peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5274 Location: Taoswest, USA
Posted: Mon Jul 01, 2013 5:33 pm Post subject: Need some information for ceiling bows for a conversion. |
I am planning on installing birch paneling on the ceiling of the 66 13 Window and I have realized I will need a couple of wood bows to take up the gaps between the roof frame.
Anyone ever done this?
I am fairly certain I can lay out the bows myself and cut them.
What I am curious about is should they have a runner on the rail at the edge of the ceiling that the bows attach to to?
Would I need 2 or 3 bows?
I have the baltic birch paneling that I purchased a few years ago. 10-1/8"x4'x10' sheets which I hope to get two 4' panels out of each.
Anyhow, any thoughts, ideas or experience would be much appreciated.
Photos and specs would be helpful too.
Thank you. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4117 Location: Margaritaville.....24/7
Posted: Mon Jul 01, 2013 5:42 pm Post subject: |
Since you will need a panel that is ~50" wide you will need to run a strip down the middle of the roof. Clara makes bows but not for down the middle, IIRC. The bows should look just like the front and rear metal ones that are already welded to the roof and the top of the walls. The bases will need to be set back from the inside lip to accept the edges of the roof panels.
I have never been a fan of the Riviera/Sundial/Caravel, etc... roof layout. But that wasn't your question, now, was it?
Look what I just found!-
http://www.thesamba.com/vw/classifieds/detail.php?id=1152873
Is this what you are trying to replicate? _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Mon Jul 01, 2013 5:56 pm Post subject: |
I want to try to do them without the seam in the middle.
I also saw this ad from Clara, though I would like to do it myself.
http://www.thesamba.com/vw/classifieds/detail.php?id=1229943 _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Posted: Mon Jul 01, 2013 6:08 pm Post subject: |
BTW, I know Clara makes quality interior pieces, as I have bought from her before for a SC.
I am trying to do this one all on my own and for the fun of doing it. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
cru62 Samba Member
Posted: Mon Jul 01, 2013 6:09 pm Post subject: |
I don't see how you can do this with 48"wide panels unless you do it with the grain running side-to-side. I will reserve comment on this method. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Posted: Mon Jul 01, 2013 7:32 pm Post subject: |
cru62 wrote: |
I don't see how you can do this with 48"wide panels unless you do it with the grain running side-to-side. I will reserve comment on this method. |
Wait and you will see! _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
cru62 Samba Member
Posted: Mon Jul 01, 2013 10:00 pm Post subject: |
peaceful warrior wrote: |
cru62 wrote: |
Wait and you will see! |
I am prepared to be amazed, my good man. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Clara Samba Member
Posted: Tue Jul 02, 2013 8:27 am Post subject: |
I make three bows, with the seam in the middle, because that is what Westfalia did and I follow them like the proverbial lemming.
The number of the bows shall be three. Thou shalt not count four, nor two, unless immediately proceeding to three. Five is right out.
Possibly you could use two, or four, or five, depending on your design.
There is also the US OTW roof style with the seam down the middle, which takes a wooden brace down the middle.
Westfalia used 'shoehorns' at the sides to shoe horn the roof panels into the inner rain gutter, #8 in diagram.
I used the wrong length shoe horns for these, oops... this length would work better on a flip hatch bus... the seam between shoehorns on each side should be on a bow and tacked in place there. yes, tacked into the metal bow. Don't use long nails or it will dimple the roof out!
Posted: Tue Jul 02, 2013 11:47 am Post subject: |
Thanks Clara and thank you for the time on the phone this morning.
Much appreciated. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Posted: Tue Jul 02, 2013 12:05 pm Post subject: |
BTW, this is just an idea for what I am doing to MY bus.
Aluminum diamond plate at the bottom of the door panels and side panels. The birch I am using is not finished and being used for fitment. Working out some issues as height, how to transition from DP to Birch, etc.
I like the way it looks.
TOOB Member #15
Brian |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Tue Jul 02, 2013 2:52 pm Post subject: |
i like the aluminum panel idea, how about the old hammered style? http://www.materialsgate.de/en/mcard/28078/Hammered.html _________________ regards
Uli
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9789 Location: Exit 7, New Jersey
Posted: Thu Jul 04, 2013 1:22 pm Post subject: |
Diamond plate is kinda played out, but I can understand why you'd want something other than a varnished wood panel to take the abuse from water and stuff bouncing around inside the bus down low on the doors. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Thu Jul 04, 2013 2:24 pm Post subject: |
j.pickens wrote: |
Diamond plate is kinda played out, but I can understand why you'd want something other than a varnished wood panel to take the abuse from water and stuff bouncing around inside the bus down low on the doors. |
I have never used it, so I don't understand the played out.....
I found some aluminum divide to separate the DP from the wood, in 1/8".
Here is a photo of what it looks like. I think it will give it a cleaner look.
TOOB Member #15
Brian |
