LED Tail Light Bulbs
Page: 1, 2, 3, 4  Next
WestyDreamer
WestyDreamer is offline
PostPosted: Sat Jun 29, 2013 12:27 pm    Post subject: LED Tail Light Bulbs Reply with quote
Anyone using the newer LED Tail light bulbs.. Saw that GW and others sell a bulb kit but I'm mainly concerned with the Driving Lights, as they are dim.
I was thinking of using one of those flat LED boards that have 36 or 40 LED's on it and the 1156 style base that would fit into the tail light socket.
Question. Should we use the clear white bulbs or Red LED bulbs, or wouldn't it matter?
kamzcab86
kamzcab86 is offline
PostPosted: Sat Jun 29, 2013 12:44 pm    Post subject: Re: LED Tail Light Bulbs Reply with quote
GW kit reviews: http://www.thesamba.com/vw/forum/viewtopic.php?t=512849
VC kit reviews: http://www.thesamba.com/vw/forum/viewtopic.php?t=457411
Have you added headlight relays yet?
Rule of LED thumb: Bulb color should match lens color.
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
Ahwahnee
Ahwahnee is offline
PostPosted: Sat Jun 29, 2013 1:11 pm    Post subject: Reply with quote
FWIW -- I went with the 50W brake lights sold by Terry K. Real bright, much brighter than some LEDs I tried -- but too much heat for anything other than brake lights I think.
I used the LEDs for the rear turn signals -- not just brighter but (IMO) a more abrupt flash to them which helps visibility.
geodude
geodude is offline
PostPosted: Sat Jun 29, 2013 1:50 pm    Post subject: Reply with quote
My dear wife got me the VC setup for Fathers Day (Love that woman) and what I found was the running lights were much brighter, the reverse are about the same brightness as my old ones that I had added reflectors to (so would likely be brighter than stock), the turn signal and brakes are about the same brightness but much quicker coming on. I had my wife hit the brakes and the LED was on instantly and there was a very noticeable wait until the conventional bulb on the opposite side that I hadn't changed yet came on. I'd guess 0.1 to 0.2 seconds for the conventional light to get bright. That's pretty significant. All in all I think worthwhile change.
I also homebrewed my own headlight relay system with separate power taps for the headlight and highbeams running to two relays in a small weatherproof box. The headlights are much brighter than stock. Went from dim yellowy spots to more of a white beam on the pavement. Much more comparable to a newer car light output. Definitely worth $50 to do.
1988 GL Camper
1991 Multivan — the basket case
r39o
Samba Polizei
r39o is offline
PostPosted: Sat Jun 29, 2013 2:19 pm    Post subject: Reply with quote
Adding in a better power source system and cleaning / replacing the headlamps makes a HUGE difference, generally.
joseph928
joseph928 is offline
PostPosted: Sat Jun 29, 2013 3:39 pm    Post subject: Re: LED Tail Light Bulbs Reply with quote
Blue Bay Bus Go Westy love them, also put in the extra bulb. Now have two tail lights! Kam is right on the color of bulb to lens. Very Happy
1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug.
Syncroincity
Syncroincity is offline
PostPosted: Sat Jun 29, 2013 6:00 pm    Post subject: Reply with quote
I'm running these in red in both my van and the Passat;
http://www.superbrightleds.com/moreinfo/tail-brake...tower/526/
They are very bright, and make good use of the reflectors built into the tail lights.
I used some flat panel boards like you described for the brake lights on the van. The leds are white, and I don't like the output compared the the ones above; I'm going to change them out to another set of these. The red LEDs give you a very rich, true red color that really pops out, the white ones behind a red plastic lens look washed-out and pinkish.
I did the panel LEDs in the rear turn signals, too... these I actually like.
It's a fiddly mod for no improvement in output over the tower bulbs above, which pop right in, and it's a pain in the butt to take the tail lights out once they're in. I glued the panels inside the reflectors.
ps. There's 10% off until July 4th. Promo code 070413
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
wcdennis
wcdennis is offline
PostPosted: Fri Jan 09, 2015 10:06 pm    Post subject: Reply with quote
I was poking around on the web today and discovered these LED tail light assemblies:
http://www.amazon.com/ZNU-Light-Truck-Caravan-Bulb...ail+lights
They are almost exactly the same size as the Vanagon tail light. To get an idea of how they would look, I tried them on with PhotoShop.
I'm not sure about the look, but it would be nice to never have to worry about replacing bulbs ever again. Anybody have an opinion?
PS Not my van, but the same colors.
Syncro Jael
Syncro Jael is offline
PostPosted: Fri Jan 09, 2015 10:33 pm    Post subject: Reply with quote
I too bought the GoWesty exterior LED kits for our vans. They are very bright and have been flawless for a couple years. Even the backup lights are bright now. It's hard to spend that much on bulbs but I would do it again in a heartbeat.
