Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Wed May 24, 2017 3:55 pm Post subject: Re: Advice on Single Cab Purchase |
Just read this whole thread start to finish. Nice job. Hows the truck coming? _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
nice dad Samba Member
Joined: July 25, 2013 Posts: 317 Location: Honolulu, HI
Posted: Fri Jul 28, 2017 12:32 pm Post subject: Re: Advice on Single Cab Purchase |
Master Cylinder is in. Better stop on a dime for the price I paid for that one year only dual circuit BABY!!!!!!!!!!!!!!
_________________ 1967 Single Cab |
Posted: Fri Jul 28, 2017 12:35 pm Post subject: Re: Advice on Single Cab Purchase |
Skim wrote: |
Just read this whole thread start to finish. Nice job. Hows the truck coming? |
Thanks! Well, she runs, drives in and out of the garage and will now stop soon since I just put in that $$$$$ master cylinder.
I need to install the battery tray and mount the oil filter and a bunch of other stuff before I can put her on the street. _________________ 1967 Single Cab |
Posted: Sun Aug 27, 2017 4:29 pm Post subject: Re: Advice on Single Cab Purchase |
Well I installed the one year only master cylinder and whoot we have brakes.
Went to take her down the driveway for a test drive. As I depressed the clutch pedal there came a gnarly grinding noise. Pulled the motor to discover a bent fork arm, signs of grinding on the throwout bearing retaining pins. and metal shavings. Wow, is the pressure plate to heavy for the throw out bearing? Or sized wrong?
There is safety wire installed around the clips because a heard they were notorious for slipping out.
I am so close to getting her on the road, what a bummer. Is there a better set up like HD fork and different retaining clips, etc. Obviously, I don't want this to occur again.
Thanks _________________ 1967 Single Cab |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sun Aug 27, 2017 4:31 pm Post subject: Re: Advice on Single Cab Purchase |
first of all: way too much grease in there! clean all that gunk out of there!
secondly: wrong pressure plate (that's the 71- style), which is what destroyed your clips when you stepped on the clutch. see the shiny ring on the pressure plate and the blue paint shavings in the bellhousing? _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Sun Aug 27, 2017 4:41 pm Post subject: Re: Advice on Single Cab Purchase |
hazetguy wrote: |
thirdly: the arms of the cross shaft are bent, or at least look bent in the pics. |
Thanks for the quick reply.
Yes the fork arms are bent. Ah wonderful to know that is the wrong pressure plate. Ok thanks for that.
Yes the shavings are more than apparent.
Grease will be leaving shortly.
So I am assuming that the same clutch will work with the right pressure plate or should I just purchase a new set up? Obviously, I will need a new cross shaft as well. _________________ 1967 Single Cab |
Posted: Sun Aug 27, 2017 4:46 pm Post subject: Re: Advice on Single Cab Purchase |
you could use the same clutch disc if it's ok and not slathered with grease.
since you're going to replace the pressure plate, i'd recommend putting a new disc in there at the same time (unless the one that was in there is perfect).
also consider a new throwout bearing, as perhaps that's where a lot of that grease came from? hard to tell since the grease is everywhere. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
Posted: Sun Aug 27, 2017 5:00 pm Post subject: Re: Advice on Single Cab Purchase |
hazetguy wrote: |
also consider a new throwout bearing, as perhaps that's where a lot of that grease came from? hard to tell since the grease is everywhere. |
Thanks hazetguy. Much appreciated advice. I see now exactly what happened.
Time to order some parts. _________________ 1967 Single Cab |
GfunkBus76 Samba Member
Joined: October 04, 2004 Posts: 378 Location: Cloverdale, BC, Canada
Posted: Fri Sep 01, 2017 10:48 am Post subject: Re: Advice on Single Cab Purchase |
Cool thread! Nice project for your son... Hope he appreciates it!
Was looking longingly at a rusty 1967 SC.... not sure if your thread has inspired me or frightened me. With limited budget I'll have to skip it for now unfortunately - I'm sure this one would need as much or more than yours did!
Keep it up! Definitely going to be great to have it running and moving on its own for you! _________________ Gavin
1976 Westy - Customzation in slow-progress.
-8V TD swap
It Runs! -- http://youtu.be/kT5hOtwiOgk
And drives! - https://youtu.be/rVkoAgeOop0 |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Tue Dec 05, 2017 4:33 pm Post subject: Re: Advice on Single Cab Purchase |
Most excellent!!
Do slide under in the next day or two, so you can check for any seeps at all the lines joints and the brake backing plates. Hopefully all will be nice and dry! _________________ In Stereo, Where Available! |
Posted: Wed Jun 06, 2018 1:19 pm Post subject: Re: Advice on Single Cab Purchase |
Can someone please confirm that this is indeed a 1967 wiper arm and is correct for my SC. This is the only one that came with the SC when I bought it. I have seen some in the classified section claiming to be 1967 but don't resemble what I have.
Thanks!
Posted: Wed Jun 06, 2018 1:41 pm Post subject: Re: Advice on Single Cab Purchase |
Did a search of the split bus forum for "Wipe Arm". Search box feature near upper left of the forum web page. Checked the "Titles Only" to keep the results from being pages and pages.
Got these:
https://www.thesamba.com/vw/forum/search.php?searc...=titleonly
The hook on the first image is a mystery... _________________ In Stereo, Where Available! |
Posted: Wed Jun 06, 2018 3:08 pm Post subject: Re: Advice on Single Cab Purchase |
Eric&Barb wrote: |
Got these:
The hook on the first image is a mystery... |
Thanks for the search input. Someone may have bent it to fit a more conventional type blade. There was a goodyear plastic wiper on it. _________________ 1967 Single Cab |
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Sat Aug 25, 2018 12:59 pm Post subject: Re: Advice on Single Cab Purchase |
Well, time for another BIG move. From Pittsburgh PA to Honolulu HI. From snowstorms to hurricanes, never a dull moment. Aloha!
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 902 Location: Las Vegas, NV
Posted: Sat Aug 25, 2018 1:22 pm Post subject: Re: Advice on Single Cab Purchase |
nice dad wrote: |
That is a big change in climate. Congrats. Hawaii has a huge VW culture. If you will be there next weekend they have the big Shaka VW car show.
http://www.vwclubofhawaii.com/events/shaka-weekend-2018 _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Mon Oct 08, 2018 2:04 pm Post subject: Re: Advice on Single Cab Purchase |
Well, I am stumped! This darn bulb won't light up. I have power and ground with a new bulb. ? Should this bulb only have a single contact on the bottom? This one has two, just like the original I pulled out to replace. Each contact on the bottom is receiving power. I cleaned the corrosion from all the grounding contacts.
's
Thank you _________________ 1967 Single Cab |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Mon Oct 08, 2018 2:44 pm Post subject: Re: Advice on Single Cab Purchase |
nice dad wrote: |
Well, I am stumped! This darn bulb won't light up. Should this bulb only have a single contact on the bottom? This one has two, just like the original I pulled out to replace. |
6 volt = VW# N177191 .... auto parts store # 1156 (6v 10 Watt BA15s)
12 volt = VW# N177192 .... auto parts store # 1156 (12v 10 Watt BA15s)
_________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
