built in refer OR stand alone refer |
Built in Refer (i.e. Truckfridge or equivalent) |
54% |
[ 31 ] |
Standalone Refer (i.e. Engle, Edgestar, or equivalent) |
45% |
[ 26 ] |
Total Votes : 57 |
madspaniard Samba Member
Posted: Sat Aug 24, 2013 11:14 am Post subject: |
dobryan wrote: |
furrylittleotter wrote: |
I really appreciate the followups, and as I suspected, the one guy with a HUGE solar panel can run indefinitely, the others are limited but can still extend battery life.
Neil2 |
I have the 62qt Edgestar and a 100W solar panel, MPPT controller, and 115AH deep cycle house battery. On our maiden voyage with this combination last spring we went for a week off the grid and still had a full battery after a week. |
Thanks. Yes, as I mentioned before, that is what I would expect with this setup with plenty of sun. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
nocreditnodebt Samba Member
Joined: September 28, 2012 Posts: 332 Location: Socal
Posted: Sat Aug 24, 2013 11:41 am Post subject: |
I have a Vitrifrigo c51is, very similar to the TF-49, same compressor same box.
I have added insulation, and maximized airflow through condenser and across compressor, my unit runs well less than a 30% duty cycle in upto 85 degrees ambient.
Number 1, I can keep my interior from raising much above ambient.
Number 2, the Danfoss bd35f compressor can handle upto an 8 cubic foot fridge. It is just coasting along powering a 1.8 cubic foot fridge.
Those claiming very high battery consumption or not being able to run indefinitely with 65+ watts of solar likely have an inefficiency bottleneck somewhere, most likely in the form of recycling preheated air through the condenser.
The single best way to increase efficiency is to have the fan pull the coolest possible ambient air across the condenser, once. Not just have a few restrictive passive vents in the compressor compartment for the heat to make its own way out. The better the heat can be removed from the condenser, the lower the battery consumption, the better the fridge performance, and the longer the life of the unit.
My battery monitor says My fridge uses well less than 24 amp hours per 24 hours. It really depends on what I am asking it to remove heat from or keep the heat removed from. Installing a gallon of warm tomato juice and a 12 pack of warm beer makes the duty cycle skyrocket for several hours before tapering back toward 25%, and the heat coming out my exhaust vent behind the compressor is much much hotter than when everything inside the fridge has already been brought to sub 35f temps.
My 200 watts of solar have no issues what so ever returning what my fridge consumes. I could likely run 3 similar fridges in my environment before the solar could not keep up.
My batteries are now at 40% of their original capacity. Still no worries.
My previous fridge was a Norcold. the SawaFuji compressor was a Buzzsaw. It was not as efficient as this Danfoss powered Vitrifrigo which is nearly silent in comparison
Danfoss compressors can handle up to 0.5 amps of computer fans that turn on when the compressor does and dopuble that for 1 second on start up. Adding another low draw, low noise, low cfm computer fan to exhaust the compressor compartment will increase performance, reduce battery consumption and extend compressor life. The amount of tech which goes into some of these computer fans is impressive.
Google Noctua Nf-f12
You salvaged computer fans might be economical, but low tech noisy and consume more electricity for less air moved.
Can you get away without doing so? Of course. Most do. To my mind having small passive vents behind the fridge is akin to blocking 75% of one's radiator with cardboard and wondering why the engine is running hot |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Sat Aug 24, 2013 12:56 pm Post subject: |
nocreditnodebt wrote: |
Very interesting upgrade on your fridge! I did google the fans and found a test that said they are extremely quiet but double the price of other fans.
http://www.youtube.com/watch?v=Mi46_1BnPPw
I see you are quite knowledgable and seem to be a fan of the Danfoss compressor. That was a big factor for me as well. I had friends that worked at their place outside of Atlanta, and coincidentally, my GF is from the same town as Danfoss, (Nordborg, Danmark)
Great company, great product.
