thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Wed Aug 21, 2013 6:37 pm Post subject: Early engine assembly - something is wonky |
I have the long block assembled for my '63 T34, and I'm test-fitting all of the tin and whatnot before I have it powder coated. I have an "NOS" muffler of unknown provenance, but the little metal tubes which go between the fan shroud and the heater boxe don't line up very well. The amount by which they miss is about the same on each side.
Do I have the wrong parts, or do is this one of those cases where new parts just aren't that great? I have an extra set of connector tubes that I could sacrifice to 'stretch' these to fit, but that seems wasteful.
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Aug 21, 2013 10:21 pm Post subject: |
Stupid question- you have the rubber collar connectors, right? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
thom Samba Member
Posted: Thu Aug 22, 2013 6:19 am Post subject: |
Tram wrote: |
Stupid question- you have the rubber collar connectors, right? |
Yes, I have the collar connectors, but this is so far out of whack that it will be difficult to install them, and they'll probably tear in a short time anyway.
Here's a pic of my other motor. There's a little bit of offset between the pieces, but not nearly as bad
1956 Single Cab
1963 Unimog 404
1965 E-Type |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34012 Location: Conejo Valley, CA
Posted: Thu Aug 22, 2013 8:04 am Post subject: |
Is the sheet metal surrounding the small rear heat exchangers welded to the pipes, or just crimped like on Bugs? On my old Bug, I often had to rotate/adjust the sheet metal surrounding them until they lined up right. |
t3kg Samba Member
Joined: June 14, 2006 Posts: 2712 Location: Los Angeles
thom Samba Member
Posted: Thu Aug 22, 2013 8:09 am Post subject: |
KTPhil wrote: |
When I first tried to install it, neither outlet on the driver's side lined up - meaning both the connection to the heater box and to the fan shroud were both off by a significant amount. I drilled out the spot welds and rotated the clamshell so that it would at least line up with the heater box. The passenger side lines up OK with the heater box, but not with the fan shroud.
I wonder if these "NOS" parts that are on the market now were really QC rejects that never made it through the original supply chain. I have another "NOS" early T3 muffler and it won't even fit on the exhaust studs - I will have to rotate the flange about 5° on each side. That being said, the NOS muffler I used on the last motor was perfect. _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Thu Aug 22, 2013 8:13 am Post subject: Re: Early engine assembly - something is wonky |
t3kg wrote: |
I think if you tighten the muffler down it'll line up better. I see a big gap where the upper part of the exhaust flange meets the head. |
That will line it up slightly better in one plane, but if you look at the other pictures, it is way off in the other plane.
t3kg wrote: |
What's up with the welding in the first photo? Was the upper left flange repaired? |
I had to break the clamshell loose and reposition it to get it to line up at all. It was originally pointing about 15° away from the heater box. _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
thom Samba Member
Posted: Thu Aug 22, 2013 7:52 pm Post subject: |
I installed the other NOS muffler tonight, and it fit somewhat better. This one has a lot of shelf wear, and it took some 'adjusting' to get it to fit, including cutting off and re-clocking one of the flanges. There is evidence of someone trying to fit this previously, and apparently they gave up.
I guess in order to use the other muffler, you would have to use paper tubes or something instead of the metal couplers.
1956 Single Cab
1963 Unimog 404
1965 E-Type |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22423 Location: Kimball, Mi
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Thu Aug 22, 2013 9:59 pm Post subject: |
thom wrote: |
Tram wrote: |
is it just me or does that engine appear to be running? looks like the timing pulley is spinning... _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
vdubin Samba Member
Joined: September 09, 2006 Posts: 305 Location: Huntsville, Al
Posted: Fri Aug 23, 2013 5:39 am Post subject: |
it is running. you can see the coil wire coming over the intake and the fuel cans. that was his test bench. |
thom Samba Member
Posted: Fri Aug 23, 2013 6:22 am Post subject: |
Yes, the engine is running in that picture. It is easier to sort out various issues with the engine out of the car. _________________ -Thom
1956 Single Cab
1963 Unimog 404
1965 E-Type |
