schoonerman Samba Member
Posted: Sun Jul 07, 2013 1:07 pm Post subject: Stumped: starter screech, hesitation |
My friends automatic 1986 vanagon has had this problem since before a GW 2.2 was put in and the transmission overhauled
Problem...
A screech on initial start
A hesitation sometimes on start, not always
Has replaced starter 3 times, same problem every time, after two years the last starter just packed up, a re-con by Wilson.
Things done..
Replaced starter with a Bosch from Germany$$$$$
Replaced battery
Replaced ignition switch
Installed easy start relay for solenoid
Cleaned ALL grounds
Jumped the main cable from battery+ to starter.
Jumped the ground - from battery direct to starter.
Sat down scratched head had a beer
The engine starts ok, but at the end of the start is where the screech is, maybe it's normal on AT's, as my standard shift van doesn't do it.
Thanks for any input
Mike[vimeo][/vimeo] _________________ 87 Westy/Vanagon |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Jul 08, 2013 6:58 am Post subject: |
Sounds like it's time to snug up your alternator belt.
They stretch a bit after installed & start to slip, hence the screech
Why so many starters? Was it NOT starting? _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
insyncro Banned
Posted: Mon Jul 08, 2013 7:09 am Post subject: |
When any of the (4) bellhousing to engine fasteners are loose and or the (2) holding the starter in place are loose or unequally torqued, the starter will be misaligned with the flywheel or torque convertor while starting and make a sound that you do not want to hear.
Worth a look and retorque if you ask me. |
Posted: Tue Jul 09, 2013 9:41 pm Post subject: |
Thanks for the idea's Guy's
The van is in the transmission shop as the newly recon tranny sprang a leak/
so I wont be able to check them out.
Thanks again
Mike _________________ 87 Westy/Vanagon |
