58Dub Samba Member
Joined: June 02, 2004 Posts: 1713 Location: Davison, MI
Posted: Sun Jul 21, 2013 2:10 pm Post subject: trans leaking...need some advice |
OK....Im very much a newbie when it comes to messing with the trans. I'm pulling a IRS trans out of a 70 bug. when I pulled the drivers side CV off at the trans, it appears the trans fluid has been leaking into the CV. The rubber/plastic cap that goes over the spline shaft that the CV attaches to was off....and the joint seemed to be filled with a mix of grease and gear oil.
Is this an easy fix??
thanks for any info
Matt _________________ 58 Beetle (now just a pile of parts in the corner)
60 Beetle (2221 turbo under construction)
70 Beetle Baja project |
JerryB Samba Member
Posted: Sun Jul 21, 2013 10:17 pm Post subject: |
Over the years, the CV grease has broke down and gets kinda runny. if you have a leak in the side cover seal in back of the companion flange of the trans, there might be a mixture because of slinging grease and oil around. Possibly tho its just the CV grease over everything.
Torn boot. And possibly a leaking side cover seal as above/\ /\.
First, remove the rear wheel then you might pressure wash or clean all the grease and oil off. Remove the affected axle, replace the boot that's torn and also the boot on the other end unless it was fairly new. Check the CV with the torn boot carefully for lack of grease.....galling, heat etc. as it might need to be replaced. Search on the details. Then you should look carefully behind the CV flange on the side cover and see if gear lube has leaked from the seal area. You will smell the sulfer smell if it is gear lube. If so replace the seal. GKN Lobro CV kits and boot kits are best but they cost a fair bit more than the "offshore" parts. |
58Dub Samba Member
Posted: Mon Jul 22, 2013 1:59 am Post subject: |
JerryB wrote: |
Thanks JerryB
The bots were not torn....When I removed the drivers cv joint at the trans, there looks like a rubber disc, about the size of a quarter or half dollar. when I look at the passenger side, it looks like it was supposed to be on the spline shaft that holds the CV flange to the trans. I was wondering if that is what stops the trans fluid from leaking out between the flange and the spline shaft. _________________ 58 Beetle (now just a pile of parts in the corner)
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Mon Jul 22, 2013 2:24 am Post subject: |
yep, that rubber disk is the seal. Just need to replace them, It is that simple |
58Dub Samba Member
Posted: Mon Jul 22, 2013 3:49 am Post subject: |
modok wrote: |
Always love it when its a simple fix..
Thanks Modok _________________ 58 Beetle (now just a pile of parts in the corner)
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Mon Jul 22, 2013 4:15 am Post subject: |
Those caps are cheap - get a couple just in case you mess one up, but they just pop in. _________________ D-Dubya Manx clone - 63 Short pan,1914.