Neil2 |
joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Sat Aug 24, 2013 2:45 pm Post subject: TF-49 |
Yes I did put more insulation on the TF-49. Also took a stock Westy fridge vent and put the pipe over the compressor with a new low power computer fan. Now my duty cycle is down to 30% of the time from almost 50%. And the TF-49 can go 3 weeks with out turning the engine on. That is the most time I have pushed it. Now I'm down to a little less then 24 amps per day. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
kamzcab86 Samba Moderator
Posted: Sat Aug 24, 2013 3:38 pm Post subject: |
Great that you have so much passion on the topic, Kamz, sorry that you find my desire for actual useful data annoying in any way. Feel free to ignore my posts if you find them disconcerting in the future.
I only take issue with your dismissive attitude towards my supplying manufacturer data that others may find helpful. If it wasn't useful to you, fine; but don't outright dismiss it all as being completely useless to everyone else, many of who don't care about the little details, like how much cooling is lost when the door is opened.
But, you know what, you're right; providing all that data was a complete waste of my time. Please forget I ever posted all that junk. Everyone interested in a new fridge: Don't worry about needing to conduct basic 5th-grade math, or doing any of your own research, including contacting manufacturers, to determine your own needs that will fit your budget. Instead, just copy someone else's entire existing, well-working system described here on The Samba... they've completed all the groundwork for you. Done and done.
I really appreciate the followups, and as I suspected, the one guy with a HUGE solar panel can run indefinitely, the others are limited but can still extend battery life. |
Extending battery life is not the only reason for charging (no matter the method) your aux battery: You need to maintain its capacity too. _________________ ~Kamz
2016 Golf GTI S
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Thu Nov 07, 2013 11:59 pm Post subject: |
kamzcab86 wrote: |
FWIW, I did some research on these things:
ARB 50qt.: 0.7 - 2.3 amps (1.35 amps avg. w/ 90°F ambient temp) on 12v
EdgeStar 43qt.: up to 5.4 amps on 12v
EdgeStar 63qt.: up to 5.5 amps on 12v
Engel MT35 & MT45: 0.7 - 2.5 amps on 12v
TF49: 2 amps average on 12v
Warrantee policies:
ARB = 3 years
Edgestar = 1 year
Engel = 2 years
TruckFridge = 1 year _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
LandSailor Samba Member
Joined: October 30, 2009 Posts: 315 Location: Las Vegas, NV
Posted: Fri Nov 08, 2013 11:08 am Post subject: |
Very interesting that the poll is so evenly divided.
One big advantage to the removable units is that they are, in fact, removable. That ~$500 investment can be used in the house during Thanksgiving, if your refrigerator goes out, or just to get ice cream home from the store in the summer in Las Vegas. That's the biggest advantage in my book: You're not putting half a grand into something that will only be used in the Westy.
The other is that they operate on the "all of your cold doesn't fall out every time you open the door". Just look at all the frozen products in horizontal open freezers at the grocery store.
We've only made one trip so far in the Westy and we used an ice chest behind the passenger seat. It was useful as a footrest and for getting into the top bunk. |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Fri Nov 08, 2013 9:08 pm Post subject: |
ThankYouJerry wrote: |
Warrantee policies:
TruckFridge = 1 year |
Incorrect - it is actually two years. |
Posted: Fri Nov 08, 2013 9:20 pm Post subject: |
westyventures wrote: |
Warrantee policies:
Incorrect (unless TruckFridge's website isn't up to date) - it's actually 1 year (at least for ALL portable fridges). Here's the link to their site and a portable fridge that says "1 year" (same for all other portable models): http://www.truckfridge.com/tf41.html _________________ 1990 Multivan - "Ohana"
Posted: Fri Nov 08, 2013 9:34 pm Post subject: |
Warrantee policies:
Incorrect (unless TruckFridge's website isn't up to date) - it's actually 1 year (at least for ALL portable fridges). Here's the link to their site and a portable fridge that says "1 year" (same for all other portable models): http://www.truckfridge.com/tf41.html |
Well, you didn't specify portables.
From their site:
"2 year warranty on most Front Opening models
1 year warranty on most Portable models" |
Posted: Fri Nov 08, 2013 9:37 pm Post subject: |
Warrantee policies:
From their site:
True… but the vast majority of discussion in this thread has been about portables… even though it didn't start out about portables .
