stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Wed Aug 07, 2013 10:37 am Post subject: Replacing heater hoses |
I am thinking of replacing the heater hoses on my Westy. But a trip is coming up and I am not sure it can be done before that. My question is does the fuel tank need to be dropped in order to replaced the front to back runs? There are ties that I can see when the hoses are exposed, but I don't remember if there are any above the tank. If there are, it will make ti very difficult to feed then through the ties again with out dripping the tank.
Please answer my question only if you have done this before. _________________ Steve
87 Westfalia full camper 4 speed |
SCM Samba Member
Joined: January 26, 2011 Posts: 3118 Location: Bozeman MT
Posted: Wed Aug 07, 2013 11:18 am Post subject: |
I didn't need to remove my tank. There were some ties but I was able to reach into the "saddle" above the tank and cut them. Once the ties were cut, I used a barbed fitting to attach the new hose to the old one, then pulled the old one out - simultaneously pulling the new one into place.
Dealing with the coolant loss and subsequent air bleeding were (for me) a far bigger hassle than swapping the hoses. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Wed Aug 07, 2013 12:16 pm Post subject: |
SCM wrote: |
Dealing with the coolant loss and subsequent air bleeding were (for me) a far bigger hassle than swapping the hoses. |
Thank you very much for the tip. Good to hear I don't need to drop the tank. Dropping the tank means I must have enough clearance under the van to remove the two straps and it is a pain. _________________ Steve
metropoj Samba Member
Posted: Thu Aug 08, 2013 4:36 am Post subject: Clamps ... |
Speaking of coolant hose replacement, the P.O. used almost exclusively the normal style worm gear clamps unlike the GEMI style.
Is this what most people are using ? My few silicone hoses I got from Van Cafe have the smooth type but trying to find any here locally ( Toronto Canada ) is proving to be a challenge. The local parts stores look at you like you're from Mars ....
Where are people getting their smooth faced clamps from ? I need to order a pile up for the rest of the hoses !
Cheers,
JMM. |
SCM Samba Member
Posted: Thu Aug 08, 2013 8:17 am Post subject: Re: Clamps ... |
metropoj wrote: |
Cheers,
JMM. |
https://www.belmetric.com/ _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
