kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Thu Jul 11, 2013 9:24 am Post subject: Ughhhhh...Heater Cable Stuck |
Changing out my heater cables ('67). The left one came one nicely, but the right side one jammed about 18" from the end...right where it goes over the torsion bar (upward curve). Now it won't go forward or backward other than about for an inch. Gonna try pumping PB Blaster in there, but not real hopeful. Read a couple of threads. on bay window buses, and it seem that the right side is the one that sometimes hangs up. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Thu Jul 11, 2013 10:20 am Post subject: |
Did you cut off the larger end of the cable first, if it was still attached?
The tubes are often plugged with grease and dirt build-up so if the end is still there, you need to cut them off first or they could get stuck.
Unfortunately this doesn't help you now.
The PB Blaster might break it down though.
Maybe blast some air from a compressor from the front too. _________________ How to Post Photos
Posted: Thu Jul 11, 2013 11:00 am Post subject: |
Yeah...too late now. Thought if that too late. |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Thu Jul 11, 2013 12:36 pm Post subject: |
If it is being held in place by petrified grease, the judicious application of heat may help soften it and cause the cable to let go. I would recommend a heat gun over open flame as you don't need THAT much heat and you don't want to get undercoating or paint burning. |
Posted: Thu Jul 11, 2013 12:40 pm Post subject: |
Thanks. Ill give it a shot. I figure...worst case scenario...I slice out a section and fit a cylinder or hose over that section. |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Thu Jul 11, 2013 1:29 pm Post subject: |
kenshapiro2002 wrote: |
I had to do that on my Mango, but I don't recommend it.
As long as your cable is still moving, you are not dead in the water.
Keep worrking that baby and it WILL free up. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Thu Jul 11, 2013 1:31 pm Post subject: |
Appreciate the encouragement. |
Posted: Thu Jul 11, 2013 3:05 pm Post subject: |
My best guess, since there were no seals on the ends of the cables, is that a chuck of old seal was in there and got dragged up the "hill" over the torsion tube. Been suing PB and heat for a few hours to no avail. I'll give it time. |
Brokenbus Samba Member
Posted: Thu Jul 11, 2013 3:51 pm Post subject: |
You won't need heat for several months so try attacking it from the back end with something not quite as thick as a coat hanger. Leaving the end piece on was a good idea because it will help clear the blockage. If you can manage to run a piece of .032 safety wire the entire length of the tube you can pull the new one thru that way. maybe. |
2Pack Samba Member
Joined: September 20, 2005 Posts: 807 Location: Virginia
Posted: Thu Jul 11, 2013 3:56 pm Post subject: |
Two thoughts:
- If you had a flexible tube that is just larger than the cable end, you might be able to feed it in over the cable. Once you got it over the cable end you would just have to pull out the flexible tube, which has less chance of snagging.
- You might try rotating the cable slowly with a drill as you tug to see if that helps. Risky though because you might break the cable. _________________ Please buy my Treasure |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jul 11, 2013 6:14 pm Post subject: |
How about just jacking up the front end and dripping penetrating oil down thru the front of the tubes? _________________ In Stereo, Where Available! |
Posted: Thu Jul 11, 2013 6:23 pm Post subject: |
Eric&Barb wrote: |
How about just jacking up the front end and dripping penetrating oil down thru the front of the tubes? |
That's what's been going on all afternoon...PB Blaster. Even boiling it out the back end (so it's going down there) when I use the heat gun. |
dawerks Samba Member
Posted: Thu Jul 11, 2013 6:46 pm Post subject: |
It happens to lots of those random tubes. I usually go at it with a small drill bit, and drill some small holes in a row. Then you can see what's the hold up and get RIGHT in there.
Cutting the tubes works, but then it's hard to weld the top part of the tube back up. I can live with tiny holes 'just in case', and it's another spot to add a bit of grease _________________ "There is only one sin; disconnection from self." |
Posted: Thu Jul 11, 2013 6:54 pm Post subject: |
dawerks wrote: |
Cutting the tubes works, but then it's hard to weld the top part of the tube back up. I can live with tiny holes 'just in case', and it's another spot to add a bit of grease |
Not a bad idea. I'd thought about using a tubing cutter to remove a section and then just reattaching it with hose clamps. That's "if" my soaking, heating and cursing don't work over the next few days. |
Posted: Fri Jul 12, 2013 9:33 am Post subject: |
Used the tubing cutter about 4" forward of the torsion tube. Pulled the cable out from the front. So now I have the end piece and about 3" of cable still in there contemplating my next cut/move. Making another cut and removing that section is easy...gonna see if I can do something else. |