1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat)
thatvwbusguy
thatvwbusguy is offline
PostPosted: Fri Jan 09, 2015 10:37 pm    Post subject: Reply with quote
I bought a set of fairly similar LED tail lights a while back, but the fit was not quite right. For the relatively small investment, it would be great to know if this model would work on the Vanagon without a lot of custom fabrication.
Another nice option with LED tail lights is faster activation, which can (theroetically at least) help with reaction time for drivers behind you when you hit the brakes.
Jay Brown
'85 Zetec Westfalia
Newmarket, NH
VANAGON HEADLIGHT RELAYS
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion.
syncrodoka
syncrodoka is offline
The ones you are looking at are even larger.
thatvwbusguy wrote:
Sorry for not following up sooner. The lights are actually fairly bright from a distance, unfortunately they are about 1/2"-5/8" too long to fit correctly. This makes them protrude into the recessed space toward the center of the van, which pretty much means there is no way to seal them from the weather. Oh well, you win some, you lose some…
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...p;start=20
ThankYouJerry
ThankYouJerry is offline
PostPosted: Fri Jan 09, 2015 10:48 pm    Post subject: Reply with quote
I have the GW exterior bulbs and like them a lot. However, these LED reverse bulbs are FAR brighter than the ones that came with the GW kit: http://www.amazon.com/gp/product/B00B21RJUU/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
So far, so good.
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
Tom Powell
Tom Powell is offline
PostPosted: Fri Jan 09, 2015 10:50 pm    Post subject: Reply with quote
It makes the Vanagon look like a vehicle of this century.
But at $86 for a pair I'd rather use the money for fuel lines or headlight upgrades.
Photoshop is easier than installation.
Aloha
tp
IdahoDoug
IdahoDoug is offline
PostPosted: Fri Jan 09, 2015 11:59 pm    Post subject: Reply with quote
Thanks, Jerry. I ordered those Amazons right away directly from your recommendation.
1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2016 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential. 1988 Mitsubishi Van w/ dual spinny seats, mid engine and solid axle.1990 burgundy parts Vanagon. 1984 Porsche 944, 1992 Lexus LS400, 1988 Toyota Supra 5 speed targa project in pieces, 2002 BMW 325iX
luVWagn
luVWagn is offline
PostPosted: Sat Jan 10, 2015 1:01 am    Post subject: Reply with quote
Damned impulse shopping, me too! Confused
'91 Syncro 16 Reimo Hightop Conversion, eTDI
Tom Powell
PostPosted: Sat Jan 10, 2015 5:22 am    Post subject: Reply with quote
The review on Amazon:
"Light were terrible.... You could not even tell they were on because they were so dim. Would not recommend these lights at all."
Hopefully he wrote that in the daytime.
Do they have both taillights and brake lights in the red lens?
I assume the yellow is for turn signals.
Please post your installation and illumination comments when the job is done.
Aloha
tp
wcdennis
wcdennis is offline
PostPosted: Sat Jan 10, 2015 7:30 am    Post subject: Reply with quote
It looks like it has already been tried:
Thanks for finding the thread I missed, syncrodoka.
thatvwbusguy, who tried the very similar lights, passed on the installation because they were about 1/2" too long.
I have already started down the LED bulb route but, so far, only replaced the back-up lights. I was thinking this unit would be great way to do away with the tenuous sockets in the stock tail light. I think I will hold off for now but if someone wants to try, here is the same unit at a better price (for a pair):
http://www.amazon.com/GENSSI-Trailer-Commercial-Li...JBCPG1ASC2
IdahoDoug
PostPosted: Sat Jan 10, 2015 9:45 am    Post subject: Reply with quote
One thing I've noted from playing a bit with LEDs is that a large number of dim/cheap LEDs in a tail light doesn't create the same perceived brightness on the road as fewer quality bright LEDs. A lot of sellers are offering the former and crowing about "114 LEDs" but not revealing the LED's draw. For instance, the back up lights I just ordered above are single CREE 7W LED. Those are going to to be very bright for back up lights and CREE is a worldwide leader.
So, don't be blinded by sheer quantities of likely cheap LED which won't look impressively bright in the real world, compared to fewer quality LEDs. And if they don't list the draw (3W, 7W, etc) be suspicious.
DougM
JED THE SPREAD
JED THE SPREAD is offline
PostPosted: Sat Jan 10, 2015 10:16 am    Post subject: Reply with quote
There is a comprehensive range of quality LED bulbs for a Vanagon right here, http://campervanculture.com/product-category/lighting/ All of them are top quality and have been tested extensively by me personally.
I hope this helps.
Jed
Visit CAMPERVANCULTURE.COM real camping and video uploads
Subscribe to Campervan Culture by Email
Follow us on Facebook, Campervanculture.com
Syncro Jael
PostPosted: Sat Jan 10, 2015 10:22 am    Post subject: Reply with quote
So far, so good.
I agree the GW backup LEDs are brighter than stock but still not enough for backing up at night off-roading.
This 36w Cree Flood LED does the trick nicely mounted up high.
Page 1 of 4
