vwfye Samba Member
Posted: Mon Nov 17, 2003 12:24 pm Post subject: still haven't received my bus bentley yet... sooo... |
can anyone tell me the total advance for a 1.8L with an 009? also, is the t4 firing order that of the earlier motors? i.e. 1-4-3-2 or is it 1-3-4-2? thanks! |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Mon Nov 17, 2003 12:26 pm Post subject: |
No bus left the factory with a 009 so the bentley won't have any information on it.
The firing order is 1-4-3-2. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
vwfye Samba Member
Posted: Mon Nov 17, 2003 12:42 pm Post subject: |
bad wording on my part. since i have an 009 on it, i need to know the max advance on a 1.8L motor. thanks |
Posted: Mon Nov 17, 2003 2:40 pm Post subject: |
Those engines like 7.5 BTDC advance at idle. All other values (TDC, 5 ATDC, 10ATDC) are smog settings.
The 009 advances 22-24 degreed maximum so the total advance from 7.5 would be about 30-32 degrees. _________________ '78 Westfalia CDN
'76 Doublecab
vwfye Samba Member
Posted: Mon Nov 17, 2003 3:19 pm Post subject: |
initial timing is not my question. what is the max advance allowable on a 1.8L? is is 28, 30, 32, 40? |
wgargan Samba Member
Joined: September 21, 2002 Posts: 871 Location: Dreaming of the Rockies
Posted: Mon Nov 17, 2003 8:48 pm Post subject: |
69 _________________ Current ride:
1983.5 Watercooled Vanagon 'L' Automatic transmission |
Posted: Mon Nov 17, 2003 8:49 pm Post subject: |
Posted: Tue Nov 18, 2003 12:13 am Post subject: |
Looking at the stock distributors for the years that the 1800 was available and taking into account the mechanical and vacuum advance it appears 44-45 is the answer.
Because of the limited advance of the 009 you have to run your idle advance at 20-23 degrees to get the most out of it. Doesn't seem ideal. _________________ '78 Westfalia CDN
'76 Doublecab
