do not sell these stickers) I think that if you put a sticker on without filling the holes you would see them through the sticker.
Rathbone
That is exactly the info I needed!! Thank you very much. You can read a manufacturer's description on how it works, but I like to hear about real world experience. Thanks again.
Vince
surfnc
surfnc is offline
PostPosted: Fri Sep 20, 2013 4:35 pm    Post subject: Reply with quote
Update 9/20
Been driving it around since last Tuesday and have put almost 900 miles on it. (working out of it) Still not completely done but I put the interior in, got all electrical hooked up, rear bumper on. and new Sidewinder installed. Got the engine tuned, just need to take care of a few seal leaks.
Still need to polish the rims, put new tires on, install rear deck and install new soft top.
Vince
Manx Lee
Manx Lee is offline
PostPosted: Fri Sep 20, 2013 5:30 pm    Post subject: Reply with quote
great as usual!!
MOON BUGGY
MOON BUGGY is offline
PostPosted: Fri Sep 20, 2013 5:53 pm    Post subject: Reply with quote
ohh so very nice, classic.
"Dune Buggies and Watermelon Rock! . (MOON BUGGY)
frizzardking
PostPosted: Fri Sep 20, 2013 7:06 pm    Post subject: manx Reply with quote
Out off this world! Simply Stunning!
Roys_Big_Toys
Roys_Big_Toys is offline
PostPosted: Fri Sep 20, 2013 8:49 pm    Post subject: Reply with quote
I can't find the "Two thumbs up" button. Damn nice, Vince. Give me a call and I will make arraignments to pick your parts up. I may have to get some seats while I am out here. I think my butt deserves them.
I'd rather be an hour early than 5 minutes late. (Mine)
"It's not a hobby, it's an addiction" (My wife)
"Socialism only works in two places: Heaven where they don't need it and hell where they already have it." -Ronald Reagan
Original Meyers Manx
Berrien LKD Warrior Ecotec 2.2 w/ Bus 091 Trans
Original 2 sided Meyers Manx Dealership sign
Meyers Manx Surf Board #1 0f #100
Custom Meyers Manx Cornhole game
monomanx
monomanx is offline
PostPosted: Sat Sep 21, 2013 8:18 am    Post subject: Reply with quote
vince,
Is that a stainless "show" bar or a rechromed original?
Also, where did you get your steering wheel adapter...nice old school Manx accessory
Chris
Roscoe
Roscoe is offline
PostPosted: Sun Sep 22, 2013 5:49 pm    Post subject: Reply with quote
Looks totally Awesome! Where did you get your bumpers and skid plate? Once again great job on a period correct looking buggy!
surfnc
surfnc is offline
PostPosted: Sun Sep 22, 2013 8:14 pm    Post subject: Reply with quote
Lee
Thanks! Looking forward to your Manx 2 build.
MB
Thanks, MOTB coming up soon, are you going to make it?
Marc
Thanks, did you get your Tow'd yet?
Roy
Thanks, and thanks for all your help with the parts.
Chris
New from Winnie, stainless hoop.
I got the wheel adapter with my yellow Manx 1
Roscoe
Thanks! I got the front bumper off the classifieds here. It is the stainless type that was made in 2000 (?) for the Signature Manxes. I got the rear setup from a good friend who changed his out for a new Meyers Manx Manxter style bumper.
Vince
frizzardking
PostPosted: Tue Sep 24, 2013 4:08 pm    Post subject: Manx Reply with quote
Just sent the money and working on details for shipping it back , shipper said possibly this weekend , I will start a new thread.
How is she running? Can't wait to see it up close, bet it looks a thousand times nicer in person! Well we will see it soon !
frizzardking
PostPosted: Tue Sep 24, 2013 4:18 pm    Post subject: Manx Reply with quote
surfnc
surfnc is offline
PostPosted: Mon Sep 30, 2013 10:32 am    Post subject: Reply with quote
Marc
She is running well. I finally took care of the oil leak. (hopefully)
Update 9/30
Polished rims, put new tires on and installed new center caps.
I also wanted to see how my widened "smoothies" looked. I got some MT Mini Mags for the front.
I still need to install the rear deck cover and the soft top.
Vince
MOON BUGGY
PostPosted: Mon Sep 30, 2013 2:04 pm    Post subject: Reply with quote
Smoothies and slots are some of my favorites on a manx.
Both = awesome.
joescoolcustoms
PostPosted: Mon Sep 30, 2013 2:22 pm    Post subject: Reply with quote
I am looking forward to seeing it in person in 13 days and 15 hours.
I'm not one bit excited!
monomanx
monomanx is offline
PostPosted: Mon Sep 30, 2013 2:25 pm    Post subject: Reply with quote
Hi Vince,
Beautiful job. What type and size of tires are you running?
Page 5 of 6
