Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Mon Jul 08, 2013 9:00 pm Post subject: 205/75 r15 tires |
My 1963 camper has 15 inch (not the stock 14 inch) bus wheels with 185/65 r15 tires on them. The front tires are pretty worn and I have an extra set of four painted 15 inch bus wheels, and I want to mount 205/75 r15 tires (a new set of extra tires came with the double door that I bought) on them. Will these fit alright inside the body? _________________ Don't worry; be happy. (Baba) |
61TXghia Samba Member
Joined: July 17, 2009 Posts: 950 Location: El Paso, TX
Posted: Mon Jul 08, 2013 9:04 pm Post subject: |
will work just fine, I used to run that size tire. From the gallery:
_________________ 62 Standard Type 2 (Nothing Fancy)
my bus: http://www.thesamba.com/vw/forum/viewtopic.php?t=464719
bill may wrote: |
Camping is cheaper than therapy. |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
G-wood Todd Samba Member
Joined: January 11, 2005 Posts: 1047 Location: Colorado
tyzel Samba Member
Posted: Mon Jul 08, 2013 11:00 pm Post subject: |
They'll fit just fine, I run 215/75/15's on my 62 no prob. As posted above definetely check out the link!!
Clara Samba Member
Posted: Mon Jul 08, 2013 11:01 pm Post subject: |
You have bug size tires on there now, which are shorter than bus tires.
205 75 15s are the same diameter as the stock 6.40 -15s that the 55-63 buses came with, but wider. This means the speedometer should read accurate with these tires. they are wider than stock, but do fit.
I would not run a wider tire on my 61 with the flat wheel wells.
for example:
tyzel Samba Member
Posted: Mon Jul 08, 2013 11:06 pm Post subject: |
With a 63 the 205's will be fine to get on and off with the lipped wells, the 215's you have to wiggle in there on the rear with the flat well. |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Tue Jul 09, 2013 11:00 pm Post subject: |
I have them on my Dc . I lowered my rear a notch. Now I have to deflate rear tires to remove & install. other than that a great tire choice .from above stock height you shouldn't have any issues. I also like the tires that the shasta buses use. _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Clara Samba Member
Posted: Wed Jul 10, 2013 9:03 am Post subject: |
tyzel wrote: |
by 'wiggle', you mean you can do that if you want your wheel wells stretching. |
conrad1468 Samba Member
Joined: December 20, 2003 Posts: 1019 Location: Jeannette, PA 15644
