nice dad Samba Member
Joined: July 25, 2013 Posts: 317 Location: Honolulu, HI
Posted: Mon Oct 08, 2018 2:49 pm Post subject: Re: Advice on Single Cab Purchase |
easy e wrote: |
nice dad wrote: |
Well, I am stumped! This darn bulb won't light up. Should this bulb only have a single contact on the bottom? This one has two, just like the original I pulled out to replace. |
6 volt = VW# N177191 .... auto parts store # 1156 (6v 10 Watt BA15s)
12 volt = VW# N177192 .... auto parts store # 1156 (12v 10 Watt BA15s)
Thanks very much. I read your thread on license light holders, very informative. _________________ 1967 Single Cab |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Mon Oct 08, 2018 4:35 pm Post subject: Re: Advice on Single Cab Purchase |
Is that a single filament bulb??
If it is, that type of bulb needs a ground to one of the bottom contacts, and positive to the other to work. Does not need positive or negative to the brass base. _________________ In Stereo, Where Available! |
Posted: Mon Oct 08, 2018 6:42 pm Post subject: Re: Advice on Single Cab Purchase |
Eric&Barb wrote: |
If it is, that type of bulb needs a ground to one of the bottom contacts, and positive to the other to work. Does not need positive or negative to the brass base. |
Yes it is a single filament bulb with two contacts at the bottom. Someone before me had placed the wrong bulb for the license plate light. I just took it down to the auto parts store and got a replacement. Unfortunately the wrong replacement. I returned the bulb for a single filament/single contact bulb and all is well. Now I just need to ground my taillight buckets and I am all set.
Thanks _________________ 1967 Single Cab |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Wed Oct 10, 2018 7:36 am Post subject: Re: Advice on Single Cab Purchase |
Generally the Blue with green wire goes to the oil pressure switch, the white with red wire should go to the + (bottom) of the bulbm and the bulb holder is grounded on the decklid itself.
I know you said you have it worked out so the light works, but does the oil pressure switch work? |
Posted: Sat Oct 19, 2019 2:41 pm Post subject: Re: Advice on Single Cab Purchase |
Well it is getting there. Decided to leave the patina and just drive it. The old crusty look is appealing. All 4 rusty hub caps for $5.00!
Found a used pointed front bumper, installed the safari's. At the shop getting a safety inspection, next plates.
Posted: Tue Dec 10, 2019 5:30 pm Post subject: Re: Advice on Single Cab Purchase |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Wed Dec 11, 2019 7:01 am Post subject: Re: Advice on Single Cab Purchase |
nice dad wrote: |
I'd buy $1.25 hub caps all day!
Great looking truck! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Huetti_1989 Samba Member
Joined: February 13, 2011 Posts: 1136 Location: Austria
Posted: Mon Feb 22, 2021 3:29 pm Post subject: Re: Advice on Single Cab Purchase |
I friend of mine who developed a cool clothing line asked if she could use the SC in a photo shoot for her catalogue using models from Brazil. How could I say no. The guy with the birds can be seen on the Waikiki strip regularly entertaining tourist. His birds were very friendly but the models were skeptical about handling them. Nice day at the park.
