My 69 Kombi build
Breck
Breck is offline
PostPosted: Fri Jul 12, 2013 1:48 am    Post subject: Reply with quote
Hello all, Does anyone know what type/size thread is on a standard bus shift knob??
Ian: 69 Kombi Delux
justcruzin
justcruzin is offline
PostPosted: Fri Jul 12, 2013 8:49 am    Post subject: Reply with quote
Yes!
M12-1.5
We have the tap if you want to make your own ball. Very Happy
Kim
Sacramento, CA
1964 Split Window Bus
1966 Beetle Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=472933
1969 Delivery Van= http://www.thesamba.com/vw/forum/viewtopic.php?t=566282
1970 Westy Build Thread= http://www.thesamba.com/vw/forum/viewtopic.php?t=479538
1971 Squareback Build Thread = http://www.thesamba.com/vw/forum/viewtopic.php?p=6652459#6652459
1970 Single Cab, Samson = http://www.thesamba.com/vw/forum/viewtopic.php?p=8022609#8022609
Breck
Breck is offline
PostPosted: Fri Jul 12, 2013 11:21 pm    Post subject: Reply with quote
What the heck one million people on the samba and I get my answer form one of my local peeps... thanks Kim.....It seems that once you put fiberglass to your bus folks stop talking to you!!! Shocked Sad Shocked
Ian: 69 Kombi Delux
Red Fau Veh
Red Fau Veh is offline
PostPosted: Sat Jul 13, 2013 7:46 am    Post subject: Reply with quote
Not true, folks use all kinds of stuff to fix those floors. I personally use newspaper and por 15, then bondo, works way good at keeping my feet off the asphalt. Very Happy
1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote:
Swivel Seat panels are for people with no friends Crying or Very sad
justcruzin
PostPosted: Sat Jul 13, 2013 4:25 pm    Post subject: Reply with quote
Yah, and generally if the question was answered right, then there is no need for others to post the answer. Very Happy So I guess that means I was right. Very Happy
I actually went to Emigh hardware a while ago to find the thread pitch and all. I was buying glass shifter balls and had to ad my own nut to them to fit my shifter. That's the only reason I knew the answer. LOL Very Happy
Kim
Sacramento, CA
Breck
Breck is offline
PostPosted: Sat Jul 13, 2013 9:59 pm    Post subject: Reply with quote
Never thought of making paper mache with por-15....Nice I like it!!
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Tue Jul 16, 2013 12:32 pm    Post subject: Reply with quote
Took the bus out for a 471 mile trip down the Ca coast yesterday. I will post the details in another thread. Here is a picture of the first layer of Herculiner.
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Tue Jul 16, 2013 4:46 pm    Post subject: Reply with quote
Second coat down. Sorry about the date on the photo. My good camera died and I have not figured out how to change it on this one. Date is today 7/16/13
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Tue Jul 16, 2013 4:49 pm    Post subject: Reply with quote
same deal bad date on photo 7/16/13
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Wed Jul 17, 2013 7:47 am    Post subject: Reply with quote
Front kick panels, carpet and sapphire blue door panels due in today. I can't wait!!!!
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Wed Jul 17, 2013 9:46 pm    Post subject: Reply with quote
Big let down by the fedex guy today. only the carpet came, kick panels and door panels still back ordered!!
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Wed Jul 17, 2013 10:04 pm    Post subject: Reply with quote
Here is a picture with new carpet. The carpet and the Herculiner work very well together. The rubber tackyness of the liner holds the carpet in place. Once the heat allows the carpet to rest the ripples will smooth out.
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Wed Jul 17, 2013 10:07 pm    Post subject: Reply with quote
While it is true that one day I may be referred as the PO. I still find it amazing the things that people do. It appears that the PO put the carpet down with liquid nails..Uhggggg. 1.5 hours of scraping!!
Ian: 69 Kombi Delux
Breck
Breck is offline
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Thu Jul 18, 2013 10:08 pm    Post subject: Reply with quote
I have a bug up for sale here on the Samba and the calls have held up any work on the bus!! Embarassed
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Fri Jul 19, 2013 7:58 am    Post subject: Reply with quote
Motor question, valves set, points set, timing set, if all are perfect and you get the occasional backfire on deceleration could this be a fuel air mixture problem?
Ian: 69 Kombi Delux
justcruzin
PostPosted: Fri Jul 19, 2013 10:41 am    Post subject: Reply with quote
Tighten all your exhaust bolts. Usually backfire on deceleration is an exhaust leak. When I first go my bus it did the same thing, I replaced all the seals on the heater boxes and exhaust and the problem went away for a long time. Just started doing it again just before I changed motors so I didn't worry about replacing seals again. Very Happy
Kim
Sacramento, CA
Breck
Breck is offline
PostPosted: Sat Jul 20, 2013 4:27 am    Post subject: Reply with quote
Can this be the only cause or can a rich mixture also be the culprit??
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Mon Jul 22, 2013 2:10 pm    Post subject: Reply with quote
I have finally got all the carpet and sound dampaning material out of the back top deck, what a pita!!! The area at the back the liquid nails was hard and chipped when scrapped, however at the front it is still semi soft and a total mess. Pics soon.
Ian: 69 Kombi Delux
Breck
Breck is offline
PostPosted: Wed Jul 24, 2013 7:15 am    Post subject: Reply with quote
Some quick updates. I got the back clean after a lot of scrapping, I then decided that it was time to pull the motor and reseal it to stop the leak. It really only appears to be leaking from the front main seal but since I dont know the motor I thought it best to go thru it. I took the bus to my friends house to use his lift and took it apart, as suspected the rear seal had a nick causing the leak, My cylinder tins were both cracked so I bought new ones and prepped and painted them before putting it all back together. After some friendly persuasion the tins were in place and the motor is ready for install. The PO told me that the motor had less than 10000 miles on a rebuild and by what we found I suspect that this is a true statement, It looks to be a long block built by JCS (stamped on the heads). I have read both good and bad stuff here on the samba about this builder, lets hope that I fall into the good category!!! Here are some pics.
Ian: 69 Kombi Delux
Page 3 of 5
