LHD 58 Kombi Gear Stick Problem
dave1
dave1 is offline
PostPosted: Mon Jul 08, 2013 2:35 pm    Post subject: LHD 58 Kombi Gear Stick Problem Reply with quote
My gear stick ball joint has come out of the lower rod and I can not see how it goes back in. It only has the ball type end which I suppose should just fit in the rod. Has any one got a diagram and an explanation on how you put it together. I removed the gear stick for investigation. The plate under the gear stick has a raised section on one side.what side does it go right or left
Cheers
Dave
mandraks
mandraks is offline
PostPosted: Mon Jul 08, 2013 2:38 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=535356&highlight=shift+lever
this should help
regards
Uli
dave1
dave1 is offline
PostPosted: Mon Jul 08, 2013 2:49 pm    Post subject: LHD 58 KOMBI GEAR STICK PROBLEM Reply with quote
The ball at the end of my gear stick doesn't have a pin like the one shown it is only a ball early type. Mine came out when I was doing work in the cab area I pull the gear stick back then it went loose. At the time I had my engine out. Is it just a case of re-aligning the ball & rod recess and bolt it up
PostPosted: Mon Jul 08, 2013 3:57 pm    Post subject: Reply with quote
^^^^ Yes.
dave1
dave1 is offline
PostPosted: Mon Jul 08, 2013 4:35 pm    Post subject: gear stick problems Reply with quote
Hi
what way round does the plate go that has the slope, left or right
cheers
PostPosted: Mon Jul 08, 2013 4:39 pm    Post subject: Reply with quote
Not a Bus but same thing
dave1
dave1 is offline
PostPosted: Tue Jul 09, 2013 8:54 am    Post subject: LHD 58 KOMBI GEAR STICK PROBLEM Reply with quote
Hi
Would anyone have a diagram to show of an early van gear stick lower plate
Thanks again
Dave
PostPosted: Tue Jul 09, 2013 9:41 am    Post subject: Reply with quote
Found these in the Gallery:
More:
http://www.thesamba.com/vw/forum/album_search.php?search_keywords=1959+bus+shifter
dave1
dave1 is offline
PostPosted: Wed Jul 10, 2013 2:35 am    Post subject: LHD 58 KOMBI GEAR STICK PROBLEM Reply with quote
Everett thank you for your help
Dave
