Zero419 Samba Member
Posted: Sun Nov 05, 2023 4:01 pm Post subject: cracked rain gutter from awning |
I've had an awning on my van for many years mounted with the GoWesty adapters and now they are cracked in those locations. what is another way to mount? _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9605 Location: Western WA
Posted: Sun Nov 05, 2023 4:05 pm Post subject: Re: cracked rain gutter from awning |
Was the lower tab floating away from the body?
Or does it restt on the body?
Maybe you have to put a bolt in the tab to prevent the movement. _________________
....KTMs, GasGas, SPOT mtb |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Sun Nov 05, 2023 7:15 pm Post subject: Re: cracked rain gutter from awning |
This is the exact reason why I have not put one on my van _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
valvecovergasket Samba Member
Posted: Sun Nov 05, 2023 7:22 pm Post subject: Re: cracked rain gutter from awning |
How big of an awning? How many mounts? Are they bolted to the body?
Oh and... Pictures _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Sodo Samba Member
Posted: Sun Nov 05, 2023 7:42 pm Post subject: Re: cracked rain gutter from awning |
skills@eurocarsplus wrote: |
This is the exact reason why I have not put one on my van |
Skillz maybe its because you're not camping often enough....??
I've seen perhaps a hundred awnings but never seen cracked gutters.
A pic of the mount and it's installation will help this discussion. _________________
E1 Samba Member
Joined: January 21, 2013 Posts: 6542 Location: Westfalia, Earth
Posted: Sun Nov 05, 2023 8:06 pm Post subject: Re: cracked rain gutter from awning |
I’d bet Skills had similar concerns to mine when I went with another awning (Jonce Fancher’s, it survived Hurricane Matthew when 30 miles from Savannah).
My concerns were mostly about wind strength and weight of the Fiammas, but for whatever reason also didn’t like the mounting. I guess things can look riskier or more intrusive than they turn out to be, a proper worry of loving these old vans.
Is the OP saying the mounts cracked, or the rain gutter? _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
elizer Samba Member
Joined: May 02, 2016 Posts: 1462 Location: Northern Virginia
Posted: Mon Nov 06, 2023 4:29 am Post subject: Re: cracked rain gutter from awning |
For awnings you should really have 3 brackets even with the arb awnings. Also when you install the brackets there is a such thing as tightening them to the rain gutter too much. You can actually see it bending and distorting the rain gutter which I assume weakens it. You need to back off on tightening at that point. _________________ 91 syncro westy fas tdi |
Posted: Mon Nov 06, 2023 6:16 am Post subject: Re: cracked rain gutter from awning |
Sodo wrote: |
A pic of the mount and it's installation will help this discussion. |
in my 30+ years of camping (a bulk of that in a bay) I have never seen the need to lug one around.
Yea, they are kind of cool but I also never found a need to set up my (factory) drive away tent either.
looking at the various mounting systems it is inevitable that there would be some damage to the van. Believe it or not, every time I have to drill a hole in a car...my ass puckers. I 100% hate it _________________
Jake Raby wrote: |
Brian wrote: |
SCM Samba Member
Joined: January 26, 2011 Posts: 3115 Location: Bozeman MT
Posted: Mon Nov 06, 2023 10:56 am Post subject: Re: cracked rain gutter from awning |
I'm in the same boat and would really like to see photos of the OP's issue.
Almost all of my camping is accessed by driving USFS roads with a good amount of washboard, bumps, and ruts. My wife is pushing (actually offering to buy) an awning for our van. The only one I really like is the hard-cased ARB option but I worry about the raingutters, drilling holes for brackets, and the possibility that a third bracket won't fit due to the curvature of the van as I've read on another thread here.
In 30 years of car/van camping I can count the number of times that I've used or wanted to use a tarp/awning on one hand. And I'm quite good at rigging a tarp to the side of my Westy. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
1988M5 Samba Member
Joined: January 23, 2016 Posts: 674 Location: Santa Cruz, CA
Posted: Mon Nov 06, 2023 11:09 am Post subject: Re: cracked rain gutter from awning |
To deal with the curve I used spacers but the intent was to not bow the awning. I guess it would work the other way around too and not stress the van.
BK _________________ 1991 tin top GL
Some BMWs. |
elizer Samba Member
Posted: Mon Nov 06, 2023 12:05 pm Post subject: Re: cracked rain gutter from awning |
I have the 3 brackets without the bottom hole drilled. So far no issues. I had the arb. I moved to the fiamma.
