insyncro Banned
Posted: Fri Jul 12, 2013 7:02 am Post subject: |
Thank you for you dedication JackBombay.
Your product is awesome |
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Fri Jul 12, 2013 10:28 am Post subject: |
SOT - Slightly Off Topic . . .
The rise of 3D printing will mean you can make plastic items like the SA grill and Terra Wagen fender flares in your own garage or local Maker Space in under an hour and for a few bucks of plastic.
So, if you think those items are overpriced, get out there and "print" your own.
3D printing will soon be as common as having an inkjet in your home office, and cost about the same to use.
CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
r39o Samba Polizei
Posted: Fri Jul 12, 2013 10:34 am Post subject: |
I have been 3d printing. The $2000 printer I have been using can only make small things.......a fender flare is out of the question. Small parts, like a Syncro knob bezel is about as big as it gets.
Dream on........ _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Fri Jul 12, 2013 10:38 am Post subject: 3D |
r39o wrote: |
Dream on........ |
It will happen soon, technology is on the fast track! _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
Posted: Fri Jul 12, 2013 10:54 am Post subject: 3d |
Z Corp Spectrum Z510 3D Printer
Seller information
ootigoo (6 )
Item condition:Used
Price:US $16,000.00
Will do 10-14-8 inches the next one up will do 20-15-9 I think were in the fender flare size! Wait a year the cost will fall just like it did on computers _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
Zero419 Samba Member
Posted: Fri Jul 12, 2013 11:09 am Post subject: |
you have to know how to model.
you cant just plug it into your brain and say "I want that".
Back on topic.
GAS! _________________ 1987 Westy Auto Bostig 2.0 Ztec |
tam_shops Samba Member
Joined: November 15, 2012 Posts: 1530 Location: Vancouver BC
Posted: Fri Jul 12, 2013 12:39 pm Post subject: |
SCORE! $4 here, but this size and style if anyone else is wondering. That, and a touch of crazy glue on each and and Voila! I just saved $36. Should add that one end has to be up while the other sideways before you glue it...
Thank you Alistair!
http://www.homedepot.com/p/5-16-in-x-9-3-8-in-Zinc...eBaGW3AETA
Any drawbacks to doing this, rather than the other, hand made one(s)? It will certainly work for the summer, but once I'm back at school, should be able to find a student to make me the other one if needed...
tam
ragnarhairybreeks wrote: |
I know, you can use a $5 turnbuckle to so the same thing, but the argument still is valid.
alistair |
_________________ 1987 Vanagon Westfalia GL Automatic
Making it special:
http://www.thesamba.com/vw/forum/viewtopic.php?t=545885 |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Jul 12, 2013 3:43 pm Post subject: |
$4 turnbuckle...extravagance! Here's mine @ $0.37:
But then again, I'm the guy that brought you the DIY pilot bearing puller...
...the DIY flywheel lock:
...and the $12 Jeep front blower resistor:
_________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Fri Jul 12, 2013 4:45 pm Post subject: |
dhaavers wrote: |
When the apocalypse comes you will be invited to live in my castle!
insyncro wrote: |
Your welcome _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
Posted: Fri Jul 12, 2013 8:23 pm Post subject: |
^^^ Thanks for the invite! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Fri Jul 12, 2013 8:30 pm Post subject: |
On 3d printing... Our Alaris 30 printer was a cool $50K, carries a $3000/year maintenance contract and eats UV cured monomer at $600/litre. Way cheaper to buy the injection molded parts!! At least for the next few years...
Love the printer for what it is...just not cheap to run. _________________ Cheers,
Dennis Wood
The Grape |
Chuey Samba Member
Joined: October 18, 2010 Posts: 855 Location: Oceanside, California
Posted: Fri Jul 12, 2013 9:28 pm Post subject: |
The bent bolt has tons of rustic charm. More than the bent sheet metal part and way more than the turnbuckle. That said, since a Vanagon is pretty much 100% rustic charm to begin with, anything will do, won't it?
