THINGONER Samba Member
Joined: April 13, 2008 Posts: 674 Location: riverside ca
Posted: Mon Aug 05, 2013 6:41 pm Post subject: Thermostat flaps open to the max? |
I am currently attempting to set up my thermostat and flaps on a type 1 motor. Can someone tell me with the thermostat fully extended are the flaps supposed to be at their maximum point of travel (open)? In other words the maximum they can travel-with nothing connected to them? I am able to set it up with my flaps fully closed (thermostat cold) but then although the flaps open they are not at their maximum travel. Hope this makes sense thank you. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Mon Aug 05, 2013 7:26 pm Post subject: |
Yes. Max travel is parallel with the cooling fins. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Mon Aug 05, 2013 7:40 pm Post subject: |
Flaps parallel with cooling fins?-that makes sense-I guess at this point I will adjust to get max open instead of max closed-I cannot achieve both. I do have some slop in the linkage at the pivot points. |
74 Thing Samba Member
Posted: Mon Aug 05, 2013 7:42 pm Post subject: |
They are supposed to be but the circular springy attachment point for the thermostat rod on the drivers side flap sometimes gets bent and it no longer closes or opens all the way properly. The easiest way to confirm everything is working correctly is to install the fan shroud onto the engine sheetmetal without the fan in the housing then use a hairdryer to activate the thermostat and make sure everyting opens and closes properly.
I believe Max Welton has a posting somewhere here doing just that with photos. |
Posted: Mon Aug 05, 2013 8:17 pm Post subject: |
I was doing that very test actually-That would make sense about the circular thing the rod fits into-like someone (not me ) tried to pull off the shroud before disconnecting thermostat-Thanks for the replies you guys have been very helpful. |
VIN Samba Member
Posted: Tue Aug 06, 2013 10:38 am Post subject: |
i had the exact same problem, i could only get full open or full closed. not both. i would rather have full open of course. _________________ Co-owner, 2 Brothers Guns
[email protected]
Click to view image |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
hill Samba Member
Posted: Tue Aug 06, 2013 12:53 pm Post subject: |
I had to fiddle and tweak the flaps themselves to get both to get onto their closed stops together, and then needed to screw the thermostat down two full turns to get the whole thing working both hot and cold.
Helps a lot to make marks on the tin showing both open and closed position of the operating levers before starting to twiddle the connecting piece.
Weird system but it actually can work. Too bad they didn't put it where you could watch it with the engine installed. _________________ '78 Biegephalia |
Posted: Tue Aug 06, 2013 2:00 pm Post subject: |
we need some computer geek to put a sensor on it and measure that, sort of like a cooling system TPS. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Tue Aug 06, 2013 5:01 pm Post subject: |
You can put a little flipper-needle tattle tail on the pivot pin so the angle of rotation can easily be observed from in the engine compartment.
A suspension height potentiometer could easily be adapted to measure the vertical thermostat rod displacement. (then data log this info, or display it)
http://blog.accuairsuspension.com/wp-content/uploads/MG_51491-1024x668.jpg |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3899 Location: Seattle, WA
Posted: Tue Aug 06, 2013 5:49 pm Post subject: |
I don't think it was ever intended, nor is it desirable, that the flaps are
100% closed when cold. Pretty much for the same reason you don't
adjust the carb throttle plate to be 100% open when the pedal is
floored: there needs to be a little slack to prevent excessive strain on
all the parts.
If the bracket is adjusted correctly (as outlined in the Bentley manuals),
then the flaps will automatically be 100% open when the tstat expands
enough to be stopped by the bracket, unless there is damage/distortion
somewhere in the assembly. _________________ '67 bug: seized by the authorities
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Wed Aug 07, 2013 5:53 am Post subject: |
Quote: |
then the flaps will automatically be 100% open when the tstat expands |
kreemoweet is right about the manuals. The flaps need to be wide open with it expanded. When cold, take the bolt out of the bottom of the thermostat, lift the thermostat up until it hits the bracket. Adjust either the bracket, rod, or both to get the flaps wide open. Move the thermostat down in the bracket and replace the thermostat mounting bolt in the bottom of the bracket. Whatever flap closure you get is it! To 'check' the flap position on an engine, scribe a line on the flap shaft to show open or closed. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
VIN Samba Member
Posted: Thu Aug 08, 2013 8:44 pm Post subject: |
I painted a couple purty lines on my shroud for full open/closed.
[email protected]
Clatter Samba Member
Joined: September 24, 2003 Posts: 7544 Location: Santa Cruz
Posted: Fri Aug 09, 2013 8:05 am Post subject: |
ALmost all of these motors have been taken apart by a dumbass at least once in their life.
The idiot is trying to lift the fan housing up and off the oil cooler, and it won't go...
So they yank and tug and cuss, then finally realize that there is this metal rod sticking down there for some reason.
Then, they make sure to never install THAT dumb thing again, whatever it was.
So has come the tradition of taking it off and throwing it away.
If you are going to try and run these parts, you are going to have to carefully un-dumbass it, if possible.
All/any of the parts are going to have to be verified as to their straightness.
What they actually are supposed to look like is actually a mystery, as non-dumbassed ones are very, very rare.
Also, the bushings that the flap shafts ride in are some kind of plastic or phenolic, and are very likely to be broken from the dumbass they have been subject to.
So, long story short, eveything will have to be un-dumbassed very carefully, and never, ever underestimate their level of dumbassedness... _________________ Bus Motor Build
What’s That Noise?!? |
VIN Samba Member
Posted: Sat Aug 10, 2013 9:13 am Post subject: |
LOL, my bushings are bronze, maybe the early ones are plastic. _________________ Co-owner, 2 Brothers Guns
[email protected]