Drilling into the body is 100% the best solution. But I too hate drilling holes. The bottom portion still makes positive contact with the body and has yet to pull away. But, ya it is still a lot of weight riding on there. I'm surprised people mount roadshowers on rain gutters.
The ease of setting up and breaking down is huge on how often I use something. The fiamma takes seconds. I have a 23zero 270 degree awning on my overland trailer. I have used it 0 times. _________________ 91 syncro westy fas tdi |
Sodo Samba Member
Posted: Mon Nov 06, 2023 12:36 pm Post subject: Re: cracked rain gutter from awning |
Agreed on all counts elizer.
Re: drilling a classic vehicle, I pucker too, hem & haw.
Eventually I have to remind myself that if drilling was so bad, rust repair or collision repair would be impossible
and upon discussing with myself that a hole can often be patched,,,,
I weigh how bad I want the mod, how much time I've wasted thus far,
get confident that I'm not about to drill the wrong location,
and (if all is well) drill-baby-drill.
The awning is kind of like a specialty tool.
Only AFTER you buy it...
And use it more than once,
can you start the regret,,,,
in not buying it 30 years ago.
Upgrading to the Fiamma is like "then buying the better tool" and you start the "past regret" counter at zero again. _________________
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3093 Location: ABQ NM USA.... Except when not
Posted: Mon Nov 06, 2023 1:02 pm Post subject: Re: cracked rain gutter from awning |
Even with this ease, I rarely use it. Only if hanging out in sun or rain...I rarely hang out.... And it's nice to have when one wants it
Now the brackets, supported on the rain gutters and drilled into side have worked really well. I think the lower support point helps.
The same brackets on the other side have held a couple hundred pounds or kayaks, skis, and hang gliders depending on season. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Mon Nov 06, 2023 1:04 pm Post subject: Re: cracked rain gutter from awning |
Huh... I've heard of sunk costs. This thread's direction makes me feel as if there needs to be a new term:
Sunk Regrets!
I've got enough money to buy a Fiama, and have had such an amount (dedicated for VW toys, and fixes) for quite a while. Mrs. Black Loves the idea. Our camping style has never had me grumpy that I didn't have an awning yet. But, I still WANT one.. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
elizer Samba Member
Posted: Mon Nov 06, 2023 1:19 pm Post subject: Re: cracked rain gutter from awning |
The fiamma 45s 10ft weighs about 50 lbs
The arb Hard case 2500x2500 weighs about 40 lbs
Still curious to see the OP pictures, driving conditions, etc. _________________ 91 syncro westy fas tdi |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32592 Location: Reading Pennsylvania
thatbaldwinlife Samba Member
Joined: August 01, 2011 Posts: 777 Location: Out exploring
Posted: Wed Nov 08, 2023 7:26 am Post subject: Re: cracked rain gutter from awning |
We love our Fiamma awning and couldn't imagine camping without it. Especially here in the PNW where it will rain from like Nov-April
I too was concerned with cracked and deformed rain gutters especially after we went to the 10' F45 awning. Here is what we did:
I took the GoWesty brackets and added 2" to each side of the clamping area making them around 7" wide each. I just used a small sledge, a vise and a welder to form the extensions. This spreads the clamping loads out significantly. We then drilled and inserted the Rivnut to use a security bolt to retain the lower part of the bracket onto the body. This is very important to keep it from flopping around. We also used spacers to deal with the curve of the Westy vs the straight awning.
We still feel it shaking a bit on rough washboards but after a few seasons of abuse, it looks just like it did when we modified it.
Hope this helps.
nate _________________ 1987 Westy
Insta: @Thatbaldwinlife
Vanagon Adventure and DIY videos:
That Baldwin Life YouTube Channel
Last edited by thatbaldwinlife on Wed Nov 08, 2023 9:12 am; edited 1 time in total |
E1 Samba Member
Posted: Wed Nov 08, 2023 9:00 am Post subject: Re: cracked rain gutter from awning |
Good work creating a fix, but this ^^^ is precisely what’s amiss with some vendors, and *consistently* one in particular that I’ve personally observed for over a decade now.
If vendors can’t make the time to engineer and fully test their wares, in what other venue is it presumed or acceptable that the users — the *customers* — are able do that pre-market work for them?
Nonsensical, and I’ve tired of posters here excusing what clearly appears to be absolute disrespect in serving — and in some cases, protecting — the customer.
We customers *built* these companies with hard-earned money, they owe us for that and for trusting them, and we deserve that very basic Business 101 consideration. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
