JKing'63 Samba Member
Joined: February 23, 2012 Posts: 56 Location: Anaheim, Ca
Posted: Tue Jul 16, 2013 11:35 am Post subject: |
Might give that a shot.. I'm not a very small guy, so we'll see how it looks once I'm under there |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Mon Jul 15, 2013 3:43 pm Post subject: |
Just lift the car up on jack stands and take the starter off - you should be able to get a tap on the bushing without bending your wrist beyond 90 degrees. |
Posted: Mon Jul 15, 2013 2:41 pm Post subject: |
That's a thought... but with the location of it all, it might be easier to take the engine out haha
I've just removed and re-installed motors in this thing 3 times in the past month... it really isn't THAT big of a deal, but I'd rather not... you always hope the last time was the LAST time ya know |
Posted: Mon Jul 15, 2013 8:09 am Post subject: |
You might try to remove the bushing. All my factory service manual says about the procedure is, "remove bush", leading me to suspect it may pull right out with a giant easy-out or the proper size tap. Just thread it in, grip, and pull.
Then you could install a 6V starter and the proper bushing. Soak the new bushing in hot oil and drive it in with a pilot pin. |
Posted: Mon Jul 15, 2013 7:54 am Post subject: |
Guess my next step is it pull the motor, again! haha
If I get in there and find that it does have a 12V flywheel then I'm selling the car (haha!) no I'm kidding....
but thanks a lot guys, hopefully I can get this settled |
HRVW Samba Member
Joined: May 01, 2011 Posts: 2531 Location: Rosarito, Mexico
Posted: Mon Jul 15, 2013 7:42 am Post subject: |
As a builder of over 1000 VW engines can attest to what would be correct.
The later 1600cc engines 69mm crank will NOT accept the 6V 180mm flywheel with the exception of the 66 transporter which had a 6V 200mm flywheel. The starter gear has to mate with the correct flywheel teeth or it will GROWL.
I made conversions in the early 70's.
A 6V starter needs the correct bushing support for it to work with a 180mm 6V flywheel.
A 12V starter needs the correct bushing support for it to work with a 200mm 12V flywheel.
I have seen a lot of chewed up 6V flywheels because someone converted their 6V car to a 12V system and used a 12V starter damaging the 6V flywheel. |
Posted: Sun Jul 14, 2013 7:52 pm Post subject: |
Harleyelf wrote: |
So if he puts a 6V starter in and the bushing is incorrect, the teeth will not engage because the armature will bang against the bushing and not enter it?
Were there any 6V auto starters made? |
this was my thinking as well....
so ultimately, I know I have a 12V starter and bushing... if I have a 6V flywheel on the new motor then I would need a 6V starter to stop that noise... which I can't do...
so I'm guessing the only answer to stop the scream would be to pull the motor and change the flywheel to 12V...? |
wayne1230cars Samba Member
Posted: Sun Jul 14, 2013 7:22 pm Post subject: |
Harleyelf wrote: |
I believe there was such a thing, SR13X but not very common at all. Maybe 1966 era?? _________________ 1960 beetle
1970 beetle convertible |
Posted: Sun Jul 14, 2013 5:07 pm Post subject: |
HRVW Samba Member
Posted: Sun Jul 14, 2013 3:06 pm Post subject: |
Both the 6V and 12V starters have a floating armature that has to be supported by the bushing in the trans bell housing.
The 6V bushing has a larger ID while the 12V starter end has a smaller dia and will move around thus NOT meshing with the flywheel teeth.
Best bet is the SR17X (auto) starter with no bushing problems to contend with.
VW Mechanic (retired) |
Posted: Sun Jul 14, 2013 2:04 pm Post subject: |
It's the brass bushing the end of the starter shaft goes into. I'm not sure how to remove & replace it with the engine/transmission installed or if it is possible to modify the 6V starter to fit the 12V bushing.
