ekimthemad Samba Member
Posted: Thu Jul 25, 2013 3:39 am Post subject: |
You need heat from an acetylene torch. You can't work on cars living in Ohio without one.
Mike _________________ Remember never argue with a moron. They'll drag you down to their level and beat you with a lifetime's worth of experince. |
Jürgen Samba Member
Posted: Thu Jul 25, 2013 6:32 am Post subject: |
The deflection problem is definitely real. A good point. A puller that attaches to the lug holes will eventually work.
A new drum is $50-150, depending on quality. Compare that to the cost of a pulling tool that attaches to the lug holes.
I'd invest in the tool. You can resell it when you're done using it.
Plus, there's nothing quite as satisfying as the CRACK your drum will make when you pull it free. |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Thu Jul 25, 2013 8:19 am Post subject: |
If you are certain that grinding is the way to go, it may be faster to begin with the hub rather than bisecting the entire drum. Whatever is binding is going to be where the axle splines meet the drum splines. When you get the hub ground down to where you can see their meeting place, it may lift right off.
Of course, even that much heat is going to ruin the axle and you will have to replace it. Now we're done trying to save parts and looking to reduce time spent replacing them. |
carcrazed Samba Member
Posted: Thu Jul 25, 2013 5:45 pm Post subject: |
I am looking for a set of torches now. Of all the tools I have, I never bought a set, but now I am go nna get one. I don't have much to lose now than to heat that up hot and see what happens. The drum is pretty much junk now and I am sure the shaft is gonna be unusable. _________________ 1965 Herbie Replica. 1776cc dual Kads.
1961 Beetle 33,000 Original Miles
"Just When you think you are getting ahead, you're always wrong." |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Thu Jul 25, 2013 6:18 pm Post subject: |
May I please ask, is this on the '61 with 33,000 miles? _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
jzjames Samba Member
Joined: September 27, 2007 Posts: 1921 Location: Windy Point, WA
Posted: Thu Jul 25, 2013 9:03 pm Post subject: |
carcrazed wrote: |
The drum is pretty much junk now and I am sure the shaft is gonna be unusable. |
Have you damaged the aforesaid? Why would they be unuseable?
I can see the rust, rust can be like welding when metal parts get together and rust, but once you get it seperated you could certainly clean it up with some emery cloth and be OK. |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Thu Jul 25, 2013 9:24 pm Post subject: |
Are drums cast steel or cast iron? Oxy-acet won't cut ci.... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
Posted: Thu Aug 01, 2013 7:16 am Post subject: |
Yes...this is the 61 with 33,000 miles. Still no luck. I haven't brought myself to cut it off. I keep soaking with PB and puller on the lugs. Hasn't budged at all!! Heat didn't do it either. I have never seen something so stubborn in all my years restoring cars. Gotta love the eastern U.S. for rust! _________________ 1965 Herbie Replica. 1776cc dual Kads.
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Thu Aug 01, 2013 9:18 am Post subject: |
Do you have air tools? If so you may want to try this.
Take about a 1/4" drill bit and on the flat surface of the drum around the axle drill 4 small divits spaced out at 90 degree intervals.
Then get your air hammer out and use a blunt pointed bit. The divits are there to help keep the point of the bit in place while you hammer on it.
Go around to each of the divits a few times and give each one a couple seconds of hammering.
Hopefully the vibration will help it come unstuck. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Thu Aug 01, 2013 7:00 pm Post subject: |
I will definatelyl try that...I don't have much more choices now. _________________ 1965 Herbie Replica. 1776cc dual Kads.
Posted: Thu Aug 15, 2013 11:24 am Post subject: |
Just an update. I tried EVERYTHING and it wouldn't move. I cut that sucker in half and, sure enough, the drum looked like it was part of the shaft. Absolutely no signs of any splines, just looked like one piece of metal. Gotta hate Northeast weather!!
Anyone got a swing axle shaft for sale?? _________________ 1965 Herbie Replica. 1776cc dual Kads.
kirkpwomack Samba Member
Joined: February 05, 2011 Posts: 67 Location: Brookville, Indiana
Posted: Thu Aug 15, 2013 11:33 am Post subject: |
LOL! That thing sounds like it sat in the surf zone... |
Posted: Thu Aug 15, 2013 12:05 pm Post subject: |
Hehe. That's the ferric oxidation method of welding. |
Posted: Thu Aug 15, 2013 3:09 pm Post subject: |
I have never dealt with any parts that stubborn in all my years of restoring cars. Very frustrating. Thank god I have an air oiled shop 5 miles from my house. Hopefully he will have a swing axle shaft laying around _________________ 1965 Herbie Replica. 1776cc dual Kads.
