WiboBusMan Samba Member
Joined: September 26, 2009 Posts: 141 Location: Canada
Posted: Thu Aug 01, 2013 9:31 am Post subject: 1.8T conversion - what power steering fluid? |
Messy, messy, messy...
I've got a 1.8T conversion with a suposedly rebuilt power steering rack, but powered off the 1.8T PS pump.
I note the requirement for power steering in a standard vanagon is actually ATF dexron, whereas the requirements for a 1.8T is pretty special and pricey Power Sterring Fluid.
Dexron seems quite a bit thicker than the 1.8T spec fluid.
The PS rack leaks from the main seals (fluid coming from the bellows, both sides, but mostly on the passenger side). It leaks quite a bit, let's say from full to empty in 500kms (+/-300mi.)
I have the thinner, pricier stuff in there now, but was thinking of trying changing out the fluid in hopes it might stop or slow down the leak, on the theory that the 1.8T spec fluid is just too thin for the seals.
On the one hand, it might just be that I need to rebuild / replace the rack, on the other hand, another rack might leak just as badly if the problem really is the "too thin" fluid. Then again I don't want to ruin the 1.8T PS pump with Dexron if it would be too thick...
Any thoughts on this / similar experience / war stories?
Thanks
WiboBusMan
'84 full camper
'88 tintop Syncro (sold)
'86 Doka Syncro 1.8T
'01 A4
'05 A6 |
xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Thu Aug 01, 2013 9:35 am Post subject: |
I have seen plenty of steering racks leaking because of the wrong fluid in the later VW and Audi cars, I have never seen a pump go bad from it however.
In both my 1.8t vans I am using ATF.
Andrew- |
hans j Samba Member
Joined: May 06, 2006 Posts: 2714 Location: Salt Lake City UT
Posted: Thu Aug 01, 2013 9:47 am Post subject: |
I would go with what the rack in the car takes, so ATF. I haven't seen a 1.8t car (newer VW or AUDI) pump leak yet from ATF, only the rack. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17124 Location: Retired South Florida
Posted: Thu Aug 01, 2013 10:07 am Post subject: |
I don't think installing the "special" fluid will seal up your rack. That said, seals are funny things and change fluids can have unexpected affects. I think if you rebuild the rack or replace it, just stick with the fluid you choose. A sealed system should not require an IV drip of replacement fluid, so even the expensive stuff won't put you in the poor house with a sealed system.
The pump uses the fluid for lubrication, so there might be something to your concern about which fluid to choose. So your question is valid. _________________ ☮️ |
VWhead Samba Member
Joined: September 27, 2009 Posts: 337 Location: Pacific Grove,CA
Posted: Thu Aug 01, 2013 12:08 pm Post subject: |
1.8T conversions use ATF Dextron for power steering fluid. It's what the steering rack likes and the 1.8T pump doesn't mind either. That's the way I build all of them. _________________ 81' Single Cab Syncro 1.8T GMW
88' 2wd Westy 1.8T GMW
www.gmwerks.com
SyncroJack Samba Member
Joined: August 23, 2010 Posts: 94 Location: Vancouver, WA
Posted: Thu Aug 01, 2013 12:19 pm Post subject: |
I used the ATF Dextron in my 1.8T also. No problems. _________________ 86 Syncro 1.8T power!, 76 Westy |
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Thu Aug 01, 2013 1:28 pm Post subject: |
If your steering rack leak is minor you can add a little brake fluid to swell up the seals, be sure to dump the fluid after and refill with fresh ATF. It may delay your steering rack rebuild for some time. |
Beetsport Samba Member
Joined: January 08, 2005 Posts: 475 Location: Sacramento, CA
Mountain1.8t Samba Member
Posted: Thu Jun 02, 2016 1:46 pm Post subject: Re: 1.8T conversion - what power steering fluid? |
So Dexron is the fluid of choice of a 1.8t vanagon power steering system.
Now, do I go with Dexron III or VI? Seems like most local parts stores only offer IV, but I can still get III (AC Delco brand) from the local VW dealership. Is there a preference? |
Posted: Thu Jun 02, 2016 5:44 pm Post subject: Re: 1.8T conversion - what power steering fluid? |
Yes, dexron III. Wibobusman, did you try to add some brake fluid to swell the seals? |