Autostickshift starters don't use the bushing. You may have the correct bushing already and it could be a contributing factor to the scream |
Posted: Sun Jul 14, 2013 1:47 pm Post subject: |
no pulling the engine would be my first choice!
so maybe try a 6V starter and see what that does?
and theres an adapter ring or something for 6V/12V in the starter housing I would have to remove right...? |
Posted: Sun Jul 14, 2013 1:25 pm Post subject: |
Yes, any mismatch between starter and ring gear will make the starter scream and have difficulty disengaging.
Got a flywheel locking tool? The wide side is for 12V and the shorter side is for 6V. Or you could use a dial caliper to compare the distance between teeth on the flywheel and starter. A 6V starter will work for years on 12V, if you want the no-pull-engine fix. Spins at double speed. |
Posted: Sun Jul 14, 2013 1:18 pm Post subject: |
HRVW wrote: |
Okay....we have a 12V (200mm) flywheel on a 1641cc engine in a early 63 bug.....originally a 6V.
Engine fits inside the bell housing means trans was clearance.
Noise (screaming) is actually a growling only heard at first start up and NOT heard when driving means that the starter is a 6V (180mm flywheel) and the flywheel is a (200mm) that needs a 12V starter.
6V flywheel.......109 teeth
12V flywheel......130 teeth
Starter and flywheel need to match or you will have a screaming or growling sound.
There's one of my issues, I'm not 100% sure if it's a 12V or 6V flywheel... and my starter is 12V, so that wouldn't be the fix...
Now would a 6V flywheel paired with a 12V starter be causing the scream/growl? |
Posted: Sun Jul 14, 2013 1:15 pm Post subject: |
Dr OnHolliday wrote: |
what does your flywheel ring gear look like? How about the starters? (pics might help).
Sounds like your starter gear is just getting caught and staying engaged with the engine and over-reving. Maybe the starter motor shaft is sticky / grungy and slowing down the disengage? |
I'll have to take pictures when I take the starter off again. But yes, I was thinkin the same thing about the shaft just getting stuck, because it definitely sounds like it's just engaging a second too long and then it's off |
HRVW Samba Member
Posted: Sun Jul 14, 2013 12:54 pm Post subject: |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Sun Jul 14, 2013 12:21 pm Post subject: |
Sounds like your starter gear is just getting caught and staying engaged with the engine and over-reving. Maybe the starter motor shaft is sticky / grungy and slowing down the disengage? _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Sun Jul 14, 2013 11:08 am Post subject: |
I would think that I would hear the scream constantly if it was a clearance issue in there right? |
Posted: Sun Jul 14, 2013 11:06 am Post subject: |
Hey drs1023. So in your experience the motor wouldn't even mount up to the tranny? because mine mounts up fine and runs and drives....
the only time I hear the scream is right when the motor turns over, and it's real quick... otherwise while it drives I can't hear any problems
If it's not the clearance in the bellhousing, any ideas as to what it might be? |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Sun Jul 14, 2013 8:35 am Post subject: |
It's not too hard to clearance the bell housing, but I doubt that's the issue. I recently clearanced another transaxle for the larger flywheel - I have done it a few times because I like the increased surface area of the larger clutch and pressure plate as compared to the "6V versions".
I have never installed a larger flywheel into the smaller bell housing without having to clear it. It just won't fit, so, either the bell housing has already been cleared, or the previous engine was using the 6V flywheel. The pictures show some of the contact points of the larger flywheel in my '63 transmission which had to be ground out. Also notice that I used the auto-stick starter because there's no bushing needed.
A quick guide to clearancing the bell housing:
1) Install the engine with the larger flywheel as far as it will go (level!) and start all the bolts you can - use longer ones on top if needed to just hold the engine in place - DO NOT TIGHTEN the bolts.
2) If you can't turn the engine by the pulley bolt, back it out a smidge and turn the pulley bolt a few times to score the outline of the clearances needed.
3) Tighten the bolts a turn or two and repeat.
4) Tighten the bolts a turn or two and repeat, etc. etc.
5) When the flywheel teeth are inside the bell housing, turn the pulley bolt a couple of good turns to make sure all score marks are in place.
6) Remove the engine and finish clearancing with a die grinder with a coarse bit. Others will tell you that using a grinder may cause sparks, and sparks and magnesium don't play well together. |