Chuey |
Posted: Fri Jul 12, 2013 11:06 pm Post subject: |
Screw the apocalypse, can you come now? 3 youtube videos, 2 forums and at least 3 hours later, I finally adjusted my son's bike brakes, stupid side pull brakes, no idea who invited them, but I want to shoot him. Unlike the centre pull brakes you can't easily adjust these. And, I'm guessing you could have fixed it after the first 3min clip. My problem, over tightened.
Seriously, why the screw and not just bend the bolt end around more? I'm going to guess the screw end goes on the Vanagon and head of bolt in the door.
The turnbuckle works b/c the hook fits in the Vanagon side and the loop fits in the door side. My glue dried. I'm thrilled! If you didn't just post an under $1.00 idea, I'd have gone and bought a second one, so I can have an open a bit one and open a lot!
tam
jackbombay wrote: |
dhaavers wrote: |
insyncro wrote: |
Your welcome |
Making it special:
Microbusdeluxe Samba Member
Joined: July 26, 2003 Posts: 980 Location: Bellingham, WA
Posted: Sat Jul 13, 2013 9:57 am Post subject: |
Jake Raby air-cooled 2000cc "Camper Special" motor. I imagine it IS a high quality item, but $12,000!? (no there is not an extra zero there). Come on. _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
whynotvw Samba Member
Posted: Sat Jul 13, 2013 11:49 am Post subject: |
1. Aftermarket bumpers $900
2. Rear Tire carrier $600
3. Rear storage box/swing away attachments $1000
4. South African lights $500
5. Suby conversion $6000
6. Recaro seats $1400 bought used $500
But worth every Penny. |
nemobuscaptain Samba Member
insyncro Banned
Posted: Sat Jul 13, 2013 12:18 pm Post subject: |
denwood wrote: |
Love the printer for what it is...just not cheap to run. |
Word.
Sure a few bushings, knobs and interior parts could be whipped up in short order....unfortunately many feel the need to make gun parts from them.
That should raise a few eyebrows and limit what will be made available to common folk
Not in agreement that the Terra Flares are anywhere near overpriced
I feel the need to also state that if a new vendor like Terra is going to continue producing very high quality pieces....they need to be supported.
Put some energy into earning a little extra coin and pop for some flares so they can move on to the next knockout product....not try and figure out how to make a similar homebrew to save change.
Just sharing, enjoy your weekend. |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Sat Jul 13, 2013 5:39 pm Post subject: |
Microbusdeluxe wrote: |
Jake Raby air-cooled 2000cc "Camper Special" motor. I imagine it IS a high quality item, but $12,000!? (no there is not an extra zero there). Come on. |
Sold three CS engines in the past two weeks. Those people know the definition of value and appreciate it enough to pay the price of admission.
Leaving the "extra zero" out wouldn't even buy one of the cylinder heads for this engine.
We of course still create aircooled engines, we simply added the suby conversions to the line up for the future. Quality ACVW parts are hard to find, hence the 12K price of the CS engine.
If you think the aircooled CS engine is expensive, looking at the price tag of my complete Suby drivetrain package would give you a heart attack and a stroke at the same time. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
a2d2 Samba Member
Joined: March 28, 2013 Posts: 366 Location: EastVanagon, BC
Posted: Sat Jul 13, 2013 7:07 pm Post subject: |
Most Outrageously Priced Aftermarket Item?
Cross border shipping charges!
No matter how hard we Canadians try to pool our orders there will always be at least one little thing we will forget that will cost us $40 more than it should when we have to place another order.
That being said, yesterday the FLAPS quoted me $85, "even after your discount", for a 2.0 CHT sensor... BD has the same part # for $16.95. _________________ 1981 Vanagon, Aircooled 2.0 AFC
1978 Baywindow Bus (R.I.P.) |
