6 volt 1500 Install - what's involved?
DeVertible
DeVertible is offline
PostPosted: Sun Jul 14, 2013 9:25 am    Post subject: 6 volt 1500 Install - what's involved? Reply with quote
I read a lot about converting a 6 volt pre 1967 car to 12 volts but what about installing a 67-69 single port in a pre 1967 type 1? can I retain the 6 volt system and if so what is involved? Thanks
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Jul 14, 2013 3:34 pm    Post subject: Reply with quote
Mostly installing the early 6 volt generator, and its stand.
Make sure you use the right sized cooling fan for the later engine.
In Stereo, Where Available!
Dangermouse
Dangermouse is offline
PostPosted: Sun Jul 14, 2013 4:54 pm    Post subject: Reply with quote
Some more pointer here? http://www.thesamba.com/vw/forum/viewtopic.php?t=478202
Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you.
DeVertible
PostPosted: Sun Jul 14, 2013 6:04 pm    Post subject: Reply with quote
Thanks for steering me toward the "previous posted posts on the subject" that I could not find and thanks for the added information. Not sure what year would have a 200mm 6 volt flywheel but I can only a assume 1966 1300. Anyone know that answer for sure?
I would very much like to replace my 1965 40 hp with my first choice a 1966 1300 if I can find one or a 1500 which seems like a more likely "can do" if I can find the right flywheel to mate the 1500 crank and a 6 volt starter, or . . . did I read correct that a 6 volt flywheels fit 1500 but not vice versa. At this point I feel a bit stupid asking but I do know things rarely go as smoothly as one might hope when doing swaps. Just want to do my homework before I go out and buy a bunch of useless parts.
Eric&Barb
PostPosted: Sun Jul 14, 2013 6:53 pm    Post subject: Reply with quote
To be sure which your engine has requires removing the engine and counting flywheel teeth, or if you have a helper, remove starter and count teeth as helper turns engine by hand. The latter is easier if you remove the spark plugs.