Also, if you'll please note, in my first post in this thread... I quoted Kamzcab86… all portable fridges. _________________ 1990 Multivan - "Ohana"
Corwyn Samba Member
Joined: December 29, 2009 Posts: 2237 Location: Olympia, Washington
Posted: Fri Nov 08, 2013 10:37 pm Post subject: |
. . . .meanwhile, back on the subject . . .
I have an Edgestar FP43. I use my Westy as a daily driver and I don't need the extra weight rolling around town. When I go camping, I put it out next to the van, so not in the way. Now I'm working on installing a Marinco 12v socket on the outside of the van. _________________ '90 White Westy ("The Longship")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~ |
Timwhy Samba Member
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
Posted: Sat Nov 09, 2013 6:50 am Post subject: |
Corwyn wrote: |
I have an Edgestar FP43. I use my Westy as a daily driver and I don't need the extra weight rolling around town. When I go camping, I put it out next to the van, so not in the way. Now I'm working on installing a Marinco 12v socket on the outside of the van. |
Yep, I use mine the same way. I find that a cord can go thru the sliding door gasket just fine so I did not put a 12V outlet on the outside, just made a longer cord... I also use a thin wire bike lock to attach the fridge to the rear jack point to make it less easy for someone to walk away with it.
_________________ Dave O
The Western Syncro build
ChilliConCarnage Samba Member
Posted: Sat Nov 09, 2013 7:41 pm Post subject: |
Just to add to this discussion, here's our setup:
Vitrifrigo (Italian made version of TF49)
120ah batteries
140 watt solar
Longest time camping in one spot: 5 days
Longest time fridge was left on accidentally: 6 days
Wife approval factor: loves having built-in as opposed to portable since there's already so little space.
Based on nocreditnodoubt's recommendations, I replaced the compressor fan. It is now both quieter and more efficient.
I love our setup. Could highly recommend to anybody. _________________ Now:
86 Westy
00 GTI VR6
03 Passat V6 4Motion
Sold:
62 T2 Double Door panel
72 T2 7-passenger
98 Jetta
97 Passat VR6
87 Audi 5000 |
gl98115 Samba Member
Joined: April 22, 2011 Posts: 263 Location: Seattle, WA
Posted: Sat Nov 09, 2013 7:52 pm Post subject: |
LandSailor wrote: |
This is a bit of a myth. The energy required to cool a fridge full of room temp air is trivial compared to the energy required to cool one room temp beer. _________________ '87 faux-Syncro Westy w/ 2.3l GoWesty WBX |
Posted: Sun Nov 10, 2013 12:48 pm Post subject: |
Chest style fridges are generally more efficient not because the cold air spills out. The door opening itself will exchange most of the air inside anyway, top or front door.
It is the fact that chest style fridges have their door seals on top, and that gravity helps compress the seals where as front loading the coldest air has just a thin door seal keeping the hot air out. Since the lock is on top. One can stuff their fridge, and barely get the door closed. It will latch at the top, but flex a bit at the bottom, leaving a small gap.
I think Waeco makes a DC front loader that has locking mechanisms both top and bottom.
I've considered adding some more foam around the seals. Condensation forms on adjacent exterior metal in humid weather showing it could benefit from increased insulation.
But honestly I have no fears about the fridge consuming too much battery.
It is this dang laptop which uses up my solar excess. and shutting it off 30 minutes earlier could save the electricity that improved insulation around my door could improve if installed. |
BetaVan Samba Member
Joined: September 14, 2011 Posts: 209 Location: Redwood City, CA
Posted: Sun Nov 10, 2013 2:08 pm Post subject: |
Dobryan, that venting trick is slick. Do you have a post on that? Would love to hear a bit more about it.
Love my TF-49. It was super easy to install (with all the Samba help of course). It's quiet, way more efficient, and has plenty of storage for my needs. _________________ 84 Westfalia
Vanistan 2.2 Powerplant
WBXhaust + External Oilcooler |
Posted: Sat Nov 23, 2013 8:37 pm Post subject: |
FWIW, these are relabeled Indel portables - exactly the same as the Truckfridge portables except you pay more for a longer warranty. |
