thermador support strut
eagle5127
eagle5127 is offline
PostPosted: Tue Sep 08, 2009 9:10 pm    Post subject: thermador support strut Reply with quote
I have located several vintage Thermador swamp coolers but without the support strut to help stabilize the unit when mounted..anyone know where such a part can be purchased?
cmdog73
cmdog73 is offline
PostPosted: Tue Sep 08, 2009 9:34 pm    Post subject: Reply with quote
Sell me one at your cost and i'll find you a support rod.
eagle5127
PostPosted: Tue Sep 08, 2009 9:41 pm    Post subject: Reply with quote
I do not own a swamp cooler but hoping to buy one..
hitest
hitest is offline
PostPosted: Wed Sep 09, 2009 7:07 pm    Post subject: Reply with quote
I'd suggest scooping up those Thermos before they dissappear- then concentrate on the struts. I've never seen a spare strut- but if you were local to me- I'd pull mine off so you could duplicate it. Perhaps another owner would do the same?
'62 L390 151, '62 L469 117, '63 L380 113, '65 L512 265, '65 L31 SO-42, '66 L360 251, '68 L30k 141, '71 L12 113, '74 ORG 181
FU#5
eagle5127
PostPosted: Wed Sep 09, 2009 7:21 pm    Post subject: Reply with quote
As a former Idahoan, I wish I had stayed in place! I will heed your advice..
gt1953
gt1953 is offline
PostPosted: Wed Sep 09, 2009 7:26 pm    Post subject: Reply with quote
I could use one here in Aridzona. Evil or Very Mad
72 type 1
73 type 1
72 Squareback
({59 Euro bug, 62, 63, 67, 68, 69 type ones 68 & 69 type two, 68 Ghia all sold})
eagle5127
PostPosted: Wed Sep 09, 2009 7:28 pm    Post subject: Reply with quote
I have noticed that a majority of the vintage swamp coolers do not use a support rod but rely on mounting to the top door jam for its support..
nodak_85
nodak_85 is offline
PostPosted: Thu Sep 10, 2009 9:54 am    Post subject: Reply with quote
it is very hard to come across one with a support rod. like hitest said buy one then worry about it. they are getting very hard to come by. thats what i did. i just had to make one. granted its not close to what the original looks like it works. i just dont drive with it on, not until i can make one like the original. i belive the original one had a foot on the bottom of it. here is a pic of what mine looks like
i suppose you cant really see it but all it is ia a 1/4 inch stainless steel rod that i threaded the top of it and put a rubber cap on the end. can some one post a pic of and original rod so i can make it exact?
eagle5127
PostPosted: Thu Sep 10, 2009 10:15 am    Post subject: Reply with quote
Nodak...do you drive w/o the support rod? several owners have told me they drive without the support and the unit seems stable...
nodak_85
nodak_85 is offline
PostPosted: Thu Sep 10, 2009 10:44 am    Post subject: Reply with quote
no i dont. i have a prop rod that i made, and i put the cooler on when i get to a show. i dont dare drive with it on till i can make or get an original prop rod. it is very unstable with out it. but i have one piece windows to so that probally doesnt help.
eagle5127
PostPosted: Thu Sep 10, 2009 10:48 am    Post subject: Reply with quote
thanks for the clarification..I understand the Firestone version requires a support rod since it mounts on the top of the window glass, where the Thermador uses brackets to clamp to the top of the door jam...and those owners say they drive w/o a support rod..
nodak_85
nodak_85 is offline
PostPosted: Thu Sep 10, 2009 11:04 am    Post subject: Reply with quote
mine is a thermador that requires a support rod. but i have seen some that do clamp on the door its self, mine goes up into the window channel and you roll the window up on to it and screw a backing plate onto the inside of the window then use a prop rod. somebody correct me if i am worng but i believe they made a couple differnt styles. here is a pic of it.
Yellowbeard
Yellowbeard is offline
PostPosted: Thu Sep 10, 2009 11:20 am    Post subject: Reply with quote
There's a guy making repops. He advertises here from time to time. I directed Lee. to his ads when he bought a Thermador from me. Anybody know his username off the top of their heads?
Lohe wrote:
Thanks. Thread went from me not being able to understand what Ipis was saying because English is obviously not his first language to me not being able to understand it because English is my first language Laughing
Fuel pumps galore:
http://www.thesamba.com/vw/classifieds/detail.php?id=845378
nodak_85
nodak_85 is offline
PostPosted: Fri Sep 11, 2009 7:39 am    Post subject: Reply with quote
does he make repos of the whole deal including a prop rod? i would like to get the rod if possible
Yellowbeard
PostPosted: Fri Sep 11, 2009 8:32 am    Post subject: Reply with quote
Sorry, I should have been more clear. The only thing he repops is the prop rod.
Fuel pumps galore:
nodak_85
nodak_85 is offline
PostPosted: Fri Sep 11, 2009 10:13 am    Post subject: Reply with quote
thats perfect. that exactly what i need. did anyone ever figure out who it is?
Amigo-2k
Amigo-2k is offline
PostPosted: Fri Sep 11, 2009 10:41 am    Post subject: Reply with quote
check on ebay this ad below that ended says this guy is re-popping the rods:
http://cgi.ebay.com/ebaymotors/OLD-SCHOOL-THERMADO...06.c0.m245
1958 Rag Top
http://ryanendres.com
Operations manager with a results-driven passion for process improvement
Yellowbeard
PostPosted: Fri Sep 11, 2009 11:47 am    Post subject: Reply with quote
That's the guy. I think Lee. bought one from him. Ask him how he likes it.
Fuel pumps galore:
nodak_85
nodak_85 is offline
PostPosted: Fri Sep 11, 2009 2:34 pm    Post subject: Reply with quote
cool thanks guys
hitest
hitest is offline
PostPosted: Fri Sep 11, 2009 8:19 pm    Post subject: Reply with quote
* bonus info:
The prop rod with my Thermo is the flat channeled steel version- and has an "S" bend where it hooks over the scraper seal. This prop has worn a 1" tear in my OG seal- just a warning. (I call it a beauty mark)
I have run this cooler every summer for about 10 years now- and I'll bet it holds about 13 pounds of water and ice! I think I could run it empty w/o the prop- but certainly have one if you fill it.
Oops, almost forgot the street cred photo:
FU#5
